7x ClearPath SD motors
Re: Clearpath Servo Motors and Step/Dir/Enable Pin Avaiability
Hi!
is it possible to use a PanelDue on CONN_SDCARD
and simulaneously use the two STEP/DIR channels on CONN_LCD ?
Forgive the quick sketch ... Thinking about a breakout board like so.
@djstree said in 7x ClearPath SD motors:
Hi!
Yes.
Those NL37WZ16 buffers have very nice output drive characteristics. Unfortunately they specify a minimum Vih of 0.7V * Vcc, which at VCC=5 is 3.5V. That's more than the 3.3V nominal (and possibly as low as 3.2V) provided on the expansion board connector.
@dc42 good spot, thanks.. I'll find another part.
If you feed +5V and IN- to the Clearpath input instead of IN+ and ground, then you could perhaps use SN74LVC06A powered from +3.3V.
Something along these lines? Agains, sorry for the sketch. I'm on the tablet!
Yes, that's what I had in mind.
Along with some other I/O conns ...
This post is deleted!
