Solved 3.2 SBC cancel print not working w/ missing/blank cancel.g
@Heartleander81 said in Problem after cancel print:
If I have to cancel a print and start this or another, the extruder no longer feeds filament.
Only when I reboot the Raspberry Pi 4 does the pressure go back to normal.Can you try describing again what exactly this means? I'm having a hard time understanding the problem.
Does the printer try to resume the print but the extruder motor doesn't turn?
Does it just sit there?
Is the heater at temp at that point?
@Phaedrux
I start a print.
For example, a component comes loose.
Then press pause and release the pressure.
Change something on the slice or try to reprint.
Then nothing is extruded during printing.
When I restart the Pi, it prints normally.
But today I was able to determine that this problem also occurred even after a successful print. That's only since the update from 3.1.1 to 3.2.0After Bed and Nozzle is on temp make my Printer Homing.
Sorry. Fu.. Translator. I doun't have check before copy and past.PRESS pause and then cancel i the print
I have a Video on youtube
Did you try creating the missing cancel.g?
This post is deleted! -
Is the same with empty cancel.g
Do you have a
T0
command in your slicer start gcode?
Is your tool still selected after canceling?
Can you try putting some commands in your cancel.g?Example:
; cancel.g ; ; Run when the print is paused, and then canceled. ; G10 P0 R0 S0 ; Set hotend temp to 0 M140 S0 ; Set bed temp to 0 M106 S255 ; Fan at 100 to cool nozzle and bed M220 S100 ; Set speed factor back to 100% in case it was changed M221 S100 ; Set extrusion factor back to 100% in case it was changed M290 R0 S0 ; clear babystepping G28 XY ; home XY M84 ; turn off steppers G4 S60 ; wait 1 minute for nozzle to cool M107 ; turn off the fan
Now is working with this config.
Can you tell me why?
What config? Did you mean to post one?
@fcwilt i mean the config post from phaedrux
You mean you added those commands to cancel.g?
I'm thinking there is an issue with missing or blank cancel.g files and the firmware isn't doing the expected default behaviour.
Thanks for confirming that adding a cancel.g with commands allows it to work. I'll flag this for further investigation.
@Phaedrux I doun't now why, but on second test, the same bevore. I test at saturday more cycles. I think the problem is at my side.
I give you Feedback at saturday night ore sunday morning. -
@Phaedrux
Thanks for your help. But i doun't find out what is. I have downgraded to 3.1.1When the next 3.2.x stabel comes out i test it.
I found the mistake. It was the slicer. I accidentally swapped relative and absolute extrusion. As a result, the skirt was still printed and nothing came out of the nozzle during the actual printing
Thanks for the update.
