I can't print object sliced with Prusa Slicer...
It can't print every GCODE, it looks like the Extruder stepper spins with a low low low step/mm number....this is just a little example because only small files can be attached here....linked there are the extruder settings as well example.gcode
@the_dragonlord have you tried disabling pressure advance?
@the_dragonlord, are you sure you have configured PrusaSlicer for the correct filament diameter, i.e. 1.75mm (assuming that is what you are using) and not 2.85mm?
also if you are using prusa's presets be sure to remove any printer specific config in the filament gcode
@matt3o yes
@dc42 said in I can't print object sliced with Prusa Slicer...:
yes, it is 1,75
@matt3o said in I can't print object sliced with Prusa Slicer...:
No specific config are present
@the_dragonlord I use absolute extrusion with Prusa, if that makes any difference
I've tried both but none of them works.....
@the_dragonlord have you set a max volumetric flow rate (in printer or filament settings)?
What is your first layer speed set to?
