BL Touch doesn't work
What version of the firmware are you running?
Output of M115 please -
what about the deploy and retract scripts?
@jay_s_uk Hello
It's
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2020-02-09b1
Thanks -
@Veti Hello.
I don't understand the meaning of scripts, but
M280 P7 S90 and
M280 P7 S10 are working correctly.... -
@Hiroaki said in BL Touch doesn't work:
@Veti Hello.
M280 P7 S90 and
M280 P7 S10 are working correctly....Have you created, in the firmware System folder, the deployprobe.g and retractprobe.g files containing the appropriate M280 command?
@fcwilt Hello.
Oh, I got it.
Yes, Deployprobe.g is
M280 P7 S90
and retractprobe.g is
M280 P7 S10 -
are those file in the system folder and not the macro folder?
@Veti Sorry
I should have put it.
Yes, these are in SYS folder.
Regards -
can you issue M401 and M402 to to see if the deploy and retract work that way?
Deployprobe.g
did you spell that with a captial D?
please rename the file
@Veti
With M401 it's pulled up,
with M402 it's pulled down. -
@Veti
It's with "d" actually... -
can you post the output of M558?
@Veti
Z Probe type 9, input 0, invert no, dive height 3.0mm, probe speed 120mm/min, travel speed 6000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.03 -
with M402 it's pulled down.M401: Deploy z-probe
M402: Retract z-probeI think there is your problem.
change the content of deploy and retract
@Veti Oh I see, let me confirm it.
It's funny because I copied all the files from my first printer which works correctly,...
Anyway thank you very much! -
@Hiroaki M401 should deploy the probe and not pull it up.
you have the contents of your deploy and retract files the wrong way round.Deploy probe should be S10 and retract S90
@Veti I have confirmed that S10 and S90 were swapped in deployprobe.g and retractprobe.g
Thank you very much. -
@jay_s_uk Thank you.
I got it.
But I still wonder why it was ok with my first printer... -
Everybody
Thank you very much!
Now I feel better !
I can sleep tonight!
