Duet3D PCB delta printer effector sneak preview
The production PCBs and heatsinks are both blue. I have both fitted to my delta now
Did any beta tester experienced "ringing" due to the custom mounting with the sensor ?
This certainly seems the optimum delta configuration at present, nozzle contact sensor, linear rails, Haydn magnets, stiff effector and carriages (PCB/metal). About time for someone to blow it wide open with a radical new design I do like the Tevo Little Monster frame that's a nice idea, a lot of the rest of the stock machine is so so but the frame is a good idea.
I agree, I think it's state-of-the-art at this time.
I've not seen a Tevo Delta up close, but from the photos on their web site I wonder whether the base plate and top plate are sufficiently rigid to match the verticals.
do you know where haydn share his Machined Delrin Sockets file?
i would like to print some.
dc42: pleaaaaase take pictures -
There are pictures at https://duet3d.com/wiki/Smart_effector_and_carriage_adapters_for_delta_printer. These are of the second prototype, but the changes to the production effector are small.
looks brilliant.
quick editing error,
"Support for 2-wire thermistor, or 2- PT100 temperature sensor"should be "2-wire PT100"
Thanks, I've corrected that.
dc42: pleaaaaase take pictureshttps://www.youmagine.com/designs/magnetic-ball-joint-rod-ends
Any good?
The cbeams are fairly substantial 8040. If the end plates are stiff and precisely drilled, and the extrusions tapped for long bolts, I can't see it being a problem. Mounting rails is tricky as the mid point in the cbeam inner aspect is between two grooves in the extrusion. Double rail per tower has been proposed.
If I were going to rework the kossel Xl, which would be mad as it's printing brilliantly, I'm tempted to buy the cbeams which are cheap from china and have end plates water jet cut from thick aluminium. Maybe mount the rails on plates spanning the two inner slots.
I like the base plate / top plate idea but why not use 40x60 verticals instead and then you have a center groove to mount rails on.
It's too late for me to read through all of the comments.
This looks good, I do not fully understand why you did this, I think I remember something about it on your blog. No effector tilt is definitely appealing though, I also would like a camera or two (just to get a closer look or explore AI potential) or at least a light in the bottom that would look good when it's all enclosed in a heated chamber. ?
RGB? Haha I only care about white light there. Really like the no effector tilt though, mine isβ¦.significant. That's what I get for buying a cheap kit....
how do you see if you are tilt or not?when you move the head on corners with bubble level?
Yes you can see tilt on the spirit level, you can also (if you have an offset sensor, presume there is tilt, depending on the trigger height changing relative to the nozzle depending on where on the bed you are probing (this presumes the bed will not affect the sensor like the graphics on some build surfaces do to the IR sensor).
Another method is strapping a laser pointer to your effector firmly, then marking on the wall the dot from the laser, then move to anther coordinate (at the same z level) and see if the dot is still on the same horizontal plane.
Generally with linear rails, and high quality magnetic arm systems, plus stiff, precise effectors, there is little/no tilt measurable.
thanks you so much
dc42:any news about the price kit -
Any good?
thanks again djdemon
So, price? Availability?
yes dc42 we want to know
I am sure they will announce the details just as soon as they are ready there are lots of guys waiting patiently for them
