Minor firmware release 1.18.2
I tried to upgrade to this firmware release in hopes it might fix my endstop troubles. It installs but when running the SetNetwork command it shows error: M587 unsupported command. So i cant get connected to the web control.
See https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md for what has been fixed.
That's because you were previously running a 1.19 beta version. You should go back to using the beta if it was working well for you. The bug fixes in version 1.18.2 were already implemented in the 1.19 beta.
But it wasnt working for me. And with the 1.18.2, it is working! So is there anything i can do to initiate the wifi?
Which version of DuetWiFiServer are oh running? It should be 1.03-ch to go with main firmware 1.18.2.
yes, 1.03-ch, all three files downloaded from site.
duetwebcontrol 1.15a
duetwififirmware 1.18.2
duetwifiServer 1.05-ch -
I've just released firmware 1.18.2 (stable) at https://github.com/dc42/RepRapFirmware/releases.
Installed over 1.18.1. Did a few simple test prints on my T3P3 Kossel Mini. All seems good.
John
duetwifiServer 1.05-chI presume you mean 1.03-ch.
If you send M122 from a USB host program, what does it show as the wifi status?
M 122 command; it reads;
Network
WifiServer is running
SPI underruns 0, overruns 0
===Webserver===
HTTP sessions: 0 of 8 -
I'm sorry, I forgot that M122 doesn't display WiFi stats in firmware versions prior to 1.19. To get the stats in 1.18 and earlier you need to send M552 S0 from USB to disconnect the network, then send M552 S1 and wait for the connect response.
it now says; Wifi Server stopped
So you need to send M552 S1 to start it.
says;
DuetWifiServer v 1.03(ch fork)
wifi vcc 3.14v, host name;
duetwwifi, reset reason: Turned on by main processor
Wifi is running as an access point with name
DuetWiFi -
but i cant connect using the ip address or the name duetwifi
If it's running as an added point then it's failed to connect to your WiFi network. You need to connect to it from a smartphone, tablet or laptop instead of to your usual WiFi router, to set up the SSID and password stored in the WiFi module. See https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_Z_using_a_Z_probe and start in particular steps 7 to 10.
Have obtained ip address on cell phone. There is no step for entering the SSID. Unable to make work.
I think i'll just abort this procedure. I have a ir probe coming tomorrow. If i install that and then change firmware to the 1.19 beta, will i overcome the z endstop issue? Also having difficulty locating that download again. Do you have a link to it?
Thank
Brian
Do you have anyone who lives near you that has the Duet boards that could possibly help you?
Where are you based?
Doug
I'm in western Canada, not much help in these parts. My z probe arrived so maybe i'll have more success. Now if i can find that link to v 1.19 beta.
