IDEX CoreXY, With Only 2 Motors.
Very clever thinking there.
I have a Mark Forged style printer and I found it necessary to have two Y steppers to control the racking of the X gantry.
If it were me I would just use use two X steppers.
@fcwilt thanks! Interesting you mention that, it did cross my mind but I didn't give it much attention. The Voron appears to have a pretty tightly build gantry, but they are only MGN9 rails. Its a very good point, I think I will need to test it out.
@RichardDuke said in IDEX CoreXY, With Only 2 Motors.:
Isn't the Voron a CoreXY?
One of the goals of the CoreXY design was to minimize racking.
I like the MarkForged design because the belt paths are shorter and simpler - the price is one extra stepper.
And not many folks seem to have one - I like being different.
@RichardDuke
I think, racking won't be an issue the way you guide the belts.
I've played around with a "dual roller constraint" which works the same way.
A short video how it works.
It's common practice in big CNC machines by the way.I've built a simple XY-penplotter with only one rail for the Y-axis and used this method to avoid racking.
You can see the green string here and a hint of the rollers (which are the belt idle rollers in your case)IMHO the result speaks for itself.
Why don't you build a toolchanger while you are at it? Your idea already basically is one, only the tool stays on the X carriage when parked ....
The kinematics of this directly correspond to that of Markforged, except at every toolchange, both X and Y motor logic is swapped and reversed.
Is it possible to do the swap during a tool change? What does the firmware do in that case? There are some restrictions to the stepper parameters, IMHO some require a reboot? @Phaedrux ??
I guess the main idea behind this was to try implement indipendent dual extrusion to an existing platform without heavily modifying the original design. If it works, it would potentially be possible to a second carriage to just about any CoreXY printer.
@fcwilt yes the Voron is a CoreXY, designed for minimal racking, but with this modification the racking could become an issue as the gantry would now be pulled in the Y direction from opposite ends of the rail. It could potentiality be overcome with alternative belt routing, but that will require a design overhaul, in which case id probably look to just add an extra motor and belt anyway
@oliof a toolchanger could be an option, the coupling of the tools sound like it could be challenging though. Id probably look to retrofit the e3d carriage and park the tools off the gantry though.
@o_lampe I have had a conversation with Tony from Duet who doesn't think there will be an issue, but we will cross that path later.
I wish you hadn't put the idea in my head of converting my MarkForged style printer into a IDEX unit.
Like I don't already have enough projects!
Fredereick
@fcwilt you and me both! I haven't even finished tuning my recent Cartesian IDEX build and I'm already looking for something else!
I disagree.
The B-belt is passive during Y-moves, but it is still there and it's tension makes all the difference.
Both ends of the crossbar are wrapped in belts, that's important for the constraint.My CoreXY is easy to modify with your idea. I'll print a second carrier-dummy and try it out today.
I could need some help with the kinematic-matrix. -
@ all
what would be a good testprint to show (the absence off) racking? -
Just to chime in on the alleged h-bot racking -- that all seems to go back to an old Hackaday posting where the author later admitted to using low quality belts and self-made cantilevered pulleys. I am poised to assume the claims about h-bot being terrible are a bit overblown in practice.
@oliof of course it is .
many industrial motion systems use h bot . startasys used hbot in their printers . it all depends how rigid your design is . -
In this special case it's the equal belt tension that keeps the crossbar in line. Also the tension shouldn't be too low.
Here's a little teaser of the dummy U-carrier waiting to be connected and mapped.
It's an IDEY CoreXY BTW...just in case someone has a clue how to run this.
I found this in the wiki, but there is also a K11=MarkForge type of kinematics, but no further explanation. I guess it's trial&error time , as usual...
CoreXY with extra Markforge U axis (see https://forum.duet3d.com/post/136554 ) M669 K1 X1:1:0:0 Y1:-1:0:-1 Z0:0:1:0 U0:0:0:1
@RichardDuke
It's alive
The kinematic is the same as MarkForge (M669 K11) but I had to modify it, because my crossbeam is the Y-axis.
I've called it simple-IDEX or s-idex and linked the video to this thread.
Here's a short video with a fixed dummy U-axis.
Next I'll fix the Y-axis and work on the reversed kinematic. -
@o_lampe said in IDEX CoreXY, With Only 2 Motors.:
Nothing requires a reboot to configure. Everything can be done on the fly. The only reason DWC suggests a reboot after changing config.g is so that your changes can be applied. Could also be accomplished by sending M98 P"config.g" to execute the file as a macro.
Some changes may have a quality impact if executed during a print, but if done stationary no problems should arise.
@RichardDuke
It's alive
Next I'll fix the Y-axis and work on the reversed kinematic.Soooooo..... that is awesome! You're a superstar for testing this out! What an wicked post to wake up too.
I guess I am going to have to start ordering some parts and join in on the SIDEX action!
@RichardDuke
Goooooood MORNING!
I thought about the name of the new born baby, maybe locked IDEX describes it better?
I also have found a way to include the lock and a small servo to my X-carriers. Will photoshop the idea for all of us to discuss.I printed two things yesterday, expecting to see more overshooting at the corners, where the single belt has to catch all the moving mass, but a test cube was practically identical to a formerly printed one.
The second doesn't show any signs of difference, but I'll inspect it again in bright sunlight today. Still unsure how racking would show? Lost steps and screeching carriers?The only downside is, I was so proud about the small frame with regards to the print area, but now the second carrier eats up a lot of space. Maybe I have to order a few longer 2040 extrusions and reassemble the whole frame.
