Thermisors showing wrong temperatures
The heaters now show a reading but they are spiking to 2000 deg
the bed also registers a fault..
what can I possibly have not right?
many thanks for your reply.; Heaters
; Heatbed
M308 S0 P"spi.cs1" Y"thermocouple-max31856" ; configure sensor 0 as thermocouple via CS pin spi.cs1 and sensor type
M143 H0 S120 ; set temperature limit for heater 0 to 120C; Hotend 1-e0
M308 S1 P"spi.cs2" Y"thermocouple-max31856" ; configure sensor 1 as thermocouple via CS pin spi.cs2 and sensor type
M143 H1 S280 ; set temperature limit for heater 1 to 280C;Hotend 2-e1
M308 S2 P"spi.cs3" Y"thermocouple-max31856" ; configure sensor 2 as thermocouple via CS pin spi.cs3 and sensor type
M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H2 S280 ; set temperature limit for heater 2 to 280C -
@dc42 said in Thermisors showing wrong temperatures:
M98 P"config.g
When I ran this command, I got a response too long message -
@mendelevium said in Thermisors showing wrong temperatures:
M98 P"config.g
When I ran this command, I got a response too long messagecheck the console page
the bed also registers a fault..When do they spike to 2000?
What fault did the bed give?
What does the heater graph look like?
@phaedrux
The temperature will read 12.9/13 for both and then shoot up to 2000 deg in a flash and return to 12.9/13 but the room ambient temp is 23 deg C. I have read that the daughterboard had an improvement with a capacitor. I had bought it original from Duet around 2 years ago. might be this? -
@mendelevium
Please note that I do not have a sensor daughterboard in place for the third heater. -
@mendelevium
Please note that I do not have a sensor daughterboard in place for the third heater.Does that mean you have a thermocouple connected directly to the board?
Can you post a photo of your board setup?
Are you getting any heater fault messages in the console?
@mendelevium
Could someone explain how I can choose the right sensor as the heatbed has an NTC 100K thermistor and not a thermocouple.
The hot ends have a thermocouple -
@mendelevium
The hot ends have a thermocoupleM308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C
@phaedrux
I have a max31856 daughterboard -
@phaedrux
No luck... the heatbed is connected to a MAX31856-based interface daughterboard. The headbed has an NTC 100k thermistor. Thank you. -
@phaedrux
No luck... the heatbed is connected to a MAX31856-based interface daughterboard. The headbed has an NTC 100k thermistor. Thank you.If the bed heater has a 100K thermistor then you should connect it to the bedtemp connector on the Duet, not to the daughter board. Your original line in config.g is nearly right:
except that B3950 is more likely to be a good match to the thermistor than B4138.
Edit: I just saw that @Phaedrux already gave you the correct config.g commands. But you still need to connect the thermistor to the bedtemp input, not the daughter board.
So the thermistor is plugged directly into the board while the thermocouples into the daughterboard right? -
So the thermistor is plugged directly into the board while the thermocouples into the daughterboard right?Yes, correct.
Thank you the bed sensor is working and reading a reasonable temperature
the hot end temperatures are not well... One is reading 2000deg all the time. The other spikes at 2000deg for a split second then goes to a low unrealistic temperature. -
Are you using extension wires on the thermocouples?
@phaedrux
yes of course but i have over 2 m of wireing. may try to connect a thermocouple directly and see the reading... -
Thermocouples can be very particular about their wiring.
https://duet3d.dozuki.com/Wiki/Connecting_thermocouples#Section_Troubleshooting
@phaedrux
I have fitted two 0.01microfarad capacitors on each channel to earth as I had found on the forum however everything remained the same. Now I connected a new thermocouple to the board which is not touching anything and the problem remains.
