PanelDue Image Display
@bot, that would be entirely doable.
Cool! The PrusaSlicer fork SuperSlicer has added the functionality to put the thumbnail on non-mini printer profiles. Perhaps a different resolution is possible, as well. We could check the PrusaSlicer/SuperSlicer source.
If another resolution is possible, what would be ideal for the paneldue? I guess we should ensure the smallest paneldues can see the thumbnails. This could be included into the "RepRapFirmware" G-Code flavour that is seemingly soon to be added to PrusaSlicer.
Perhaps DWC could grab these tumbnails, too.
Very nice. +1
Do you have a link to the specification for the image encoding?
I do not think any public documentation of this exists, but here is the first most obvious reference to it that I can find in the source:
Prusa3D/PrusaSlicer/src/libslic3r/GCode.cpp#L981
static void export_thumbnails_to_file(ThumbnailsGeneratorCallback &thumbnail_cb, const std::vector<Vec2d> &sizes, WriteToOutput output, ThrowIfCanceledCallback throw_if_canceled) { // Write thumbnails using base64 encoding if (thumbnail_cb != nullptr) { const size_t max_row_length = 78; ThumbnailsList thumbnails; thumbnail_cb(thumbnails, sizes, true, true, true, true); for (const ThumbnailData& data : thumbnails) { if (data.is_valid()) { size_t png_size = 0; void* png_data = tdefl_write_image_to_png_file_in_memory_ex((const void*)data.pixels.data(), data.width, data.height, 4, &png_size, MZ_DEFAULT_LEVEL, 1); if (png_data != nullptr) { std::string encoded; encoded.resize(boost::beast::detail::base64::encoded_size(png_size)); encoded.resize(boost::beast::detail::base64::encode((void*)&encoded[0], (const void*)png_data, png_size)); output((boost::format("\n;\n; thumbnail begin %dx%d %d\n") % data.width % data.height % encoded.size()).str().c_str()); unsigned int row_count = 0; while (encoded.size() > max_row_length) { output((boost::format("; %s\n") % encoded.substr(0, max_row_length)).str().c_str()); encoded = encoded.substr(max_row_length); ++row_count; } if (encoded.size() > 0) output((boost::format("; %s\n") % encoded).str().c_str()); output("; thumbnail end\n;\n"); mz_free(png_data); } } throw_if_canceled(); } } }
So the thumbnail seems to be encoded in 'base64' by the boost library. The start of the thumbnail says
; thumbnail begin
followed by the pixel resolution and the encoded size. I suppose it's an encoding of a PNG file of some format. -
@dc42 I found this website which can directly decode the image that I posted above, which was merely an example I found on the internet from someone's publicly posted gcode.
https://base64.guru/converter/decode/image/png
Encoded PNG with added information removed:
iVBORw0KGgoAAAANSUhEUgAAANwAAAB8CAYAAAACRt5vAAAJPElEQVR4Ae2d2ZoTVRSF60FsWiFewP dxi4iI2iL3voIiIorzPADP5ouFTneHLkINZ9jD2uesi32TpM5ZWbX+pFKpU3vYbDbXD+vGjRsn+5p6 XqKk57DQHFU3vcbxeljbSEOcxviHY0bVTc16+xLB68FaHAM2P/7/T25vNYpe4+R6sBKobaTWXFq6te BKrZ681pwrd5xBY1BPI6Xm1Tis8YZMC75aryLmo3T7oXTwlAk0QmthiqRmVMg04PP2WkKzdq6Tgcs1 yNvIEoMkPyAiQSYJnofXGhmpfd1cZQOXYhaSkam6CJoueBpee+ajVHcRcEsiEI1cM1VCdySIrMDT8t o6I5Kaq4Abi7t58+bn6EYe6t5pHusuGScSNJ7gRcyHhm4CVwFcJFA8oWslH+7AtXBIeWhoiu5IcHiC t5YPHlJWCEp5Ds3I1OcIWz50El5750Mj1138LZCqZ+01kUDwhE7Ca8R8SOjOAi53MgRTSzRMbRMJAC /opLxGz0iNZl7albBtpOB7loTXUfJRun0XFy+XzkfYyqDz3GfWecwdJ3l5joQBFqZKjh8p6EiFsv8Q c80FqIQNHjqtjEiMmTv+YC1KYx5pzZGC3Sp06BkpnWewFiRthIbuSKFuGTjUfNTMO3iKqjFFS3OkQP