Updating firmware.
E3D thermistors are configured like this, T100000 B4725 C7.06e-8
@rushmere3d Thanks I will try that Thermistor config. Do I just replace everything past Y"thermister" on the M308 line with the info you provided? just double checking before making a change to the config as Im a little rusty on Reprap
@kwad3d said in Updating firmware.:
You change the B parameter and the C parameter (or add it if it is missing)
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8
@phaedrux said in Updating firmware.:
Ok that seems to have my temps at normal levels. After pid tuning with M303 I enter M500 and get a Warning about no M501 was executed in config.g. Does that mean the tune did not save?
The tune saved, but now you have to add M501 to the end of config.g to load those saved results at boot up.
@phaedrux So I have been tuning for a few days and Im trying to set up pressure advance now. Im following the guide at https://duet3d.dozuki.com/Wiki/Pressure_advance but I don't see any change vertically in the print. However the test print looks great.
M550 P"Voron V1.9" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 S0 ; physical drive 1 goes forwards
M92 X160.00 Y160.00 Z400.00 E832.0 ; set steps per mm
M203 X12000.00 Y12000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E700 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X-25 Y-25 Z-2 S1 ; set axis minima
M208 X325 Y300 Z450 S0 ; set axis maxima; Endstops
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-26 Y-2 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:325 Y05:325 S56 ; define mesh grid; Heaters
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Presure Advance
M572 D0 S0.1M501
And here is my slicer layer change settings using S3D.
{if layer_num== 1}M572 D0 S0.0
{elsif layer_num== 25}M572 D0 S0.01
{elsif layer_num== 50}M572 D0 S0.015
{elsif layer_num== 75}M572 D0 S0.02
{elsif layer_num== 100}M572 D0 S0.025
{elsif layer_num== 125}M572 D0 S0.03
{elsif layer_num== 150}M572 D0 S0.035
{elsif layer_num== 175}M572 D0 S0.040
{elsif layer_num== 200}M572 D0 S0.045
{elsif layer_num== 225}M572 D0 S0.05
{elsif layer_num== 250}M572 D0 S0.055
{elsif layer_num== 275}M572 D0 S0.06
{elsif layer_num== 300}M572 D0 S0.065
{elsif layer_num== 325}M572 D0 S0.07
{elsif layer_num== 350}M572 D0 S0.075
{elsif layer_num== 375}M572 D0 S0.08
{endif}Im not sure if was on,,, went through the settings. Or just ran the whole print at S0.1
M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2)Increase the speed, accel, and jerk for the E axis and try again.
Try
M566 E3000
M203 E6000
M201 E3000 -
@phaedrux Thanks for the input. I will try that tomorrow. So it was on but my settings were holding it back?
Most likely yes.
