PanelDueFirmware 3.2.2 released
@Caveman What version of firmware are you running on the Duet?
@wilriker said in PanelDueFirmware 3.2.2 released:
This release is compatible with RepRapFirmware 3.2-beta1 or later. It will partially work with RepRapFirmware 3.1.1 but not with any older version.
3.2 beta3
@Caveman Can you please flash PanelDueFirmware again and see if this problem still exists?
Also please make sure that the baud rate you configured on your Duet with
M575
matches the baud rate set on your PanelDue. And of course that you enabled the Aux port viaM575
in the first place.If that still does not work please connect a USB cable to your Duet, connect via serial terminal (if necessary see guide for initial Duet setup for instructions on how to do that) and issue
M111 P3 S1
You should see
M409
commands coming in on channelAux
RunM111 P3 S0
before disconnecting USB.
If you don't please return here and provide your
config.g
as well as the output ofM122
Fixed with a reflash, strange tried that also yesterday but did not work. Fixed for now! thanks
I am pleased to announce the release of PanelDueFirmware 3.2.2. Please excuse the inconvenience with broken 3.2.1.
New and changed features:
- Provide interface for RepRapFirmware to reset as well as erase and reset the PanelDue
Does this mean updating PanelDue firmware will be possible via DWC down the road?
@Exerqtor said in PanelDueFirmware 3.2.2 released:
I am working on that. But due to hardware limitations it will only work for v3 boards and 5i/7i. So much limitation I can already put forward.
@wilriker
Sweet! Given how cheap the V3 boards are it's not unobtainable for anyone atleast -
I have a problem about on screen keyboard. I pressed any letter but no any visible feedback. When i close and re open keyboard all pressed letter can visible.
My board V3 and 7" -
@cgcafer Thanks for reporting. I can reproduce this issue. Actually that's a bug I already fixed in one of the 3.2.0 RCs but it seems to have returned.
Thanks for your answer, i have also another problem that is about V2 board and 5"LCD.
it has no problem with V1.24 but not V3.2.2. It seems to like about lcd timing problem. -
@cgcafer I found the bug with the command input (actually a different problem to what I fixed in the RCs) and fixed it. I will release this probably later today.
Can you explain that with a bit more detail, please?
I can also atest for the on screen keyboard acting up. If i write something it won't show up unless i hit backspace.
@Exerqtor Thanks, I found and fixed that. I am right now working on improving overall update rate and will then release a new version.
@cgcafer said in PanelDueFirmware 3.2.2 released:
https://drive.google.com/file/d/1JUmpmnN39RU9hgvowxu67gGC0sFneF2J/view?usp=sharing
https://drive.google.com/file/d/1BLFRYAHmChkUitGM5Tn8wXyLXaf9cAyy/view?usp=sharing
All V3 same resultThanks for reporting. I will analyze this issue but it may take a while. Sorry, I cannot give you a more short-term answer.
I have now released PanelDueFirmware 3.2.3. Please continue in this thread.
@cgcafer Please check the latest release of PanelDueFirmware 3.2.4 if that fixes your issues on your V2 board.
