Bug in 3.2.2: X/Y/Z positioning wrong in DWC and PanelDue
I think you should enter a request in the firmware wish list section to have the DWC and PanelDue be able to display the command that is currently being executed. I don't think that information is now available for display.
It also might be possible to have the firmware feed the DWC/PanelDue the actual current position rather than the target position as specified in the command - would that be of beneifit?
@fcwilt said in Bug in 3.2.2: X/Y/Z positioning wrong in DWC and PanelDue:
This thread has nothing whatsoever to do with displaying "the command that is currently being executed." It's only about what is displayed as the "tool position."
Your statement erroneously implies that DWC/PanelDue is displaying the target position of the currently executing command. It IS NOT. That's what this bug report is about.
@fcwilt So far, your involvement in this thread has been more harmful than helpful. Instead of contributing to the report or showing that there is no bug, all you've done is to dilute the thread with false statements and wild geese. Please go away.
@garyd9 said in Bug in 3.2.2: X/Y/Z positioning wrong in DWC and PanelDue:
You are wrong so I will let you carry on believing things that are not true.
So says the person who trolls a thread without even bothering to repeat the issue reported.
I know why the DWC/PanelDue shows what it shows.
You don't like it and I agree there is a better way.
You just need to post your request to the firmware wish list.
It's as simple as that.
@garyd9 The reason why the positions are slightly off is because the OM reports the user/machine positions of the last processed move, which are usually needed in macro files when using conditional G-code and expressions. But I understand this may be a bit counter-intuitive and we may replace it with actual "live" values at some point, but @dc42 and I have not yet decided when and how in detail.
Btw you can click on "Tool Position" on the web interface to change to the machine positions.
@chrishamm said in Bug in 3.2.2: X/Y/Z positioning wrong in DWC and PanelDue:
I can completely understand why the userPosition is desired for running macro's. I'm not sure how that relates to what is displayed by DWC as "Tool Position."
Compare it to medical equipment and take it to an extreme: If you were are on a device that monitors your heart beat, you might expect to see a number such as 75bpm. What if the monitor instead displayed 0? Would you be happy with the explanation of "well, it's showing what your heartbeat WILL be... and we all die eventually."
Perhaps a bit less of an extreme, the altimeter of an airplane: It would make flying the plane much harder if the plane's instruments reflected the planes projected state instead of it's actual physical state.
Of course, now that you've told me switching to machinePosition is as trivial as a click, I might not care. I wonder if @wilriker would be willing to add a similar toggle to PanelDue.
@LB
I don't understand what you are posting/suggesting. -
I intend to provide this possibility but due to the limited screen estate I have to carefully work out where I can make space for a button or similar.
