Delta smart effector repeatability
Hi all
Have a problem with the effector repeatability.
After 15 times checking it goes slowly UP.
Its starts with 0.150 and ends in 1.80 in about 20 times.What can this be?
This post is deleted! -
@Veti have it on 100 now what could be a good number?
Standard is 50. if you want more sensitivity you need a lower number
@PCR do i need a higher or lower valiue?
What release of RepRapFirmware are you running?
@oliof
3.2.4 -
@Goretec said in Delta smart effector repeatability:
Hi all
What is it that goes up from 0.15 to 1.8?
The probe offset
Made a marcoFist i level the nozzle and set it to Z0
Then the marco
G1 Z5
G30 S-1
G1 Z5
G30 S-1
G1 Z5
G30 S-1A couple of times
Are you using in on a Delta? Could be some mechanical backlash
@PCR yes use it on a delta with linear rails and haydin rods
Please check all belts and grub screws. Have you fixed the hotend etc
@PCR everything is rock solid and tight belts have the same tension hotend is tightened on 240c
