Motors for duet 2 wifi
@mendelevium, can you provide a link to the datasheet for the motor, or at least its model number?
@mendelevium The stepper driver won't heat up, unless you use a current that is close to the maximum current the stepper driver can supply; with the Duet 2 WiFi, the maximum is 2.4A, and we recommend using a fan on the Duet if the motor current is set above 2.0A (see https://duet3d.dozuki.com/Wiki/Hardware_Overview#Section_Cooling). So setting the current to 0.8A is no problem.
If you run the motor at up to 80% of it's rated current, it's unlikely to get very warm. Stepper motors can usually put up with running at temperatures of 60C+ (it's operating temperature range will be in the motor spec sheet.), which is uncomfortable to the touch, and can start softening printed motor mounts, so generally 3D printers run the motor at a lower current than the maximum to keep it cool. As yours are rated at 1.2A (well within the stepper driver's limit, so no need for additional cooling), a current of 1.2 * 0.8 = 1A will be fine.
The input voltage is largely irrelevant, because the stepper driver is a current-sensing device. It controls the current by varying the voltage, and does this by checking the current it's sending, which is affected by the resistance of the motor. It calculates the resistance (eg 2.4 ohms is roughly the resistance per phase on a stock NEMA 17 motor), and has a target for current (eg 1.2A), so it supplies the voltage to the coil at the full step of V (voltage) = I (current) x R (resistance) = 2.88V. So most of the time the motors are actually getting quite a low voltage. As speed or load on the motor increases, so the voltage increases, as there is more resistance generated in the motor coils, so to keep the target current, the voltage increases. The motor itself will be able to take whatever voltage the stepper driver can supply, up to the point the motor is moving too fast, or there's too much load, at which the motor will skip steps. Other stepper motor parameters can affect this too, such as inductance. At least, this is how I understand it! You can see the stepper driver spec sheet here, which may explain it better: https://www.trinamic.com/products/integrated-circuits/details/tmc2660c-pa/
The advantage of using 24V over 12V is that you have more headroom, to run the motors faster. I also understand it makes the step rate 'snappier', because you have a larger 'reservoir' of voltage (but I'm not entirely sure about this explanation - someone said it to me a long time ago!). It's also worth having a play around with the EMF calculator at https://www.reprapfirmware.org/ to get a better understanding of what your motors are capable of, and what is the maximum speed you can, or should, achieve; because going very fast and then suddenly stopping creates a voltage spike, as the stepper motor becomes a generator, that goes back into the stepper driver, and may damage it.
Hope that helps!
sl42sth40-1204a
@droftarts Torque is a function of current, and current is a function of the inductance of the motor windings and supply voltage. With higher supply voltage, the current in the inductive windings rises faster than it does with lower supply voltage, so torque ramps up faster.
is your bed heavy ? what is the motor moving ? maybe you simply overloading the motor .
as others said , higher voltage will give you more torque at higher speeds . holding torque wont be effected . -
@mendelevium said in Motors for duet 2 wifi:
sl42sth40-1204a
I found the specification of those motors at https://a.allegroimg.com/s1024/0cc073/74223e8a4609b75257cfe7436eb5. As you said, the rated current is 1.2A. Their torque is quite low, so I suggest you run them at or near rated current. Try 1000mA.
You can estimate the maximum speed you can use before the motors get noisy using the motor EMF calculator that @droftarts linked to. It will be higher using 24V power than it is using 12V power.
@mrehorstdmd said in Motors for duet 2 wifi:
I knew there was a perfectly simple explanation! So the 'reservoir' analogy is kind of right. Just as well, as I think it was Dr/Prof/Sir Adrian Bowyer who told me that...
2 leadscrews connected together with a belt which IS 1.7 meters with various tensioners and guides.
Perhaps excess tension? Does the belt move easily by hand or is there a lot of resistance?
@Phaedrux
I wish to clarify some thing about my printer.
I have set the power to 1000. The Belts are not tight. Just tight enough.just to indicate my level of understanding on the matter, I own and run a CNC machine shop with various Vertical machining and turning centers/eroders/wire cut machines, programming and servicing for around 35 years.
This printer is one of two prototypes I designed and manufactured and spent much time with it. I wish to maybe market in the future. It is made entirely of metal,
This particular 3D printer runs reciprocating ball slides in X,Y and Z and I am prototyping running X and Y with reciprocating ball 12mm bal-lscrews. It has water cooling, twin extruders, and fully enclosed. Running it with a Duet is certainly a fitting suitable option.
The motors have to rotate faster and more with the balls-crews but certainly much stronger.
Yes the heat bed is a bit heavy as it is made from a 6mm machined frame and the bed is around 400 x 400 mm with a 3 mm borosilicate glass.
The extruders are custom made with a 1:3 reduction gearbox- spent around a year developing them.
The bottom line...
Now when I home- if I home at F100, the homing is smooth. Even movement is smooth, however on increasing the feed, like F500, there is noise and the motors vibrate... If I increase the feed like F1000, the motors will simply vibrate and whine and do not move.
I am thinking of switching to 24V and maybe go for the nema x 60mm larger motors. I can`t easily switch to an other type as it will involve extensive modifciations.
many thanks for your feedback.
