3.2 JSON Parse error: Unrecognized token '<' Password bug
Definitely will do. Your guesses are way more educated than mine, so I greatly appreciate it. Ill let you know the results.
My theory is that it's trying to save the cache or settings on the SD card and the weak wifi signal is causing issues.
I'm not sure which storage the "local storage" is referring to. It's a bit ambiguous and I never got clarification last time it came up. It's either the SD card as in local to the machine, or the browser side, as in local to the viewer.
@chrishamm will know for sure, but he's probably sleeping like a baby at the moment.
Unfortunately all four configurations (emptying browser cache each time) still had the same error come up.
My last suggestion is to manually replace the contents of the /www folder with a fresh set from https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWebControl-SD.zip
And if that doesn't work, try a fresh SD card.
And if that doesn't work, wait for chrishamm
Unfortunately manually replacing the www folder did not change anything, and neither did a new SD card. Thank you for your input though!
If you have any insight, I would greatly appreciate it.
@Charlie Some response doesn't seem right, no valid JSON should start with '<' so you're getting an error. Try to open the developer console with F12 and check the log for further details. You should be able to see an error trace in there.
What browser are you using? Can you open DWC from a different device?
Thank you for your response.
I opened the developer console in Safari (Develop > Show Web Inspector > Console). I found the following errors and warnings:
Im currently using Safari.
The first error does not seem to be the cause of the issue, and was resolved by inserting a blank "dwc-plugins.json" file in the sys/ folder using DWC.
The subsequent errors seem to be the cause of the issue. Ive diffchecked both the "pollconnector.js" and the "BaseConnector.js" files against the files in GitHub and they appear to be identical. Im pretty out of my depth when it comes to coding, so any help would be greatly appreciated.
Can you test with Chrome just to see if it's isolated to safari on your machine? What MacOS and Safari version are you running?
The 401 error would mean the < you are getting is because it's sending an HTML 401 error page response.
What happens if you take out the M551 in your config? Maybe there is an issue going on with passwords?
I will try to see if I can replicate the issue on Chrome, though its difficult to reliably replicate the issue. I am using macOS Big Sur 11.1 and Safari 14.0.2 (most up to date I believe).
(I'm NOT a JavaScript guy, so....))
It looks like the code is trying to parse a JSON tesponse, but the response is not JSON, it's text.
I notice in PollConnector.js this code:
if (xhr.status >= 200 && xhr.status < 300) { if (responseType === 'json') { try { if (!xhr.responseText) { resolve(null); } else { resolve(JSON.parse(xhr.responseText)); } } catch (e) { reject(e); } } else { resolve(xhr.response); }
But in BaseConnector.js I see this code:
if (xhr.status >= 200 && xhr.status < 300) { try { if (!xhr.responseText) { resolve(null); } else { resolve(JSON.parse(xhr.responseText)); } } catch (e) { reject(e); }
Maybe if you use the code from PollConnector.js in BaseConnector.js you'll fix the issue.
It appears as though this is NOT occurring in Chrome, though Ive been having issues replicating the error recently.
Wouldn't be the first time Safari has behaved oddly.
Hahaha! Very true.
I am testing out the solution by @Sindarius and I will report back the results.
Your solution appears to have worked! I deleted M551 and no more error messages in Safari.
Thank you so much for your response, but I have no clue how I would go about changing this, as I have no clue where these files (don't even know if the files sit on the Duet, lol).
@Charlie "Ive diffchecked both the "pollconnector.js" and the "BaseConnector.js" files against the files in GitHub and they appear to be identical. Im pretty out of my depth when it comes to coding, so any help would be greatly appreciated."
Oh, I figured if you checked those files you'd be ready-to-go. My machine is at the lab and I haven't been going in there due to COVID-19, so I can't check.
I don't know where the files are either, but the .zip file has them in: store\machine\connector
Is that a place on your Duet?
@Charlie Thanks for the log, I'll try to reproduce this in Safari but I am surprised it tries to parse invalid JSON at some point - even because it should never attempt to parse anything once it gets back HTTP code 401.
@alankilian BaseConnector is the base class of PollConnector and that particular function is only used when connecting. The JS files are bundled by Webpack into very few files to accelerate the initial page load.
