Duet 3 Mini 5+ : Initial announcement
@peter247 AFAIK we have now sent stock to both e3d and ooznest so hopefully they will restock soon!
Out of stock at both E3D and Ooznest. The latter said they weren't stocking them at the moment? Perhaps I missread their message: "This is not an item we carry at the moment I am afraid, we don't currently have an eta."
With the CAN bus and Raspberry Pi features weighing on the same class of processor as the Duet 2 is this likely to be a slightly lower ultimate performance - aside from the lower motor current?
Edit: Noticed that RAM and flash for the mini has doubled. Will this have any appreciable effect when it is running the same firmware?
@DocTrucker I checked our end and we are definitely supplying both E3D and Ooznest, just give us a chance to get them out the door!
The mini use a SAME5x processor which as you note has more flash and RAM than the SAM4E processor on the Duet2. They both feature floating point and a ARM4 core running at 120Mhz. Performance, where comparable, will be very similar. The mini has more headroom for future firmware features.
@T3P3Tony Thanks, I've been looking at the specs on the duet family page. Just seemed odd stock was sent on the 11th and out already on the 16th when they didn't appear to operate a queue or expression of interest system.
@DocTrucker yeah - my 11th post was overly optimistic!
@T3P3Tony Fair enough!
Hi team, do you have any information when ethernet board will be shipped to Europe?
I have ordered (and paid) mine on 10th of February and still have no ETA. -
@caviara who was the reseller?
@t3p3tony said in Duet 3 Mini 5+ : Initial announcement:
In order not to make bad commercial for the reseller i will reply on private to you.
@caviara thanks you can email info@duet3d.com
@T3P3Tony
Thank you a lot for help you provided with my case!
Also want to use this opportunity to thank all Duet team for your great work - best support ever from all of you -
What benefits have the Trinamic 2209 vs the duet 2 wifi steppers?
Seriously considering swapping over to the new board. (Because I'm bored and haven't modified my printer in at least a month) + I have loads of Pi's doing stuff in the household
@caviara said in Duet 3 Mini 5+ : Initial announcement:
As an average guy running a small business, I really appreciate that attitude. Keep it up!
@dc42 I bought one of the displays shown above with the two ribbons. I tried to get this work with my Duet Mini 3 5+ Wifi... but after plugging in it's just dead? I did add the gcode to the config. But it's still non responsive. Everything I see online is for the PanelDue... Any help David?
@thelightspeed Perhaps it would be best to start a new thread with our issue. Include as much detail as possible.
