    Yet more conditional gcode help required
    Gcode meta commands
    1.7k
      dc42 administrators @deckingman
      That's the right approach, however the if..elif statements are not right. Try something like this:
          if sensors.gpIn[5].value=0           ; if left button down
              if sensors.gpIn[7].value=0       ; if joystick left and forward
      	    G1 ...
      	elif sensors.gpIn[8].value=0     ; if joystick left and backwards
      	    G1 ...
              else                             ; just left
      	    G1 ...
          elif sensors.gpIn[6].value=0         ; right button down
      	if sensors.gpIn[7].value=0       ; joystick right and forwards
      	    G1 ...
              elif sensors.gpIn[8].value=0     ; joystick right and backwards
      	    G1 ...
              else                             ; just right
      	    G1 X1 U1 A1
          elif sensors.gpIn[7].value=0         ; if just forwards
      	G1 ...
          elif sensors.gpIn[8].value=0         ; if just backwards
      	G1 ...
      You could also add an "else break" at the end, then you wouldn't need to test all the buttons in the while-part.
      deckingmanundefined OwenDundefined 2 Replies Last reply Reply Quote 0
        deckingman @dc42
        @dc42 Thanks. That looks good. From my very limited knowledge, I can see that would be "conflict free" compared to what I had.
        @all. Thanks for the input everyone - much appreciated. It'll be a couple of days or so before I get time to get the hardware and wiring sorted. Then I'll either report back with a successful outcome, or I'll be asking for more help........
        • OwenDundefined
          OwenD @dc42
          @dc42 said in Yet more conditional gcode help required:
          If he removes the while test of all pins, wouldn't the macro only trigger once (when a switch signal rose/fell)
          Or do you just mean use "while true" instead (hence the break statement )
          I'm always reluctant to use potentially infinite loops.
            Yes I meant use "while true". Or if you don't like infinite loops, "while iterations < 1000" or similar.
            OwenDundefined 1 Reply Last reply Reply Quote 0
            • OwenDundefined
              OwenD @dc42
              @dc42 Thanks for clarification.
              I might have locked up a few machines over the years with my clumsy work when using loops.
              I realise it's a valid method for those that think things through more than me before they press "executive" edit: "execute" (Stupid iPhone!!!) 😆
                deckingman
                Err, in view of the above and as a further sanity check on my understanding, here is the full macro that I intend to start with ........
                G91; Set relative
                M400; wait for any moves to finish
                G1 F6000 ; set feedrate to 100mm/sec
                while sensors.gpIn[5].value=0 | sensors.gpIn[6].value=0 | sensors.gpIn[7].value=0 | sensors.gpIn[8].value=0
                	if sensors.gpIn[5].value=0; joystick left
                		if sensors.gpIn[7].value=0 ; joystick left and forwards
                			M400
                			G1 X-1 U-1 A-1 Y-1 V-1 B-1
                		elif sensors.gpIn[8]; joystick left and backwards
                			M400
                			G1 X-1 U-1 A-1 Y1 V1 B1
                		else ; joystick left only
                			M400
                			G1 X-1 U-1 A-1
                	elif sensors.gpIn[6].value=0; joystick right
                			M400
                			G1 X1 U1 A1 Y-1 V-1 B-1
                		elif sensors.gpIn[8]; joystick right and backward
                			M400
                			G1 X1 U1 A1 Y1 V1 B1
                		else ; joystick right only
                			M400
                			G1 X1 U1 A1
                	elif sensors.gpIn[7].value=0 ; joystick forwards only
                		M400
                		G1 Y-1 V-1 B-1
                	elif sensors.gpIn[8].value=0 ; joystick backward only
                		M400
                		G1 Y1 V1 B1
                	else break
                Is that about right?
                • OwenDundefined
                  OwenD
                  To clarify my comments.
                  A "while" statement will loop if the condition test is true.
                  In your case by testing all those inputs.
                  If you put
                  while true
                    G1 X1
                  Then you have an endless loop as true always equals true, so you're going to crash.
                  Therefore you must ensure that you put a test in somewhere the calls "break" to get you out of the loop.
