RepRapFirmware 3.2beta4.1 now available
This release fixes bugs in RRF 3.2beta4, notably problems updating Duet 3 tool and expansion board firmware when using an attached SBC, and introduces the option to update PanelDue firmware. Find it at https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2beta4.1.
nice
Version 3 PanelDue boards (including all PanelDue 5i/7i) can now be updated from the Duet
I just tested upgrading the PanelDue using M997 S4.. worked great! That is going to be very helpful for us.. thanks!
The package server has been updated as well, if you're on the
unstable
package feed you can now install it by runningsudo apt-get update
andsudo apt-get upgrade
PanelDue firmware update from Duet instructions are here: https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update#Section_Firmware_update_via_Duet
I've got one minor and one medium issue with 3.2beta4.1:
minor: 2 Duet3 6HC with ToolBoards sometimes show what seems an uninitialised ToolBoard, PanelDue and DWC shows 2000º on the Extruder temp and Heater not configured on the console
A power cycle resolves the issue.
Would a pause in config.g help debug this?
UPDATE:
I can't replicate the issue after several power cycles and STOPs.
If the issues happens again I'll update -
medium: G1 H2 Xx on homex.g also moves Y on the same direction(tested both) and on the same amount.
This happens only in my CoreXY, not in my Cartesian.
G1 H1 moves as expected.
@jbarros I too had the "2000c" issue, as well as a message that there was no Fan 0 associated with the tool. A reboot seems to have fixed it.
PanelDue update was pretty slick!
However repeating 3.2.4 didn't erase or reset 7i, nor did the previously installed 3.2-something-beta.it does when rtfm and using 115200 baud -
@Nuramori said in RepRapFirmware 3.2beta4.1 now available:
You will get that issue if you update the tool or expansion board firmware and you don't then reboot the main board. The next version of DWC will offer to reboot the main board after updating tool of expansion board firmware.
@jbarros said in RepRapFirmware 3.2beta4.1 now available:
This happens only in my CoreXY, not in my Cartesian.G1 H2 moves are defined as individual motor moves, and on a CoreXY machine the X and Y motors each move both X and Y. You can use a G1 H2 Xn Yn move if you want to move just one axis.
@dc42 Weird. I only updated the main board (the toolboard is still at beta 4).
Either way, it's working fine now after the reboot. I'm excitedly waiting for the auto tune off of the toolboard
Exactly like me, Toolboard at 3.2beta4 and 6HC was upgraded from 3.2-beta4+4
@dc42 I read the documentation before posting and I understand that but I could swear it was working ok, I might have missed it before because it was only moving 5mm.
I'm going to downgrade later today to test just as a sanity check.The Configurator puts out moves like I said for homing.
So my question is: how a "normal" user, not knowing CoreXY kinematics should move an axis in a pre homing procedure?
I have just updated the firmware binaries for the Duet 3 expansion boards EXP3HC, TOOL1LC and EXP1XD to fix a stack overflow when a heater fault occurs on a tool or expansion board. These now all report version 3.2beta4.1 (not 3.2beta4 as before).
Has anyone UI-issues updating the Duet Maestro? I get this message:
M997 S0 Operation has been cancelled
when upgrading to 3.2beta4.1 - however it seems the update was successful:
M122 === Diagnostics === RepRapFirmware for Duet 2 Maestro version 3.2-beta4.1 running on Duet Maestro 1.0 Board ID: 08DJM-9X66L-LG3SJ-6JKF2-3SJ6L-KAX6R Used output buffers: 3 of 24 (11 max) === RTOS === Static ram: 23020 Dynamic ram: 97892 of which 200 recycled Never used RAM 8936, free system stack 216 words Tasks: NETWORK(ready,193) HEAT(blocked,335) TMC(blocked,117) MAIN(running,477) IDLE(ready,20) Owned mutexes: === Platform === Last reset 00:02:27 ago, cause: software Last software reset at 2020-12-06 21:23, reason: User, GCodes spinning, available RAM 8976, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN Error status: 0x00 MCU temperature: min 44.7, current 45.2, max 45.7 Supply voltage: min 0.0, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 0, standstill, read errors 0, write errors 1, ifcnt 132, reads 40385, writes 8, timeouts 0, DMA errors 0 Driver 1: position 0, standstill, read errors 0, write errors 1, ifcnt 132, reads 40385, writes 8, timeouts 0, DMA errors 0 Driver 2: position 0, standstill, read errors 0, write errors 1, ifcnt 132, reads 40384, writes 8, timeouts 0, DMA errors 0 Driver 3: position 0, standstill, read errors 0, write errors 1, ifcnt 126, reads 40384, writes 8, timeouts 0, DMA errors 0 Driver 4: position 0, standstill, read errors 0, write errors 1, ifcnt 132, reads 40384, writes 8, timeouts 0, DMA errors 0 Driver 5: position 0, standstill, read errors 0, write errors 1, ifcnt 133, reads 40384, writes 8, timeouts 0, DMA errors 0 Driver 6: position 0, standstill, read errors 0, write errors 1, ifcnt 132, reads 40384, writes 8, timeouts 0, DMA errors 0 Date/time: 2020-12-06 21:42:16 Slowest loop: 25.81ms; fastest: 0.17ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 15.0MBytes/sec SD card longest read time 1.5ms, write time 0.0ms, max retries 0 === Move === FreeDm 169 (min 169), maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1, chamberHeaters = -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 6.74ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 Interface state active, link 100Mbps full duplex
