New to the duet COMPLETE NEWBIE
@Phaedrux BUT THANK YOU THOUGH!! NOW I KNOW HOW TO USE IT THE RIGHT WAY.
Hmm, yeah wiggly isn't great.
There is a way to get up and running without a Z endstop at all though. You can configure it to ask you to jog the print head down so that the nozzle touches the bed to set the Z height. Manual probing.
You'd need to change your config.g
M558 P0 H5 F300 T6000 G31 x0 y0 z0 P500
And then in homeall and homez where it says
G1 H1 Z-405 F3000 ; move Z down until the endstop is triggered G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
replace that with
G1 X150 Y150 F6000 G30
Then when you try and home it will do xy, move to the center(ish) and there will be a pop up asking you to move Z jog it down carefully and when the nozzle is just touching the bed, hit OK.
Pretty handy in cases like this. I used this the other week when I broke a BLTouch pin.
This post is deleted! -
Haha, good luck with your first print.
@Phaedrux
I am SO SCARED. . lol thanks for the luck . . I NEED ITTTT -
@Phaedrux okay so do is erase something out of my config? or rather where do i put this into the config
@Phaedrux said in New to the duet COMPLETE NEWBIE:
Okay i think i see . .
M558 P0 H18 F120 T480000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X10:220 Y10:220 S20 ; define mesh gridreplace with
G31 x0 y0 z0 P500 -
Replace with:
G31 x0 y0 z0 P500
M557 X10:220 Y10:220 S20 ; define mesh grid -
G91
G1 H1 Z-400 F3000
G92 Z0 ; change Z0 to match the actual Z co-ordinate at which the Z end stop triggers
G1 Z10
G1 H1 X-300 Y-300
G1 X5 Y5
G1 H1 X-6 Y-6 F300
G90change to
G91
G1 X150 Y150 F6000
G30
Do i leave everything under this there or void?
G1 Z10
G1 H1 X-300 Y-300
G1 X5 Y5
G1 H1 X-6 Y-6 F300
G90 -
For homeall try this
G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-300 Y-300 F3000 ; move quickly to X and Y axis endstops and stop there (first pass) G1 X5 Y5 F6000 ; go back a few mm G1 H1 X-300 Y-300 F3600 ; move slowly to X and Y axis endstops once more (second pass) G90 ; absolute positioning G1 X150 Y150 F6000 ; move to center G30 ; probe the bed G1 X10 Y10 Z10 ; move to parking position
@Phaedrux YESSS !! it worked perfectly!!
@Phaedrux Hello again. Ive been trying to fix this issue all day to no avail. After i home my printer and start the print it does not go down to the bed. its about 2mm above and it doesn't print. Ive checked the settings in cura and i cant figure out where its going left. . . Ill post the first few lines. THANKS for helping me once again.
;FLAVOR:RepRap
;TIME:9734
;Filament used: 17.6452m
;Layer height: 0.32
;MINX:41.27
;MINY:49.81
;MINZ:0.32
;MAXX:211.803
;MAXY:236.543
;MAXZ:99.84
;Generated with Cura_SteamEngine 4.8.0
T0
M190 S60
M104 S220
M109 S220
M82 ;absolute extrusion modeM83 ;relative extrusion mode
G1 F1800 E-3
;LAYER_COUNT:313
;LAYER:0
M107
G0 F6000 X121.857 Y55.934 Z0.32
;TYPE:SKIRT -
G31 x0 y0 z0 P500
Did you change your G31 command in the config.g to have Z0?
@Phaedrux
yes; Z-Probe
G31 x0 y0 z0 P500
M557 X10:220 Y10:220 S20 ; define mesh gridDo you think its something with my homeall?
idk what to do. . ill post my config here as well; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 17:33:25 GMT-0500 (Eastern Standard Time); General preferences
M550 P"Creola" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z400.00 E97.08 ; set steps per mm
M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z120.00 E250.00 ; set accelerations (mm/s^2)
M208 X300 Y300 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop; Z-Probe
G31 x0 y0 z0 P500
M557 X10:220 Y10:220 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin e0temp
M950 H0 C"bedheat" T0 ; create bed heater output on e0heat and map it to sensor 0
M143 H0 S80 ; set temperature limit for heater 0 to 80C
M308 S1 P"e1temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e1temp
M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
M950 F0 C"fan0" Q20 ; create fan 0 on pin fan0 and set its frequency
M106 P0 C"PartCool" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
M950 F1 C"fan1" Q20 ; create fan 1 on pin fan1 and set its frequency
M106 P1 S1 H T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
T0 ; select first toolAlso my homeall
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 17:33:25 GMT-0500 (Eastern Standard Time)G91 ; relative positioning
G30 ; probe the bed
G1 X10 Y10 Z10 ; move to parking position; set Z position to axis minimum (you may want to adjust this)
;G91 ; relative positioning
;G1 Z18 F8000 ; lift Z relative to current position
;G90 ; absolute positioning -
now you need to calibrate the trigger height of the probe
@Veti ok thank you . ill do it after my errand and keep you all posted
@Veti said in New to the duet COMPLETE NEWBIE:
No probe involved in this case. Just manual probing due to a broken Z endstop.
@Phaedrux yes, I figured after trying to follow along with it. It’s working for the most part now though. I’m having some mechanical issues at this point. My feeding gears were all off and I releveled the bed. I’m about to try a print now. Thank you all for the consistent help.
