3.2 SBC cancel print not working w/ missing/blank cancel.g
This post is deleted! -
Is the same with empty cancel.g
Do you have a
T0
command in your slicer start gcode?
Is your tool still selected after canceling?
Can you try putting some commands in your cancel.g?Example:
; cancel.g ; ; Run when the print is paused, and then canceled. ; G10 P0 R0 S0 ; Set hotend temp to 0 M140 S0 ; Set bed temp to 0 M106 S255 ; Fan at 100 to cool nozzle and bed M220 S100 ; Set speed factor back to 100% in case it was changed M221 S100 ; Set extrusion factor back to 100% in case it was changed M290 R0 S0 ; clear babystepping G28 XY ; home XY M84 ; turn off steppers G4 S60 ; wait 1 minute for nozzle to cool M107 ; turn off the fan
Now is working with this config.
Can you tell me why?
@Heartleander81 said in Problem after cancel print:
What config? Did you mean to post one?
@fcwilt i mean the config post from phaedrux
You mean you added those commands to cancel.g?
I'm thinking there is an issue with missing or blank cancel.g files and the firmware isn't doing the expected default behaviour.
Thanks for confirming that adding a cancel.g with commands allows it to work. I'll flag this for further investigation.
@Phaedrux I doun't now why, but on second test, the same bevore. I test at saturday more cycles. I think the problem is at my side.
I give you Feedback at saturday night ore sunday morning. -
@Phaedrux
Thanks for your help. But i doun't find out what is. I have downgraded to 3.1.1When the next 3.2.x stabel comes out i test it.
I found the mistake. It was the slicer. I accidentally swapped relative and absolute extrusion. As a result, the skirt was still printed and nothing came out of the nozzle during the actual printing
Thanks for the update.