@dc42 I performed changes in my config.g and rebooted the board at the DWC prompt to get:
G28 Error: Board 20 does not have input handle 1000 Error: Failed to enable endstops
Heater temp was 2000º
This happened only one time since the upgrade to 3.2-beta4.1
Let me lnow if you need additional info/testingM122 B20 Diagnostics for board 20: Duet TOOL1LC firmware version 3.2-beta4.1 (2020-12-03) Bootloader ID: SAMC21 bootloader version 2.1 (2020-11-03b2) Never used RAM 4432, free system stack 96 words HEAT 50 CanAsync 89 CanRecv 83 TMC 54 MAIN 316 AIN 66 Last reset 00:02:00 ago, cause: software Last software reset at 2020-11-30 00:59, reason: HardFault, available RAM 4224, slot 0 Software reset code 0x0060 ICSR 0x00000003 SP 0x200011c0 Task Stack: 20001014 0000000f 0001d3e3 00000000 20000928 0001757d 000184fe 01000000 00014822 0001491c 20001210 200032d8 00000020 00017d11 20004668 00000000 20001300 000086e5 00014822 20004678 0001491c 42eb80ae a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 Driver 0: position 0, 80.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 140, reads 60377, writes 9, timeouts 0, DMA errors 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0 No step interrupt scheduled VIN: 24.3V MCU temperature: min 37.4C, current 37.6C, max 37.7C Ticks since heat task active 53, ADC conversions started 120796, completed 120795, timed out 0 Last sensors broadcast 0x00000000 found 0 56 ticks ago, loop time 0 CAN messages queued 512, send timeouts 0, received 1104, lost 0, free buffers 36 M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.2-beta4.1 running on Duet 3 MB6HC v1.01 or later (standalone mode) Board ID: 08DJM-956BA-NA3TJ-6J9D2-3S06S-9V8AT Used output buffers: 1 of 40 (18 max) === RTOS === Static ram: 123292 Dynamic ram: 169120 of which 168 recycled Never used RAM 99612, free system stack 164 words Tasks: NETWORK(ready,165) ETHERNET(blocked,110) SENSORS(blocked,13) HEAT(blocked,297) CanReceiv(blocked,864) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,18) MAIN(running,1125) IDLE(ready,19) Owned mutexes: === Platform === Last reset 00:02:49 ago, cause: software Last software reset at 2020-12-06 12:03, reason: User, GCodes spinning, available RAM 99360, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0xffffffff Task MAIN Error status: 0x00 MCU temperature: min 29.7, current 30.1, max 39.7 Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0 Driver 0: position 400, standstill, reads 41987, writes 19 timeouts 0, SG min/max 0/118 Driver 1: position 400, standstill, reads 41988, writes 19 timeouts 0, SG min/max 0/128 Driver 2: position 2000, standstill, reads 41989, writes 19 timeouts 0, SG min/max 0/189 Driver 3: position 0, standstill, reads 41990, writes 19 timeouts 0, SG min/max 0/83 Driver 4: position 0, standstill, reads 41999, writes 11 timeouts 0, SG min/max 0/0 Driver 5: position 0, standstill, reads 41991, writes 19 timeouts 0, SG min/max 0/88 Date/time: 2020-12-06 12:06:15 Slowest loop: 26.45ms; fastest: 0.15ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 2.5ms, write time 2.8ms, max retries 0 === Move === FreeDm 375 (min 373), maxWait 67323ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 2, completed moves 2, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 23.98ms; fastest: 0.03ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 1 of 8 - Ethernet - State: active Error counts: 0 0 0 0 0 Socket states: 2 2 2 2 2 0 0 0 === CAN === Messages queued 706, send timeouts 0, received 725, lost 0, longest wait 222ms for reply type 6027, free buffers 47
Ok, I've been getting more 2000º and other missing things from the Toolboards
2 printers running 3.2beta4.1 on 6HCs and 3.2beta4.1 on the Toolboards
It seems to happen when saving config.g and accepting the reload popup -
Latest tool board firmware is now 3.2beta4.1.
@dc42 I wrote the version bad on my post but my Toolboards run 3.2beta4.1 from the day you announced it's availability.
Got a problem updating to latest beta.
After upgrade printer doesn't connect to wifi anymore.When doing M587 I get an error saying another SPI transfer is pending.
Tryed rebooting but it's still stuck, any tip ?
Thanks
Edit: I solved it by manually flashing again the wifi module. Wondering what did happened
