You can see your options here.
https://duet3d.dozuki.com/Wiki/Connecting_an_LCD_control_panel#Section_Option_1_Ribbon_cable
Testing the with ribbon cable could be instructive. 400mm recommended.
For a 4 wire cable it's 800mm recommended. -
@Phaedrux the problem still show up. at lately it more often. i have change the cable to STP lan cable used 4 cable only. i also make it shorter the cable is 50cm long only, before is 1.5m a weeks ago my problem is not occurs often. very rare but sometimes happened but this week it show more often.
is there any trigger event that when it change from active to standby i can forced it back to active?
any way to do it?@dc42 any help about this. i have disperate to solve it with cabling
Can you try updating your PanelDue firmware to the new 3.2 release
https://github.com/Duet3D/PanelDueFirmware
Please note this would also require updating your Duet firmware to 3.2 beta4 as well for best results.
@lifeform Some ideas:
- Do these issues also appear if you do not activate serial communication on Duet, i.e. comment out
M575
? - Is your PanelDue inside a case that by chance might put pressure on the screen? This might result in random taps.
Also can you please restate your current issues. I feel they changed along the course of this thread and I lost track what is still left.
@wilriker said in error:attempting to extrude with no tool selected while printing:
hello, the main problem is just it is randomly changed from active tool to standby while printing. when it not printing this will not happened at all
before i post last night, i change a lot. change paneldue to 3.2 but it is beta when i try. and i change it back to the old firmware cause new paneldue firmware fit for rrf3.2 also
i also change the baudrate from 115200 to 57600, looks like the problem still exist but not often like before
i also change the cable. from 1m ribbon cable to connect mainboard to paneldue. i changed with stp cable. it is for LAN cable. i just found this cable and test it with 50cm long. the sympthom looks like more rarely show upbut a weeks ago, i print 8 hours long. not a really long printing object. but it can show 5 times. the last make me desperate cause i do not know the notification and the print failed.
@wilriker emm if i do not use serial how paneldue connected? looks like it happend with the lcd connected
my panel have screen guard before, now i remove it and the problem still show up yesterday. sorry for my long journey about this. sometimes it's not happened but lately it happened and make frustrated -
the last step i forcely select the tool again when tfree macro called.
but i know it is not solving problem. it is just for emergency.
also measured with my multimeter the resistant of the cable is 0.1
@lifeform said in error:attempting to extrude with no tool selected while printing:
The main question I try to solve here is: does it also happen if there is no PanelDue in the first place. Or put differently: is PanelDue really the cause for your issue or is it something different?
put differ
oops sorry.. i got your poin now. so the first try i must do is disactivate the paneldue and print without paneldue and check if this problem still happen or not. will try in a week of printing. will update as soon as got the problem occurs
@wilriker
tested without paneldue and print ok in several print part and in 5-6days trial
connect the paneldue again and it random change tool againi used blv project for the printer. and looks like the led cable is cross with paneldue cable event i already used shielded cable and ferit.
now i forced to select tool 0 and cannot change to another
next try is separate and reroute the cable of the led at the front cover. and get messsage if the system change the tool accidently. -
I think the issue is that the cable is picking up noise, causing data corruption, and the checksum is insufficient to detect some instances of data corruption. It's time to change the checksum to a CRC.
