Error when trying to update- Duet3_SBCiap32_MB6HC.bin missing
its part of the 3.2 update
As you are running with attached RPi or other SBC, it should have been installed when you ran apt update and apt upgrade.
Yes, I have a Pi 4 attached. Ran the sudo apt update and sudo apt upgrade a couple of times, the first time everything ran through good. looks like the 3HC board is still on the old firmware, I can't get it to update for anything. The 6HC and DWC both look like they updated fine using apt
@cdthomas9 said in Error when trying to update- Duet3_SBCiap32_MB6HC.bin missing:
I don't see the Duet3_SBCiap32_MB6HC.bin anywhere in the file manifest. I see Duet3_SDiap32_MB6HC.bin
but that's definitely a different file. I'm guessing the file it's saying it needs is due to the SBC interaction with the 6HC board? -
I am also getting a number of errors when the board resets:
1/15/2021, 9:56:25 AM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 3
1/15/2021, 9:56:20 AM Connection interrupted, attempting to reconnect...
1/15/2021, 9:56:20 AM Emergency stop, attemping to reconnect...
1/15/2021, 9:56:06 AM Error: M307: Heater 1 not found
1/15/2021, 9:56:06 AM Warning: M950: Command is not supported
1/15/2021, 9:56:06 AM Warning: M308: Invalid Z probe index
1/15/2021, 9:56:06 AM Error: M906: Response timeout: CAN addr 1, req type 6043, RID=6
1/15/2021, 9:56:05 AM Error: M92: Response timeout: CAN addr 1, req type 6042, RID=5
1/15/2021, 9:56:05 AM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 6
1/15/2021, 9:56:04 AM Error: M350: Response timeout: CAN addr 1, req type 6042, RID=4
1/15/2021, 9:56:04 AM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 5
1/15/2021, 9:56:04 AM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 4
1/15/2021, 9:56:04 AM Error: M584: Response timeout: CAN addr 1, req type 6042, RID=3 -
@cdthomas9
post your config. but the error tell you that you have errors in your config -
M669 K1 ; select CoreXY mode; Drives
M569 P0.0 S0 ; physical drive 0.0 goes forwards
M569 P0.1 S0 ; physical drive 0.1 goes forwards
M569 P0.2 S0 ; physical drive 0.2 goes forwards
M569 P0.3 S0 ; physical drive 0.3 goes forwards
M569 P0.4 S0 ; physical drive 0.4 goes forwards
M569 P0.5 S0 ; physical drive 0.5 goes forwards
M569 P1.0 S1 ; physical drive 1.0 goes backwards
M569 P1.1 S0 ; physical drive 1.0 goes forwards
M569 P1.2 S0 ; physical drive 1.0 goes forwards
M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0 ; set drive mapping
M92 X80.00 Y80.00 Z1600.00 E415.00 ; set steps per mm
M566 X900.00 Y900.00 Z120.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z480.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E940 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
M671 X33.2:33.2:355.5:355.5 Y447.5:-61:447.5:-61 S20 ; leadscrew definition; Axis Limits
M208 X374 Y360 Z430 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!io0.in" ; configure active-low endstop for low end on X via pin io0.in
M574 Y1 S1 P"!io1.in" ; configure active-low endstop for low end on Y via pin io1.in
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
M558 P9 C"^io7.in" H10 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-48 Y15 Z2.291 ; set Z probe trigger value, offset and trigger height
M557 X15:360 Y15:345 S35 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M307 H0 A232.9 C532.1 D1.7 V23.8 B0 ; heater definition as provided by auto tune
M143 H0 S130 ; set temperature limit for heater 0 to 130C
M308 S1 P"1.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin 1.temp0
M950 H1 C"1.out0" T1 ; create nozzle heater output on 1.out0 and map it to sensor 1
M307 H1 B0 S1.00 ; default heater definition
;M307 H1 A570.8 C282.2 D 4.1 V23.8 B0 ; heater definition as provided by auto tune; Fans
M950 F0 C"1.out6" Q500 ; create fan 0 on pin 1.out6 and set its frequency
M106 P0 S0 H1 T45 ; set fan 0 value. Thermostatic control is turned on
M950 F1 C"1.out7" Q500 ; create fan 1 on pin 1.out7 and set its frequency
M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P0 D0 H1 F-1 ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom Settings
M564 H0 ; Allow movement before axes are homed -
I've been running with this config for a while now, when running the 3.2 update it just broke
It looks like any command that requires it to talk to the 3HC fails with a CAN timeout? The 3HC is blinking in sync with the 6HC though. The errors I'm getting all have a motor or heater defined on the 3HC, I have that set for the extruder motor, heater and thermistor.
1/15/2021, 12:51:26 PM Error: M307: Heater 1 not found
1/15/2021, 12:51:26 PM Warning: M950: Command is not supported
1/15/2021, 12:51:26 PM Warning: M308: Invalid Z probe index
1/15/2021, 12:51:26 PM Error: M906: Response timeout: CAN addr 1, req type 6043, RID=6
1/15/2021, 12:51:25 PM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 6
1/15/2021, 12:51:25 PM Error: M92: Response timeout: CAN addr 1, req type 6042, RID=5
1/15/2021, 12:51:24 PM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 5
1/15/2021, 12:51:24 PM Error: M350: Response timeout: CAN addr 1, req type 6042, RID=4
1/15/2021, 12:51:23 PM Error: M584: Response timeout: CAN addr 1, req type 6042, RID=3
1/15/2021, 12:51:23 PM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 4 -
I would suggest trying a fresh download and re-image of DuetPi on your Pi SD card followed by a sudo apt update/upgrade. Seems like you may be using the image that came on the card with the Duet3?
Yes, I was. I've run the updates and upgrades since though. Is that something that should be done every so often? Reimage the SD card to the latest DuetPi?
@cdthomas9 No, but the image was updated since and re-imaging has solved problems for others in the past, so worth a shot.
I just ran M997 B1 to manually force the 3HC to update to 3.2, and it looks like that fixed it
Can I run a PID tuning on the heater attached to the 3HC now? I remember I couldn't before, wasn't sure if 3.2 fixed it
@cdthomas9 the heater tuning algorithm has been updated in 3.2, which paves the way for tuning on tool boards and expansions in 3.3 I believe.
From your first post with the M997 error message I thought you had already tried to manually update it.
I did, but I wasn't trying to run the expansion board directly or separately. I was letting it run through and update everything in bulk, at least I think I was...
I ran a M997 to update all firmware, thinking that the command would run through the main board and expansion boards
Ah ok. Well glad it's sorted out. Now that you're on a full release with all boards synced the sudo apt update should work going forward.
Thanks! What was the file it was looking for? the SBC iap file? I saw an SD iap file but not that one. I couldn't find that anywhere
The SBC IAP file would come from doing Sudo apt update/upgrade I believe
