Smarteffector problems with 3.11 ( update from 2.04)
@fragle can you post your current complete config please. Which delta is it as well?
It is a Anycubic Predator with a smart effector and default rods
; Configuration file for Duet WiFi (firmware version 1.21) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 26 2019 21:31:01 GMT+0000 (Greenwich Mean Time) ; General preferences G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Delta Settings M665 L440.000 R227 H430.0 B185.0 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 A0.00 B0.00 ; Put your endstop adjustments here, or let auto calibration find them ; Network M550 P"Anycubic Predator" ; Set machine name M551 P"" ; Set password M552 S1 M552 P192.168.178.10 ; Enable network and acquire dynamic address via DHCP M553 P255.255.255.0 M554 P192.168.178.1 M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drives M569 P0 S0 ; Drive 0 goes forwards M569 P1 S0 ; Drive 1 goes forwards M569 P2 S0 ; Drive 2 goes forwards M569 P3 S0 ; Drive 3 goes forwards M350 X32 Y32 Z32 E16 I1 ; Configure microstepping with interpolation M92 X160.00 Y160.00 Z160.00 E415.00 ; Set steps per mm M566 X1000 Y1000 Z1000 E1000 ; Set maximum instantaneous speed changes (mm/min) M203 X12000.00 Y12000.00 Z12000.00 E10000 ; Set maximum speeds (mm/min) M201 X3000.00 Y3000.00 Z3000.00 E3000.00 ; Set accelerations (mm/s^2) M906 X1000.00 Y1000.00 Z1000.00 E1000.00 I30 ; Set motor currents (mA) and motor idle factor in per cent ;M666 X3 Y0 Z0 M84 S45 ; Set idle timeout ; Retraction M207 S4.0 F5000 R-0.025 T2500 Z0.5 ; Firmware retraction ; Axis Limits M208 Z0 S1 ; Set minimum Z ; Endstops M574 X1 S1 P"xstop" ; X min active high endstop switch M574 Y1 S1 P"ystop" ; Y min active high endstop switch M574 Z1 S1 P"zstop" ; Z min active high endstop switch M574 U2 S1 P"e0stop" ; U max active high endstop switch ; Z-Probe M558 P8 H4 F1000 T12000 R0.2 S0.02 A5 C"zprobe.in+zprobe.mod" G31 P100 X0 Y0 Z-0.000 ; Set Z probe trigger value, offset and trigger height M557 R150 S20 ; Define mesh grid G29 S1 ; Load the heightmap ; Heaters M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 ; define bed temperature sensor M308 S1 P"e0_temp" Y"thermistor" T100000 B4725 C7.06e-8 ; define E0 temperature sensor M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0 M950 H1 C"e0_heat" T1 ; heater 1 uses the e0_heat pin and sensor 1 M140 H0 ; the bed heater is heater 0 M143 H0 S130 ; Set temperature limit for heater 0 to 120C M143 H1 S280 ; Set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ;M106 P0 S0 I0 F100 H-1 C"Print Cooling" ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off ;M106 P1 S1 I0 F100 H1 T45 C"Heatsink" ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Automatic saving after power loss is not enabled ; Custom settings are not configured M572 D0 S0.1 ; Pressure Advance ;M591 D0 P2 C4 S1 ; Activate filament sensor M404 N1.75 ; Set for print monitor M592 D0 A0.07772 B-0.00029 ; Nonlinear extrusion. Set parameters for extruder drive 0 ; Miscellaneous M501 ; Load saved parameters from non-volatile memory
@fragle said in Smarteffector problems with 3.11 ( update from 2.04):
G29 S1
Don't load the heightmap in config.g. It should only ever be loaded or freshly created after probing the bed with G30 to set Z0.
What do you have in bed.g and homedelta.g?
bed.g
; bed.g file for RepRapFirmware, generated by Escher3D calculator ; 16 points, 6 factors, probing radius: 160, probe offset (0, 0) G28 G30 P0 X0.00 Y160.00 Z-99999 H0 G30 P1 X102.85 Y122.57 Z-99999 H0 G30 P2 X157.57 Y27.78 Z-99999 H0 G30 P3 X138.56 Y-80.00 Z-99999 H0 G30 P4 X54.72 Y-150.35 Z-99999 H0 G30 P5 X-54.72 Y-150.35 Z-99999 H0 G30 P6 X-138.56 Y-80.00 Z-99999 H0 G30 P7 X-157.57 Y27.78 Z-99999 H0 G30 P8 X-102.85 Y122.57 Z-99999 H0 G30 P9 X0.00 Y80.00 Z-99999 H0 G30 P10 X69.28 Y40.00 Z-99999 H0 G30 P11 X69.28 Y-40.00 Z-99999 H0 G30 P12 X0.00 Y-80.00 Z-99999 H0 G30 P13 X-69.28 Y-40.00 Z-99999 H0 G30 P14 X-69.28 Y40.00 Z-99999 H0 G30 P15 X0 Y0 Z-99999 S6
homedelta.g
; homedelta.g ; called to home all towers on a delta printer ; ; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 26 2019 21:31:01 GMT+0000 (Greenwich Mean Time) G91 ; relative positioning G1 H1 X470 Y470 Z470 F1800 ; move all towers to the high end stopping at the endstops (first pass) G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass) G90 ; absolute positioning
@fragle ok
Few issues I can see if your config.
