Error: bad Command XXX W/RRF 3.2 and leveling issue
@3DPrintingWorld said in Error: bad Command XXX W/RRF 3.2 and leveling issue:
Note that the U axis switch is connected to the Z axis endstop port.
From your config you posted earlier it seems the U axis endstop is "duex.e2stop" and "zstop" is one of the Y axis endstops.
Did you mean the U side endstop of the Y axis? -
@Guillaume-G Sorry, yes that is correct. I also noticed that I also get the error when selecting "upload and start". I need to try to catch a recording on it so I can better tell what is going on. At this time the axis splits and rejoins to home the Y so its hard to tell when exactly it happens.
I also noticed If I don't stop it; it crashes, skips steps, gives the error, but then continues to home the Z like nothing is wrong.
@3DPrintingWorld Time to try my sensorless Y homing sequence
In both config.g and homeall.g the comments about Y drives say that drive 1 is right and 2 is left.
However the separated Y homing expects "zstop" when driving the left motor, which I would call X side, not U side:M584 Y2 ; Y-axis Left side M574 Y2 S1 P"zstop" ; Y-axis left side endstop Active
Also, from this page:
"Any M584 commands used to remap drivers must come before M350 and M906 commands. M584 commands that create new axes must also come before the M92, M201, M203, M208 and M566 that set parameters for those axes."As you remap Y drives with M584 in homeall.g, you should maybe redefine the mentionned settings for the Y axis after that.
Not sure of anything here, just looking around the Y homing process because you can repeat faults there.
@Guillaume-G You know I want to use your senseless homing, I just cant seem to get to anything I want to do as I'm spending all time on this.
Wow, I don't know how you caught that typo, my config is going to be squeaky clean with your help. It still might not level but there wont be anything out of place. P1 should have been left motor, and P2 right. I was sitting behind the printer when I typed it.....
So you are saying that I should redefine M350, M906, M92, M201, M203, and M208 for the Y axis all in homeall after M584 that brings drive 1&2 back together? That seems so sloppy to have it two places. I saw this rule previously but thought it only applied to the config file.
No, it only needs to be defined once in config.g if it's creating an axis. If you modify a parameter of that axis later on, you only need to return that changed value back to it's original state.
If you're changing the driver of the Y axis, the other values used for the axis will still be applied as they are tied to the axis, not the driver.
Hope that makes sense.
@martin7404 Instead of two bearings, what about a option to upgrade to the wide series, mgw9h. This should reduce the tilt, and would result in less binding then two bearings mounted on different planes would.
So fo MGW9H I got 150 EUR with 5 days delivery rail and 2 blocks> For MGN9H with Z1 preload they have in stock about 100 EUR for set rail and 2 blocks
Lol that makes much sense!
I assume it is then running the the start Gcode from the slicer. Does it just call G28, so homeall.g, or does it call single axes homing macros for instance with G28 Y, G28 XU... Asking because only homeall.g is posted here for review.
Thanks @Phaedrux for correcting my wrong assumptions!
@Guillaume-G said in Error: bad Command XXX W/RRF 3.2 and leveling issue:
I call the G28 in the start script. My plan at first was to call them individually, but that way you cant start homing X and U at the same time.
@martin7404 said in Error: bad Command XXX W/RRF 3.2 and leveling issue:
So you are going to try them both?
@3DPrintingWorld for now MGN9 with preload if the paly is not present I will stop there, printing my 3 mm rised toolplate now
It's a trade off - optimizing homing versus code simplicity.
My homeALL.g has always gone for simplicity:
M98 P"homeZ.g" M98 P"homeX.g" M98 P"homeY.g"
At first I went the more "traditional" route of having actual homing code in homeALL.g.
But then as I considered the ratio of time spent homing and time spent printing the potential for optimization was discarded in favor of code simplicity.
Your mileage may vary.
@fcwilt At one point I tried that but I went back to having everything in the homeall because it really does save some time, epically considering that this printer has an additional U axis. It is really nice and clean though, maybe I'll revisit it once I get this mess figured out.
I wonder why no-one replied about the fact that you get a different behaviour when starting from power off or when rebooting after loading config.g.
Same thing about the upload and print function which causes crashes.
I would have thought these hints would point towards a limited number of possible causes.
I imagine some config detail could sometimes be overwritten depending on the sequence the config files or macro are loaded...I thought about something else:
We have a difference in our M669 (kinematics type config).
You haveM669 K0 Y1:-1:0:1
As I didn't really understand why there was a minus sign regarding Y to Y reaction, I didn't go for it and used this instead:
M669 K0 Y1:1:0:1
I think the only other implication is that I need to have my Y motor directions reversed compared to yours in the M569 statements.
Speaking about it here in case the negative sign in M669 would be causing your issues somehow.
@3DPrintingWorld I think we've hit the point where this thread is too sprawling to follow closely. IF you're still having some issues, please start a new thread with a summary of details and all the configs etc.
Might be a good idea to make a tread like "Duet wifi on MULDEX printer "
What you think ? -
@Guillaume-G
I fail to understand the logic in M669 -
@martin7404
Yes I took me some time to understand the matrix concept the M669 description refers to.I use
M669 K0 Y1:1:0:1
K0 is for Cartesian
The rest is about which axis interacts with which.On the Muldex, Y movement causes X and U to move with a ratio of 1 and the other axes movements are considered independent.
This should speak better than words:
@Guillaume-G Thank you Now I understand
I did not understand the logic either. I found it defined on the forum somewhere but it did not work for me as written so I swamped the numbers around until it worked... I was hoping that I was not going to have to admit that.
@Guillaume-G Thanks for that, I studied the documentation for a while but could not understand it, now I do. I'll remove the negative.
