New to the duet COMPLETE NEWBIE
@Phaedrux its okay. I can always get another . no worries.
Ok, I can mostly see the endstops and they all look like they are connected correctly with the wires going to the outside pins, so that's a good start.
Now to make sure the wires are actually connected electrically.
Send M119 and see what the Z stop says.
Then hold down the Z switch and send M119 again while holding it clicked and see if the status changes. -
Its being so mean
1/22/2021, 4:44:48 PM M119
Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: at min stop
1/22/2021, 4:44:33 PM M119
Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: at min stop -
So being clicked or not it's not registering? Just as a control, text the other endstops as well.
If that is the case that pressing the endstop isn't registering at all then there could be a break in the wire or poor connection. In which case reseating the z endstop plug on the board may help. If you have a multimeter you can check the wire for continuity and whether the endstop switch will complete or break a circuit.
@Phaedrux
Okay. So how would i test with a multimeter? As in where to on the Z? Im still new at using this multimeter , ill post a pic to know exactly which setting to set it to. Also which command do i sent to test only for Z? THANKKASSSS -
This might help.
https://www.youtube.com/watch?v=OOK8np4t40c&ab_channel=HelpfulDIY
When set to ohms (orange on the left side, infact the symbol below the 600 may be intended specifically for continuity the arrow and the beep symbol), you can touch the two probe tips together and the display number should change, and maybe beep. Meaning there is a connection between them. Touch something metal and it should do the same. Touch two ends of a wire, same thing.
It will probably be easiest to remove the endstop from the printer entirely so that you can check the wire more easily. You'd basically want to touch one of the wires at the end that plugs into the printer, and the other end at the endstop itself.
Yeahhh .. . so i think its the actual endstop. Its really wiggly. . i don't think its suppose to be this way . . i just ordered some new ones, and new cables to dead this whole issue. by the time i'm done ill probably have enough supplies for another printer.
@Phaedrux BUT THANK YOU THOUGH!! NOW I KNOW HOW TO USE IT THE RIGHT WAY.
Hmm, yeah wiggly isn't great.
There is a way to get up and running without a Z endstop at all though. You can configure it to ask you to jog the print head down so that the nozzle touches the bed to set the Z height. Manual probing.
You'd need to change your config.g
M558 P0 H5 F300 T6000 G31 x0 y0 z0 P500
And then in homeall and homez where it says
G1 H1 Z-405 F3000 ; move Z down until the endstop is triggered G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
replace that with
G1 X150 Y150 F6000 G30
Then when you try and home it will do xy, move to the center(ish) and there will be a pop up asking you to move Z jog it down carefully and when the nozzle is just touching the bed, hit OK.
Pretty handy in cases like this. I used this the other week when I broke a BLTouch pin.
This post is deleted! -
Haha, good luck with your first print.
@Phaedrux
I am SO SCARED. . lol thanks for the luck . . I NEED ITTTT -
@Phaedrux okay so do is erase something out of my config? or rather where do i put this into the config
@Phaedrux said in New to the duet COMPLETE NEWBIE:
Okay i think i see . .
M558 P0 H18 F120 T480000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X10:220 Y10:220 S20 ; define mesh gridreplace with
G31 x0 y0 z0 P500 -
Replace with:
G31 x0 y0 z0 P500
M557 X10:220 Y10:220 S20 ; define mesh grid -
G91
G1 H1 Z-400 F3000
G92 Z0 ; change Z0 to match the actual Z co-ordinate at which the Z end stop triggers
G1 Z10
G1 H1 X-300 Y-300
G1 X5 Y5
G1 H1 X-6 Y-6 F300
G90change to
G91
G1 X150 Y150 F6000
G30
Do i leave everything under this there or void?
G1 Z10
G1 H1 X-300 Y-300
G1 X5 Y5
G1 H1 X-6 Y-6 F300
G90 -
For homeall try this
G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-300 Y-300 F3000 ; move quickly to X and Y axis endstops and stop there (first pass) G1 X5 Y5 F6000 ; go back a few mm G1 H1 X-300 Y-300 F3600 ; move slowly to X and Y axis endstops once more (second pass) G90 ; absolute positioning G1 X150 Y150 F6000 ; move to center G30 ; probe the bed G1 X10 Y10 Z10 ; move to parking position
@Phaedrux YESSS !! it worked perfectly!!
@Phaedrux Hello again. Ive been trying to fix this issue all day to no avail. After i home my printer and start the print it does not go down to the bed. its about 2mm above and it doesn't print. Ive checked the settings in cura and i cant figure out where its going left. . . Ill post the first few lines. THANKS for helping me once again.
;FLAVOR:RepRap
;TIME:9734
;Filament used: 17.6452m
;Layer height: 0.32
;MINX:41.27
;MINY:49.81
;MINZ:0.32
;MAXX:211.803
;MAXY:236.543
;MAXZ:99.84
;Generated with Cura_SteamEngine 4.8.0
T0
M190 S60
M104 S220
M109 S220
M82 ;absolute extrusion modeM83 ;relative extrusion mode
G1 F1800 E-3
;LAYER_COUNT:313
;LAYER:0
M107
G0 F6000 X121.857 Y55.934 Z0.32
;TYPE:SKIRT -
G31 x0 y0 z0 P500
Did you change your G31 command in the config.g to have Z0?
