New to the duet COMPLETE NEWBIE
Okay
@Phaedrux I inverted it and it went down so far it cracked the glass .
@gabrealek said in New to the duet COMPLETE NEWBIE:
When configuring a printer for the first time you need to take certain precautions.
For instance you can trigger an end stop switch by hand to verify that it stops the movement of the axis when it should.
In this case you would start from far the bed, being homing, hit the end stop switch and confirm movement stops.
If it didn't you can kill power before something breaks - like you piece of glass.
Also you can force very slow speeds by editing your M203 command to something like
M203 X500 Y500 Z500
which gives you more time to observe and react if something starts to go wrong.
Did you use my homing code?
We can get things working - just take it one step at a time.
@fcwilt yes . . I did use the homing code .. the way my setup is right now i have to reach around to kill the power. . im going to to change things once i print some supports for the new things . . Thank you. I appreciate your help. Im going to post all of my homes to see if you can find anything. . At this point im staring at the computer . . kind of scared to turn it back on . . I may need to take a break.
; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 17:33:25 GMT-0500 (Eastern Standard Time); General preferences
M550 P"Creola" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z400.00 E97.08 ; set steps per mm
M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z120.00 E250.00 ; set accelerations (mm/s^2)
M208 X300 Y300 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop; Z-Probe
M558 P0 H18 F120 T480000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X10:220 Y10:220 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin e0temp
M950 H0 C"bedheat" T0 ; create bed heater output on e0heat and map it to sensor 0
M143 H0 S80 ; set temperature limit for heater 0 to 80C
M308 S1 P"e1temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e1temp
M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
M950 F0 C"fan0" Q20 ; create fan 0 on pin fan0 and set its frequency
M106 P0 C"PartCool" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
M950 F1 C"fan1" Q20 ; create fan 1 on pin fan1 and set its frequency
M106 P1 S1 H T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
T0 ; select first tool///
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 17:33:25 GMT-0500 (Eastern Standard Time)G91
G1 H1 Z-400 F3000
G92 Z0 ; change Z0 to match the actual Z co-ordinate at which the Z end stop triggers
G1 Z10
G1 H1 X-300 Y-300
G1 X5 Y5
G1 H1 X-6 Y-6 F300
G90; set Z position to axis minimum (you may want to adjust this)
;G91 ; relative positioning
;G1 Z18 F8000 ; lift Z relative to current position
;G90 ; absolute positioning///
; homex.g
; called to home the X axis
G1 H2 Z18 F480000 ; lift Z relative to current position
G1 H1 X-305 F3000 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F480000 ; go back a few mm
G1 H1 X-305 F3600 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-18 F480000 ; lower Z again
; homey.g
; called to home the Y axis
G1 H2 Z18 F3000 ; lift Z relative to current position
G1 H1 Y-305 F3000 ; move quickly to Y axis endstop and stop there (first pass)
G1 H2 Y5 F3000 ; go back a few mm
G1 H1 Y-305 F3600 ; move slowly to Y axis endstop once more (second pass)
G1 H2 Z-18 F3000 ; lower Z again
G90 ; absolute positioning////
; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 17:33:25 GMT-0500 (Eastern Standard Time)G91 ; relative positioning
G1 H1 Z-405 F3000 ; move Z down until the endstop is triggered
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G90 ; absolute positioningThank you all for your help, it is greatly appreciated. I feel a lot better with you all helping me, THERE IS STILL HOPE
It's late here (11:30 EST) and I need to turn in. We can take this up tomorrow.
I'm working on my 6th, 7th and 8th printer.
Even so I still take it one step at a time.
Step one is always to get the WiFi working so I have access to the DWC where I can do the rest of the configuration.
Then I connect one piece of hardware at a time and verify that it is working as expected - that stepper motors turn, end stop switches work correctly, fans run, heaters heat, etc.
By doing that when something doesn't work I know exactly where I need to look for the problem.
Ah nuts. Sorry about that.
I'm wondering if your Z endstop wiring is not correct.
Regardless of the ! being there or not, if it's electrically connected to the Duet it should report as stopped/not stopped and change state if the switch is actually clicked at the time when you send M119.
Can you post a photo of the endstop wiring at the board? The creality endstops should be wired to the 2 outside pins of the endstop connector.
@Phaedrux its okay. I can always get another . no worries.
Ok, I can mostly see the endstops and they all look like they are connected correctly with the wires going to the outside pins, so that's a good start.
Now to make sure the wires are actually connected electrically.
Send M119 and see what the Z stop says.
Then hold down the Z switch and send M119 again while holding it clicked and see if the status changes. -
Its being so mean
1/22/2021, 4:44:48 PM M119
Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: at min stop
1/22/2021, 4:44:33 PM M119
Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: at min stop -
So being clicked or not it's not registering? Just as a control, text the other endstops as well.
If that is the case that pressing the endstop isn't registering at all then there could be a break in the wire or poor connection. In which case reseating the z endstop plug on the board may help. If you have a multimeter you can check the wire for continuity and whether the endstop switch will complete or break a circuit.
@Phaedrux
Okay. So how would i test with a multimeter? As in where to on the Z? Im still new at using this multimeter , ill post a pic to know exactly which setting to set it to. Also which command do i sent to test only for Z? THANKKASSSS -
This might help.
https://www.youtube.com/watch?v=OOK8np4t40c&ab_channel=HelpfulDIY
When set to ohms (orange on the left side, infact the symbol below the 600 may be intended specifically for continuity the arrow and the beep symbol), you can touch the two probe tips together and the display number should change, and maybe beep. Meaning there is a connection between them. Touch something metal and it should do the same. Touch two ends of a wire, same thing.
It will probably be easiest to remove the endstop from the printer entirely so that you can check the wire more easily. You'd basically want to touch one of the wires at the end that plugs into the printer, and the other end at the endstop itself.
Yeahhh .. . so i think its the actual endstop. Its really wiggly. . i don't think its suppose to be this way . . i just ordered some new ones, and new cables to dead this whole issue. by the time i'm done ill probably have enough supplies for another printer.
@Phaedrux BUT THANK YOU THOUGH!! NOW I KNOW HOW TO USE IT THE RIGHT WAY.
Hmm, yeah wiggly isn't great.
There is a way to get up and running without a Z endstop at all though. You can configure it to ask you to jog the print head down so that the nozzle touches the bed to set the Z height. Manual probing.
You'd need to change your config.g
M558 P0 H5 F300 T6000 G31 x0 y0 z0 P500
And then in homeall and homez where it says
G1 H1 Z-405 F3000 ; move Z down until the endstop is triggered G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
replace that with
G1 X150 Y150 F6000 G30
Then when you try and home it will do xy, move to the center(ish) and there will be a pop up asking you to move Z jog it down carefully and when the nozzle is just touching the bed, hit OK.
Pretty handy in cases like this. I used this the other week when I broke a BLTouch pin.
This post is deleted! -
Haha, good luck with your first print.
@Phaedrux
I am SO SCARED. . lol thanks for the luck . . I NEED ITTTT -
@Phaedrux okay so do is erase something out of my config? or rather where do i put this into the config
@Phaedrux said in New to the duet COMPLETE NEWBIE:
Okay i think i see . .
M557 X10:220 Y10:220 S20 ; define mesh gridreplace with
G31 x0 y0 z0 P500