cCHVpGajQP3qLmxC1pIWyELicfSLkevAXlmKptZKQQ9whcSgZQQJvTPSCJWjLVwshIIe4VOO+M1Goe NpvNddTaG2extCNSgAmdfT6kCh44iUWiBK5N4MYZIXACRlodLkQKLqGzz4cocOgnTcbaeHaSwC3lAB m8N85SIohLMUvD1Eih7Rm41H2PBt3k3wLeAnM1SGqOFNpegfPMh5Tm185SegmsmVdKc6TQ9ggcQkak NA+e4qTmqx0nUmh7Ag4lH5LzQSzPkZijZrxIoe0FOO18WOR66jVN9YcrNTVSaFsHThsM71wPVm/e4h Om1NRIoW0ZOK98WOa62ZsI5RgRKbQtAmf5Yeyd6+L+cFZvysLUSKFtDbgI+ZDcrsv+cAQOA7hIGZHS LHKrc2lR1qZGCm0LwEXLh6Tu4ouXp467vY7Fa0199tkmVHAj1te3j4rvzuyZD+lcd9muaqx5VwTOBj h02CxyLbI8R6OPloWhBM4PuEj5kNTcXX+4Q9174J4TOrV6/P6VUN9wmrkW+w239jiikfvHCZwNcJEz 4vYbLpV4NFOX9OyBe/GA0GnAdghctHzkZl8MuNzJEExNMWkM3IsH74YKdATYpoBL3TcosNW8Phu4Gm M8TU2dl8D5AJe7n7TzYZHrJvvD5c53CByhq69vRrCtAYeeD8lxBsnBrN6k9BxTwPH3XB1sucChZ0Rq vGb6w9WMS+BwgEPMh+T4TfaHyx1vDrjnhK4YthrgJPYpaq4HrTdoZaqE5iXg+P9cej0ewVYLnNT+Rc t1M/3hanSvAUfo0mDTAK5mXyPmmv3hEoF7dlGRILAETRO43P3u8a2WqiVUf7iU57WB++8+oZuDTRs4 r3xI6g7RH27uManKBY7Q7a7+v+ICnFdGpDSzP1whcP/ev7b959NroSCRAe3oDDZv4CzzIVnsD1cJXE /QncOGA9yuoq3FDNEf7tBQhEPKMXB/n9ZfJ+2C9+gUlkevYMMAburESATo4E6aTJm59jgKcH+eXD2r SDAt1VfvHZ0VGnDW+ZDUHL4/nMS80sD98cnV7e+n9dvH8eB7eOto+/ACNETgvDIipRn2fzjp13sBty 900L689dZZoQLnmQ9J3XD94XLmltJsAdxlvXNW3oDtQNqBtYPsiwvYUIGTyodnrvePh+8PJ2GqB3D7 +nVXH+kDeB768+Dv4IkAnBQwSLleXS2gIVBjjprxEIAb1y+j+vneea0B9fTu8fbpB8fb7y7q2zvH2y d3ToN/5zL8kYDTzodXrpvuD9cScD/de/usfvzwsn44re/v7uq4KeAQMyI1bnMrvkvmIXAYwKHmQ3K8 bvrDEThs4NAzIrV90/3hUo/bCZwfcKn7CA260u2q7ku5NJG3kTnmEDgf4FDzoZnrbvrDLRlF4GyBQ/ owts51V70F5vQRODvgIuZDUnfX/eH2ugmcDXDosFnkWqU/nJUptYaO+8MROFvgImQEuj+c9po1adj4 DcdvOI9cd90fjr/h/H/DoWdk7XET4HLP5iCYuqSHwNn/LYCej5RcqwOXOyGKqWs6CBz/h7PKdVdXms y9jsD5XtoVISNS22X3hys1xNrUnPkIXH/XUmpkOmWc5vvDpcxD4DBXC1hlxHK8pP5wkm/ccuzU7Qhc H+vhEHLdRH+42vEIXH8rvmvHK52nuXualIxB4HBvIoSSEan5wvaHk9RN4Pq4a1fp/JK6Q96XUvpYnM BhA1eyz1FzDX3n5SlNGkYSOHzgUve/9IextOaw/eEkdRO4OMAtZQENtCndIbvnSM9F4GIBd5iRSCtV oPvD7SpCfzgC5wOcVT66AI7fcAQuJyNhvuGi/IZbepzA9f0bTjsfkrp5lpLA8SylYa75PxyB4/9whr keNAKsCZvEdgSOV5pYZ3o/P6+lJHC8ltIw11wtcFEEThe46PmQmse9P5zm2AQuJnAtZ48rvkdF4HSA s9h3njnMGc/kniZWRtaaSuD8gPPOh1Wu2R+OwLkC5/Fh7Jlr3pfyDegInCRwreWjVne3/eGWXkPgZI BL8TpSRiQ0sz/cxGMETha4Ja8j5ENSN7vnzKxEIHB1wM0FNXo+anV32x9ur3lJN4ErA24tH9EyIqlZ rQNq9G+4V9ARuCzglrxuMR9mwGkf61qYmfq7gsClASfhNWI+JHXzLGXiawjcMnCSXqNmREJz1f9wa5 OimCqlmcBNA6fhdZR85OrmlSaZ2xG414HT9BoNNontBs3BPU2VmG8JOgI3D5vX/rLOZMn2za0WkJ5n aaxegfPwGjUfueO5r4eTGtdr7N6Aa3U/Wo27uuJb65Mm4rfn0hytA4fkdZR8TM3T3D1NtHWvzdcacM heW+ZMaj73u3bVzO2lOWXu6MBF8lojW1q5DnlfypLXW5o6rmjAlbxH5iNdB/Sdl0tfg6obFbgWvUbN NXsLOGn2Bq4nr5F0h+yeg2jm3E7P0awFXI3XEX1G1g3dH24fgKhr7SIEgF7bFnxDxsNPXXS9UTXTa5 t6CT7Sg5eV9vIgAAAAAElFTkSuQmCC
Produces this image:
Note that the background uses alpha transparency.
Support for the thumbnail included by PrusaSlicer is planned for the version PanelDueFirmware 3.3 (i.e. after the current 3.2 is finished).
@wilriker FYI the newest versions of PrusaSlicer include the ability to embed a thumbnail of an arbitrary size. No modifications necessary to get a thumbnail encoded now.
I was looking into this for the past week and unfortunately I have to report failure to get it done. The problem is that we just have way to few RAM available on PanelDue. Maybe in future version of PanelDue with much more RAM this could be done for but for now it is technically impossible.
@wilriker Unfortunately that makes sense. Thanks for looking into it.
If we're just "together"
I would like to see the current pinting speed on PanelDue.
undefined mfs12 referenced this topic
