Thank for the massive update about PID TUNING !!!
I've just updated to version 3.2 coming from 3.1.1 and also did the new PID tuning, using the tool as "heater" M303 T0 S240. Everything went okay so far, but the results arent that good.
This was the first print I did, it really took some time to get stable temps (there is a 5 degree drop after the first layer via slicer):
In another print I've got a heater error and a quite spicky graph, forgot to make a screenshoot of it. Cleared the heater fault afterwards and restarted print, which went fine.
This way my old PID tune with RRF 3.1.1:
M307 H1 A735.3 C254.6 D5.2 S1.00 V24.2 B0
And new with 3.2
M307 H1 R2.576 C273.2:173.4 D5.89 S1.00 V24.3
Any ideas what could be the issue?
If you have a spiky temperature graph, that indicates a temperature measuring issue.
It's hard to tell much from that graph without seeing more detail, however there is evidently some overshoot at the start. The old gain (A) parameter was 735.3 whereas the new one is 2.576 * 273.2 = 704. The reduction probably explains the overshoot. Try increasing the R parameter by a factor of 735.3/704 to get rid of it.
Thx for the explanation. I will adjust the R parameter like you said and see if that helps with the overshoot.
I will have a closer look at the spiky temperature at the heatup phase, maybe it was just a hickup.Cableing should be okay, I just rebuild the printer and redid the wiring with new cables and crimps. Could any config related stuff interfere with the temperature readings?
@Mugga said in Thank for the massive update about PID TUNING !!!:
And new with 3.2
Sorry to go off topic but how do you name your heaters like that?
@Blacksheep99 said in Thank for the massive update about PID TUNING !!!:
M308 A parameter. https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M308_Set_or_report_sensor_parameters
@Phaedrux said in Thank for the massive update about PID TUNING !!!:
Thanks. Nice feature.
@Blacksheep99
Yeah, exactly like Phaedrux told. Just the M308 A Paramter.I changed the R value as dc42 told me to, and the overshoot is almost gone. There is a small hickup close before reaching the target temperature but nothing special.
Here is the curve:
@Mugga Seems like maybe a noisy thermistor connection. Maybe try giving it a twist, and isolating it from other wiring as much as possible. Is your hotend grounded?
I can try, but I havent had this behaviour before the 3.2 upgrade with the old PID tune. Hotend isnt grounded, you think that could change readings?
True, but you also said " I just rebuild the printer and redid the wiring with new cables and crimps."
So not exactly apples to apples.
Never a bad idea.
Yeah, but I had a few hours of printing after the rebuilt with 3.1.1 without any issues. But I will double check the wiring.