Coming to ,
This printer is one of two prototypes I designed and manufactured and spent much time with it. I wish to maybe market in the future. It is made entirely of metal,I'm hearing you, I have a similar background to you. I've been a toolmaker for over 30 years, designed my own printers ect. I would try the 60mm Nema 17 first since it is easier to make that swap then going to a Nema 23.
But I will say that one of my printers has a 450mm bed with twin lead screws driven by a long belt with a single motor. The bed is .250" jig plate with a PEI surface so I don't have the added weight of the glass you have. I also run 4 start threads on my lead screws which give me 8mm of travel per revolution.I put a Nema 23 motor from the start and never had and issues with high speed Z travels. I home away from the head to Z max positive so I need the high speed travels to get the table up to the printing area after homing. As I said, I never had any issues with skipped steps of the bed not moving. I also don't have to worry with bed mesh leveling, once the plate is dialed in flat (at temp) it remains flat.
You may end up going to the larger Nema 23 stepper in the long run.
-edit- Almost forgot, I run all my printers on 24V, It's better overall on motor and hotend heater performance.
@timcurtis67
Nice....
I have just ordered two motors from smart steppers like you mentioned and hopefully will have them by mid next week. my printer has two separate power supplies as I have a 24 V heat-bed. The Bed and extruders are controlled via solid state relays and I am thinking of putting a mains supply heat-bed. My printer I have made available the possibility to run the bed by mains power and I am mulling dedicating the 24V power supply which used to power the bed to run the duet. I am still looking for some instructions or details how to construct the heat-bed using the silicone heat-pad. I have yet found nothing but have not looked much.The reciprocating ball screws have a small pitch like 5mm. One last little bit, I played around with mechaduino and managed to get motors tuned quite well. I have also tapped out the STEP AND DIR on the Duet wifi and managed to run them (this is closed loop) however for the moment I put ordinary steppers as i wish to finalize this asap....
many thanks for your bit.
@timcurtis67
I love the idea of one motor driving both screws and initially my printer had two motors and the system is not fool proof. You can have one motor skip steps... -
@mendelevium Can you post your config.g, or at least the part that has the motor configuration? I think you're just trying to run the Z axis too fast for the motors, or possibly you have the microstepping set too high. Generally, you do not need to move the Z very fast; F100 is 1.6mm/s, F500 is 8.3mm/s and F1000 is 16.6mm/s, which would be extraordinarily fast for Z! However, it does sound like the existing Z motors are not strong enough for the job.
@mendelevium I use a ac120 volt silicon pad stuck to the bottom of my bed. It is a 750 watt heater. The heater I run is similar to this one,https://www.amazon.com/approx-KEENOVO-Universal-Flexible-Silicone/dp/B00V81ZI70.
It heats up quickly. It is powered through an SSR controlled by the duet board.
If you go that route look into adding a thermal fuse inline to one of the power wires going directly to the bed heater. That way if the SSR ever fails you won't burn you house or business down. SSR's fail in the closed position which will keep your bed heater heating up even if the duet tries to shut it off. They come in different temp settings. Once they blow you have to replace them, as they can't be reset. Good cheap insurance.It has a built in thermistor which works fine. If you drill a small hole in the side of your bed plate you can add another thermistor in the small hole and get a better overall temp reading of the bed.
Also buy a good SSR, not a cheap Chinese knockoff. I've been set up this way for several years on my large printer. It runs almost 24/7 everyday cranking out parts.
Your printers sound nice, post some pictures when you get them running.
@droftarts said in Motors for duet 2 wifi:
On larger printers we need faster Z drives. If I home my printer to Z positive (Z +465.00) then start a print it would take over 4 minutes for the table to move up into print position at F100 (1.6mm a second). I typically move my Z at 1200-1500. Works well for Z hops too. I don't add too much time to my prints z hopping during retracts.
Or maybe I just need more patience
@timcurtis67 That's understandable. But you've probably got something bigger than a 1.2A NEMA 17 driving it!
i do not have that in hand now but will post it, however I have not been very clear..
"Now when I home- if I home at F100, the homing is smooth. Even movement is smooth, however on increasing the feed, like F500, there is noise and the motors vibrate... If I increase the feed like F1000, the motors will simply vibrate and whine and do not move."The homing feed is F100.
What I referred above is the movement of the X and Y axis...
G1 XXXX F500, there is noise and the motors vibrate... If I increase the feed like F1000, the motors will simply vibrate and whine and do not movehope I have explained myself better.
@timcurtis67
What did you do for the heat-bed? Aluminum plate? I am a bit concerned about the possibility of warping with the heat pad under the plate and losing the flatness... -
Two likely reasons:
You have set the acceleration too high in the M201 command.
The combination of steps/mm of your machine, motor choice and supply voltage means there is insufficient supply voltage to drive the motor that fast. However, F1000 is a low speed, so that should only be the case if either your machine has a very high steps/mm value, or the motors have high inductance. Use the EMF calculator at https://www.reprapfirmware.org/ to check.
Definitely change to 24V power then.
my extruders/ Water cooling/ hot end ![2_1615555696051_160480591_174566437831827_872159458352239571_n.jpg](Uploading 100%) ![1_1615555696051_160220999_849863792229384_3326401001603109912_n.jpg](Uploading 100%) ![0_1615555696051_160103537_3967567926635363_6334736638490467259_n.jpg](Uploading 100%)
