Tool-change end-stop?
For a tool-change device, I need to move Y-axis towards the tool-change location till an end-stop is triggered. That end-stop is not Y-axis end-stop but an additional one.
How can I achieve that? Let us assume that the additional end-stop belongs to U-axis.
A solution, ideally, should not change Y axis location information for future moves (so machine does not need to be homed in Y-axis after completing this move).
I am using version 2.05 but I guess I could upgrade my Duet 2 Wifi to a newer version if needed.
Thanks a lot,
misan
Using RRF3 makes endstop and pin assignments a lot more flexible.
I'm not sure exactly how this is arrange though. The Y axis needs to move to a separate endstop than the Y axis?
But you say it's the U axis?
diagram? photo?
Y-axis has its own end-stop for homing purposes.
But when Y-axis moves to "dock" the tool changer there is another end-stop involved (the input I am planning to use is U-axis end-stop, but I could use any other input if better).
Y-axis homing works as expected, and each time a tool change I have to send the Y-axis back (at a certain X location) so it will engage with the tool changer. I am backing the Y-axis for that purpose until the carriage "contacts" with a special end-stop for that only purpose.
One approach that seems possible is to change config as if now the Y-axis has to use this new end-stop and then to do a homey.g, but that approach would alter the Y-axis coordinates (nothing that could be fixed) doing a new (and now proper) home of Y-axis now using the real Y-axis end-stop (at a different X-location so I am not knocking down the tool-change mechanism).
But I wonder if there is another way to achieve a similar result that would not alter the Y-axis origin of coordinates.
Thanks a lot,
misan
P.S: drawing is coming soon -
@misan said in Tool-change end-stop?:
The latest RRF beta builds have a new H4 option on the G1 command, which stops when an endstop is triggered without affecting the origin.
You can also use a G1 H3 command, which stops when an endstop is triggered and changes the corresponding M208 limit to the current position. Then use M208 to reset the limit.
Here you have a picture of the setup. Both X and Y axes have end-stops for homing purposes.
A third end-stop is located in the tool changer in a way that detects when the carriage bumps into it (due to tolerances and the need of some contact force the Y coordinate may change from one operation to the next one, thus the need of an end-stop here instead of using a pre-determined fixed Y coordinate for that move).
@dc42 I see the usefulness of H4 option (it does the homing move without affecting the origin, which is what I needed). But, I guess I need to temporarily change Y-axis home end-stop source for that coupling move. How can I do that?
Thanks a lot,
misan
Oops, my edit is being flagged as spam, maybe I attempted too many edits after the post (just trying to fix the typos
Use the M574 command. Don't forget to set it back to the original value as in config.g afterwards.
Thanks @dc42 . At any rate, it has to be RRF3, right?
I can see M574 has a pin definition parameter in RRF3 that is perfect for my needs here.
Yes, because RRF2 doesn't allow you to swap endstop pins around.
