Minor firmware release 1.18.2
I'm sorry, I forgot that M122 doesn't display WiFi stats in firmware versions prior to 1.19. To get the stats in 1.18 and earlier you need to send M552 S0 from USB to disconnect the network, then send M552 S1 and wait for the connect response.
it now says; Wifi Server stopped
So you need to send M552 S1 to start it.
says;
DuetWifiServer v 1.03(ch fork)
wifi vcc 3.14v, host name;
duetwwifi, reset reason: Turned on by main processor
Wifi is running as an access point with name
DuetWiFi -
but i cant connect using the ip address or the name duetwifi
If it's running as an added point then it's failed to connect to your WiFi network. You need to connect to it from a smartphone, tablet or laptop instead of to your usual WiFi router, to set up the SSID and password stored in the WiFi module. See https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_Z_using_a_Z_probe and start in particular steps 7 to 10.
Have obtained ip address on cell phone. There is no step for entering the SSID. Unable to make work.
I think i'll just abort this procedure. I have a ir probe coming tomorrow. If i install that and then change firmware to the 1.19 beta, will i overcome the z endstop issue? Also having difficulty locating that download again. Do you have a link to it?
Thank
Brian
Do you have anyone who lives near you that has the Duet boards that could possibly help you?
Where are you based?
Doug
I'm in western Canada, not much help in these parts. My z probe arrived so maybe i'll have more success. Now if i can find that link to v 1.19 beta.