M350 only supports Interpolation of microsteps at x16, so I suggest you change back to x16 and the steps per mm to 80.
Secondly, your endstop settings are incorrect. You have them set as being on the low end when infact they are on the high end. The correct settings areM574 X2 S1 P"xstop" M574 Y2 S1 P"ystop" M574 Z2 S1 P"zstop"
Your G31 should have z set as -0.1
Here is my predator config for reference https://github.com/jaysuk/Anycubic-Predator-Duet/tree/SmartEffectorRRF3
@fragle your homing file is also incorrect as it doesn't move the towers down before trying to home again.
This is what it should contain.G91 ; relative positioning G1 H1 X470 Y470 Z470 F1800 ; move all towers to the high end stopping at the endstops (first pass) G1 X-5 Y-5 Z-5 F1800 H2 ; go down a few mm G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass) G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred G90 ; absolute positioning G1 X0 Y0 F6000 ; move X+Y to the centre
I ve adaped my config to your settings, now G32 is working well, but with the mesh compensation i am getting an G29 error Z probe readings are not consistent
At G29 the printhead goes down correctly, make some soft touches to the print plate and after around 4 or 5 point he stand still.
M557 set mesh parameter said 175 radius and 16 spacing
oh i forgot, i have an whambam printplate over the normal print plate
Might need sensitivity adjusted for the smart effector? Higher probe speed?
@fragle you've probably got play in your system with the default arms. Try increasing the S value on M558 to something like 0.05
I will try the suggestions today, but i do not thing, that it is an hardware problem, because the system is running on fw 2.04 without any problems.
small update
if i use G32, than i am getting
Calibrated 8 factors using 16 points, (mean, deviation) before (-0.004, 0.067) after (-0.000, 0.053)
Repeating calibration because deviation is too high (0.053mm)
too many auto calibration attempts -
@fragle so change the S value to 0.06 (or even slightly higher)
Currently, any value above 0.05 (originally 0.02) will cause it to fail.
Its due to the sloppy eyes they use on the rods on the predator. -
G32 is now successful after the second run
I have set the sensitivtiy to 10 for the smart effector, but i am wondering, why the display of the Z probe switches to "1000" around every third contact to the print plate.
The other 2 hits, there was no "1000" release on the display ( even tough the nozzle hits the plate and withdraw correct.
@fragle DWC generally doesn't catch up enough to fully display every probe. If it works, don't worth about it.
I have crosschecked the predator with my old 2.04 settings, everything is working fine.
Back to 3.1.1
Now i can run G32 and G29 without error.
I i try to print something i use as start script
G28
G32During the G32 from the gcode i am getting always an
Error: Z Probe already triggered at atrt of probing modeI have reset the sensififity to 131:131 ( default setting)
i ve tried some configs starting from here https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe to some hints in the forum, but nothing worked.
There are a few possible reasons for this:
- The Smart Effector is triggering when it shouldn't. If this is happening, you will see the green LED on the effector flashing. But if you are sure that it works under RRF 2.05.1, that can't be the problem.
- Vibration or deceleration after the positioning move is causing the effector to trigger. If it's vibration, reducing the sensitivity will help. If it's deceleration after the positioning move, increase the M558 R parameter.
- The effector output wire is picking up interference from an adjacent stepper motor wire. If that is the cause, and you are using probe type 5 in M558, increasing the G50 P parameter may help.
Are you using exactly the same parameter values (except for the ones where the command format has changed) in 3.1.1 as in 2.04, in your M558, M201, M203, M566, M906 and M569 commands in config.g?
small update:
I ve upgraded to firmware 3.2 an now i can print, but i have to adjust the Printhead at printing with 0,2mm babysteps.
If i try to calibrate the Z Probe as described here https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe i am getting -0,01 . Nothing change if i will change the z value to 0,2
i am getting -0,01
It should be slightly negative because it's pressing into the bed. Why do you want to use 0.2?
if i use -0.01my print noozle is to close to the print bed, it is so close, that it would scratch the surface
