BL Touch doesn't work
@Veti
With M401 it's pulled up,
with M402 it's pulled down. -
@Veti
It's with "d" actually... -
can you post the output of M558?
@Veti
Z Probe type 9, input 0, invert no, dive height 3.0mm, probe speed 120mm/min, travel speed 6000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.03 -
@Hiroaki said in BL Touch doesn't work:
with M402 it's pulled down.M401: Deploy z-probe
M402: Retract z-probeI think there is your problem.
change the content of deploy and retract
@Veti Oh I see, let me confirm it.
It's funny because I copied all the files from my first printer which works correctly,...
Anyway thank you very much! -
@Hiroaki M401 should deploy the probe and not pull it up.
you have the contents of your deploy and retract files the wrong way round.Deploy probe should be S10 and retract S90
@Veti I have confirmed that S10 and S90 were swapped in deployprobe.g and retractprobe.g
Thank you very much. -
@jay_s_uk Thank you.
I got it.
But I still wonder why it was ok with my first printer... -
Everybody
Thank you very much!
Now I feel better !
I can sleep tonight! -
@Hiroaki Sorry again.
I have also checked both files in my 1st printer.
Both values were correct.
I can't get when it's changed in my second printer....
