Ringing on prints
While printing, are the hot end and bed temperatures flat in the temperature graph displayed by DWC, or are there is oscillations?
print 2 cylinders (like you did in your images) while one is twice in diameter .
compare the pitch distance on both cylinders .
if its the same - you have problem with your leadscrews , probably one of them bent .if the pitch is different for the larger cylinder then you have temp / extruder issue .
@Phaedrux @dc42 said in Ringing on prints:
My heated bed is a 24v version that runs directly from the Duet 2 wifi board and when looking at the DWC as it is heating up on the graph it climbs up to the commanded temperature has a very slight deviation at the end where it overshoots by a few degrees then levels out nice and flat and both the hotend and bed stay flat whilst printing.
I will do 2 cylinders to see what is happening as suggested later.
This is how they look and to me they look exactly the same.
The small cylinder is 20mm which when measured using digital calipers measured 19.85 - 19.77 when being rotated and the 40mm cylinder measured 39.59 - 39.66 so they are very similar in measured dimensions with the variations. I have done all the axis calibration and the extruder calibration before this started to happen. But does this mean I need to redo the calibrations again ? Or could this be something else that is throwing the prints out ?
One thing I did notice when I was running this print is that it does seem to pause at the end of each layer for a moment unlike my Sidewinder X1 which is almost completely seamless with movements as it is printing.
i think your slicing settings are way off .
what slicer are you using ? -
@hackinistrator said in Ringing on prints:
what slicer are you using ?Simplify3D.
I remember having similar quality issues on my hevo back in the day.
I can't remember what exactly fixed the problem, but first thing I did was to check my belt tension and replaced my belts (I used those white reinforced belts, which was a big nono).Then I made sure they were tight, but not so tight you can't really push them out and more importantly - they have to be equal length (down to the tooth) and equal tension.
Then I made sure prints were square (using a calibration slat) and finally, I made sure the extruder was calibrated and also the filament itself (things like extrusion multiplier, pressure advance, destring).
And then, the printer started printing amazingly well
Maybe one of these hints will help you if you haven't done them yet.
Just in case, here are the tools I used:
https://www.thingiverse.com/thing:3306430
https://www.thingiverse.com/thing:3993559 -
@RAM
Can you share your factory file please -
@hackinistrator here is the S3D printer profile I have.
S3D Hypercube Profile@pkos thanks for the suggestions. I cant work out what it is. I have checked the belt tensions and I am not using them reinforced white belts with metal strands as I had read that they give problems.
I have even gone back over the mounting points to make sure that nothing had come loose and that the idler pulleys were all freely spinning to the point I even printed new idler pulley mounts and changed them over.
only thing I haven't done yet on the calibration things that you mentioned is the pressure advance tuning and the calibration slat.
I will try the calibration Slat but I am still trying to get my head around the pressure advance tuning thing before I even attempt it.
Right, then first make sure you do the slat - that makes sure you are printing square.
Then, do extruder calibration, extrusion calibration and only once you have that - then attempt PA If you have a direct drive, PA won't help much.
I slightly changed your profile , can you test it ?
(rename file to .fff instead of txt)
please print the cylinders one at a time , not both at the same time .for some reason your speed is set very slow at 20mm/s , why ?
i changed it to 45mm/s and reduced acceleration , if you have some kind of issues . if its a problem set speed back to 20mm/s
other changes should not effect your printer . the profile seems very old. -
@hackinistrator Oh damn it exported the TPU testing profile I was setting up and not the PLA. Sorry that was my fault I didn't realise it had done that.
If you would prefer to look at how the PLA profile is for the printer it is here.
what makes you say the profile is old ?
are you using the latest s3d version ? (they didnt update in years and probably dead , but still your profile config looks like it was created before the latest version)
if you have time try my profile for single cylinder .
@hackinistrator yep I am using v4.1.2 which is the latest. I am more than happy to try a different slicer even though I am not familiar with other slicers. I did used to use Cura years ago when I 1st got my Hictop in clone but ended switching over to Simplify3D as I found I was getting better prints using it.
I am doing the 20mm cylinder now and I will do the 40mm after to see what the difference is. So far it is looking really good. Haven't a clue what you changed but it seems to be doing the trick so far. Fingers crossed and it will have solved the issue.
@hackinistrator whatever you changed seems to have worked wonders. I will delete the other profile and run with what you have done for me.
Only thing that I would like to do is try and minimise the seam line a bit more but if that is all I have to contend with I will gladly put up with that.
If you have any other suggestions to improve it further I would be very grateful.
Give Prusaslicer a go. I’ve moved to it from Cura and I’m impressed with it
i set very conservative acceleration and jerk setting in the profile i sent you (i thought you are limited to 20mm/s from your original profile) . in S3d those values are under post processing script , as this 150$ software didn't add simple acceleration and jerk settings
i also think you should move away from s3d as they are going nowhere it seems .
for easy transition you can try ideamaker .as much as i hate S3D as a company , i still find it useful for multi process and sequential printing .other then that , prusaslicer , ideamaker and cura , all of them much better now .
@hackinistrator yea the original was a TPU profile I was setting up but I didn't realise I had exported that profile, I will use what you sent me as it is so much nicer and seems to have removed that pause as well at the end of each move.
I will have a go using your settings but upping the printing speed to 70mms and also try prusa slicer and see how I get on with it.
I know Simplify3D were meant to be releasing a v5 but I am not paying again to do the upgrade and by the looks of it, the Prusa Community for the Slicer is really powering the slicer forward.
