Capricorn PTFE Tubing XS- Low Friction
How nicely does the XS stuff cut with a razor knife? Can it easily be "pointed" so it fits between the two drive gears, like normal PTFE tube, or does it crumble or is it hard to cut?
I don't kind of get this 0.9 degree stepper on a Titan thing. I know E3D are selling them and it seems they have the motor made especially for them. But the steps per mm for a Titan with a standard 1.8 degree stepper are a tad over 400 which means that a 0.9 degree stepper will want over 800. Why would one need that sort of resolution? Or is there some other reason for having a 0.9 degree stepper motor on a geared extruder?
At 0.15mm filament width and 0.05mm layer height, 1mm of print length is 0.0075mm^3 of polymer.
At 800 steps/mm, one step = 0.003mm^3 of polymer. So the benefit really is in very small extrusion widths/layer heights.
@bot:
Yes there is a photo above with exactly that…. I cut it to a V with scissors
Good to know, thank you
Yes. So when I have a nozzle that can print about 2 hairs breadth wide and 3/4 of a hairs breadth tall I might need the extra resolution. Can't see me running out to buy a nozzle that size any time soon.
Ian, check this out:
http://e3d-online.com/High-Res-015-NozzlesImagine the time it would take to fill your build area with one of those!
If my wife ever gets into 3d printing jewelry i might pick one of those up lol
On one machine I have a flex3drive which is geared 40:1 and my esteps/mm is 3600. Does it manifestly improve the prints compared to titan with 1.8 degree motor - no. There are other benefits obviously.
Might a 0.9 deg motor be beneficial with 0.15mm nozzle? Yes certainly with low geared/ungeared extruders, but these are rapidly falling out of fashion.
I am going to check these out, just viewed the webpage. I like what I see so far but I wonder what teaming one of these up with a titan aero would do
https://flex3drive.com/flex3drive/f3d-dda/
Yes that would be like me watering my garden with a hypodermic needle on the end of my hose pipe.
So how do you prevent blockages? On a nozzle that small I reckon you'd need to have the printer installed in a clean room, fed with filtered air at just above atmospheric pressure, enter via an air lock, wearing a one piece paper overall, a hair net and surgical mask.
https://www.thingiverse.com/thing:2119644
that would do the trick and using only the recommended filaments for that nozzle
Yes recommended to have some felt or something similar to clean the filament.
that particular enclosure uses a PTFE tube all the way to the extruder so the filament never gets exposed accept when loading of coarse but yeah no reason a felt coupler couldnt be integrated right before it enters into the PTFE
I'd missed this thread before, but just wanted to add that I switched to Capricorn PTFE for my bowden a few months ago, and it was a drastic improvement. The only issue I've had with it was a cheap spool of filament that jammed… the filament was > 1.78mm in spots. Outside of that bad roll, it's been awesome. I highly recommend i t.
and i thought printing the e3d ptfe clip was rough LOL that is microscopic… but is it really higher res? eventually would like to be able to print gears so accuracy is important to me but that seems a bit much for my needs not to mention print times...ugh :).
Did you lower all your retraction settings? I found that i needed to lower retraction down quite a lot after the upgrade as i quickly jammed and needed to perform a cold pull with nylon to clear everything.
you should be able to do gears just fine with .35 or .4 nozzle if you're calibrated well.
I'm glad I found this thread. I just ordered some of that Capricorn XS tubing from Filastruder. I've been trying to reduce the problems I get with corner blobbing and blobbing at layer line ends due to bowden system pressure. I've been using the pressure advance feature, and with the settings I've got so far it's been helping, but hasn't eliminated it.
If this Capricorn reduces the filament compression (more like kinking than strict compression, but you know what I mean) that should help a lot more. This bowden system pressure is the one thing I really don't like about my printer as compared to my direct extruding Di3. Other than this my D-bot is better than my Di3 in every way.
Btw, I have a little experience looking at extrusion "pulsing" quality when changing microstepping. When I increased the microstepping I was using on my extruder I saw an improvement in the consistency of the extruded line widths. It's tiny, but you can actually see it pretty clearly on the surface of top layers. There are little "segments" if you will due to extruder stepping, and the size and distance between segments was clearly reduced as I upped the microstepping. I'll see if I can find the photo I had before that showed this.
Here's an image showing two printed gears (to be used with my belted extruder). The one on top was printed with my extruder stepper set to use 32x microstepping. The one on the bottom had the extruder using 16x microstepping.
If you look carefully you can see the "step pulsing" artifacts are smaller and closer together in the 32x microstepping print as compared to the 16x print.
A geared vs. non-geared extruder should show similar differences due to step pulsing. If anyone's confused, I'm calling it "step pulsing" when the pressure in the extruder system is increased suddenly and then decays a little as plastic flow reduces the pressure due to the discrete steps nature of the stepper motors we use. The closer together the steps are, the lower the difference will be between the highest and lowest pressure (and hence flowrate) of the system as it prints, as well as the frequency of these pressure pulses. The geared extruders have the same effect, ie: more pulses per mm of printed line, at lower pressure difference per pulse.
Yes, I went from 3.5mm retraction and still some fine stringing, to 1.3mm retraction, zero stringing. No other change than the Capricorn bowden tubing, cut to the same length. (E3dv6 & titan combo)
