Pause.g Resume.g problems
Don't put G92 into the resume.g file. As I said, put it in a separate macro and then run that manually before pressing resume button.
@Phaedrux Yeah that works. But i cant figure out that print fan, any ideas?
Post your config.g
Here
; Configuration file for Duet Ethernet (firmware version 1.16 or older)
; generated by RepRapFirmware Configuration Tool on Thu May 03 2018 12:19:37 GMT+0200 (Střední Evropa (letní čas)); General preferences
M83 ; ...but relative extruder moves; Network
M111 S0 ; Debug off
M550 Deluxe600 ; Machine name (can be anything you like)
M551 inman. ; Machine password (used when you connect Duet Web Control or via FTP)
M540 PBE:EF:DE:AD:FE:ED ; MAC Address (only needed if you have more than one Duet 0.6 or 0.8.5 on the same network)
M552 S1 ; IP address (0 = use DHCP)
M554 192.168.0.220 ; Gateway (not used yet)
M553 P255.255.255.0 ; Netmask
M555 P2 ; Set output to look like Marlin
M575 P1 B57600 S1 ; Set auxiliary serial port baud rate and require checksum (for PanelDue); Drives
M350 Z16 X16 Y16 I1 ; Configure microstepping with interpolation
M350 E32 I0 ; Configure microstepping without interpolation
M92 X50 Y50 Z800 E280 ; Set steps per mm
M566 X480 Y480 Z19.2 E270 ; Set maximum instantaneous speed changes (mm/min)
M203 X12000 Y12000 Z720 E7200 ; Set maximum speeds (mm/min)
M201 X1000 Y1000 Z850 E5000 ; Set accelerations (mm/s^2)
M906 X1650 Y1650 Z1650 E700 I1 ; Set motor currents (mA) and motor idle factor in per cent
M84 S5 ; Set idle timeout; Axis Limits
M208 X0 Y0 Z0 S0 ; Set axis minima
M208 X545 Y545 Z700 S0 ; Set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
M574 Y2 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
;M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" A2 H3 F100 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 X0 Y0 Z1.45 ; set Z probe trigger value, offset and trigger height
M557 X0:500 Y40:500 S100:100 ; define mesh grid; Heaters
M143 H0 S100 ; set temperature limit for heater 0 to 100C
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
M106 P1 S0.5 H1 T45 ; set fan 1 value. Thermostatic control is turned on
M950 F2 C"fan2" Q500 ; create fan 2 (bed) on pin fan2 and set its frequency
M106 P2 S1 H0 T50; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C;LED control
M950 P5 C"e1heat" ;set e1heat as a GPIO output pin
M501
M107 -
@Deluxe-600 said in Pause.g Resume.g problems:
You may want to add your X Y offset for your BLTouch. Unexpected things can happen if you don't.
M563 P0 D0 H1 ; Define tool 0Try adding F0 to your tool definition to make sure it's using fan0 for the part fan.
@Phaedrux The bl touch has a mechanical offset so its ok, but thank you
. I added the F0 to the tool definition (now looking like this"M563 P0 D0 H1 F0" correct?) . Doesnt seem to change anything, the fan still doesnt turn back up. Any other ideas what could i try? This is realy strange.
How did you set the fan speed before the pause: did you use M106 with or without the P parameter? If you used it without (the usual way that slicers generate it) then your pause/resume code looks OK to me.
@dc42 Its set by the Slicer. So no ideas? Ow man
Well didnt know this would be such a problem
an you share a sample gcode file? What slicer?
@Phaedrux Hi.
Im using PrusaSlicer for slicing.
Here is a gcode i tried printing.
test 1_0.3mm_PLA_MK3.gcode -
So basically it turns the fan on with M106 S255 and leaves it on a full power for the duration of the print and then turns it off at the end.
If that's normally the case, as a work around, why not just set the fan speed to 100% in resume.g?
Now that 3.2 is released can you test with that?
It is S255 for PLA but once you start printing PETG the speed changes how its needed. No i havent tried 3.2 yet. Could it solve this problem?
I don't know, but testing on the most recent code base would be ideal in case it has been solved and any work to fix it if it is a bug would happen there. Since you're on 3.1.1 it's an easy update by uploading the Duet2and3CombinedFirmware zip file to the system tab.
@Phaedrux Hi.
So i have updated to 3.2 and tried the pause.g with M107 and also with M106 S0 and the resume.g with M106 R1 and also with M106 R2 but still no luck. Seems like the M106 R1 command sets the speed always to 0rpm. Thank you guys for helping. -
I think its a bug in the software. There is no reason why should this not work, you guys dont use pause on your printers? I went trough every forum i could find and the M106 R1 command should turn the print fan back on...but it doesnt for unknown reason.
Your gcode all looks ok, so it may be a bug. We're looking into it.
@Phaedrux Thank you. Meanwhile i will try to figure it out, if i find any way to solve this problem i will let you know.
I have just tested that on my delta running 3.2 and it works properly for me.
Pause.g:
; Pause macro file if state.currentTool != -1 M83 ; relative extruder moves G1 E-4 F2500 ; retract 4mm G91 ; relative moves G1 Z5 F5000 ; raise nozzle 2mm G90 ; absolute moves G1 X0 Y85 F10000 M106 S0
Resume.g:
; Resume macro file M106 R1 G1 R1 X0 Y0 Z2 F5000 ; move to 2mm above resume point G1 R1 X0 Y0 Z0 ; lower nozzle to resume point if state.currentTool != -1 M83 ; relative extruder moves G1 E4 F2500 ; undo the retraction
The GCode file I am printing uses M106 S0 at the start, M106 S255 at the start of the second layer, and M106 S0 at the end. My M563 command in config.g does not have a F parameter.
