Duet3D PCB delta printer effector sneak preview
Have been reloading the order page the last two days
The prices from the Duet3d web shop are now confirmed as follows, all excluding shipping and VAT where applicable:
Effector, carriage adapters, connector kit and heatsink £45
Accessories:
E3Dv6 hot end kit 12V or 24V less heatsink and temperature sensor £30
Thermistor temperature sensor £4.50
PT100 temperature sensor £12.50
Set of 6 Haydn Huntley 360mm arms with Delrin ends and 12 ball studs £65
Additional set of 12 ball studs £12All the accessories are standard E3D or Haydn Huntley parts, so those outside the UK may prefer to obtain them from a local distributor.
Hi David,
Any idea when we will be able to place orders?
what kind of sensor does effector use for autobed?
It's a strain gauge that detects a minute flexing of the PCB.
Any news when it's going on the store David?
Accessories:
Is the effector populated including the strain gauges?
what will be shipping price for eu?
will you sell the set of Haydn Huntley's rod without the ballstud ?
@Alexander:
The effector PCB is fully populated and tested. You just need to mount the ball studs and hot end on it.
That's not up to me, but it's not planned. What are your reasons for wanting the rods without the ball studs, given that the effector and carriages are designed to suit the ball studs?
It will be in the store when it is in stock. I'm not involved with the web store, but I am told that making it available to pre-order would be an extra complication.
Ahhhh ok, I'll have to keep checking the store
We'll make an announcement on this forum when they are in stock.
Really looking forward to this
Will order everything I need as soon as the pcb kit is in stock Pcb kit, e3d hotend, duet ethernet, 5" paneldue.
Only missing heatbed, heatspreader, glass and zesty nimble
-Jannis
does it possible to mount titan extruder on it?
It's not designed for that. IMO a standard Titan would be too heavy for a delta anyway, it weighs about 260g. If you want to use a direct drive extruder on a delta, you need one with much smaller motor.
IMHO the best solution is the Zesty Nimble (27 grammes on the effector instead of over 200) the motor is remote mounted on the frame somewhere and transmits its power thru a cable/sleeve system pretty much like an older car Speedo drive cable using the correct adapter from either Shapeways or Thingiverse You can see photos of the set up on a previous page but i have posted some better ones here.
HTH Doug
edit links to adaptors added
Shapeways https://www.shapeways.com/product/62MB3QZJ7/nimble-mount-base-pcb-effector?optionId=62810434
Thingiverse https://www.thingiverse.com/thing:2453322
Or the flex3drive (in the interests of fairness). Which does the same thing.
Both of these options are IMO much better for a delta than a direct extruder, even a titan with 20mm motor (which works really well) is around 230g which is a lot to add to your effector. These are much better than using bowden tubes albeit a well tuned bowden with pressure advance and as short a tube as possible (flying extruder setup for example) can be quite successful.
I have an aluminium effector currently with flex3drive and e3d v6, and its total mass is 250g, it would be twice the mass with a direct titan, even with a minimal motor. I am looking forward to trying the PCB effector, which should be even lighter. If you truly never want to print at speed then the added mass is not really a problem, but then why opt for a delta unless you want to maximise one of its key attributes - lightweight printhead, enabling accuracy at speed?
There is another option and that is a lightweight adaptor which is the shape/size of a nema 17 but is driven by a drive cable, so you can reduce the mass of your titan extruder's motor to a lot less than it currently weighs. This enables you to mount a titan on an effector with less mass than with a motor attached but you would need to come up with a mounting option to attach it to the pcb effector.
Bear in mind that to use the Nimble with the production effector, you will need a different adaptor compared to the prototype that Doug used. The new heatsink doesn't come with the threaded collar that the old one did, instead there is a shorter threaded section and a M12 fine pitch half nut and washer. OTOH the effector now has 3 additional 2.9mm holes at 120 degree intervals on a 17mm radius.
I am assuming that the kit will be available at Filastruder here in the US?
If so, will there be a large lag in availability?