                  In the suggested code above that test is satisfied when none of the IF statements resolve to true, so break is called.
                    deckingman
                    OK, so that's all wired up and working. It does what I hoped it would and it respects the axis limits too (of course it does - I never doubted it would 🙂 ).
                    But I'd like to add an embellishment if possible. I've used 1mm as a movement length which is great for reasonably precise positioning but naturally, it's a bit slow if I want to travel the full 400mm or so of axis travel. Increasing the step size to (say) 5mm is about right but then I lose precision. So what I'd like to do is a bit like how one sets the time on some digital clocks. That is to say, the longer one holds the button, the faster the time changes.
                    So I'd like to alter the code so that if I hold the joystick in one position, it will move in 1mm increments but after (say) 5 iterations, the move length will increase to (say) 5mm). Ideally I'd like to do something a bit more sophisticated still, like keep increasing the move length the longer the joystick is held in one position but I'll settle for just a binary change after say 5 iterations of the same move.
                    Here is the code that I have now (without the errors that I had in some of the elif commands when I last posted it 🙂 )
                    G91; Set relative
                    M118 S"Trigger 5 - Joystick"
                    			M400
                    			echo "Left and forward"
                    		elif sensors.gpIn[8].value=0; joystick left and backwards
                    			M400
                    			echo "Left and backwards"
                    			M400
                    			G1 X-1 U-1 A-1
                    			echo "Left"
                    			M400
                    			echo "Right and forward"
                    		elif sensors.gpIn[8].value=0; joystick right and backward
                    			M400
                    			echo "Right and backwards"
                    			M400
                    			G1 X1 U1 A1
                    			echo "Right"
                    		M400
                    		G1 Y-1 V-1 B-1
                    		echo "Forward"
                    		M400
                    		G1 Y1 V1 B1
                    		echo "Backwards"
                    	else break
                      You could use the built-in 'iterations' variable to adjust the movement amount and/or speed.
                        deckingman @dc42
                        Thanks. Would I be right in assuming the "iterations" is a counter which increments by 1 every time the while loop runs?
                        Scratch that - found it.
                          deckingman
                          That's all working now although the code is a bit "clunky".
                          I'm guessing that once variables are introduced, I ought to be able to do something like ....
                          MoveAmount= 0.5+(iterations/5)
                          G1 X MoveAmount..............
                          .......or some such. Anyway, this is what I've ended up with which may not be elegant but works.
                          G91; Set relative
                          G1 F3000 ; set feedrate to 100mm/sec
                          			M400
                          			if iterations<3
                          				G1 X-0.5 U-0.5 A-0.5 Y-0.5 V-0.5 B-0.5
                          			elif iterations<5
                          			elif iterations<7
                          				G1 X-2 U-2 A-2 Y-2 V-2 B-2
                          			elif iterations<9
                          				G1 X-5 U-5 A-5 Y-5 V-5 B-5
                          			elif iterations<11
                          				G1 X-10 U-10 A-10 Y-10 V-10 B-10
                          			else
                          				G1 X-20 U-20 A-20 Y-20 V-20 B-20
                          			M400
                          			if iterations<3
                          				G1 X-0.5 U-0.5 A-0.5 Y0.5 V0.5 B0.5
                          			elif iterations<5
                          			elif iterations<7
                          				G1 X-2 U-2 A-2 Y2 V2 B2
                          			elif iterations<9
                          				G1 X-5 U-5 A-5 Y5 V5 B5
                          			elif iterations<11
                          				G1 X-10 U-10 A-10 Y10 V10 B10
                          			else
                          				G1 X-20 U-20 A-20 Y20 V20 B20
                          			M400
                          			if iterations<3
                          			elif iterations<5
                          				G1 X-1 U-1 A-1
                          			elif iterations<7
                          				G1 X-2 U-2 A-2
                          			elif iterations<9
                          				G1 X-5 U-5 A-5
                          			elif iterations<11
                          				G1 X-10 U-10 A-10
                          			else
                          				G1 X-20 U-20 A-20
                          			M400
                          			if iterations<3
                          				G1 X0.5 U0.5 A0.5 Y-0.5 V-0.5 B-0.5
                          			elif iterations<5
                          			elif iterations<7
                          				G1 X2 U2 A2 Y-2 V-2 B-2
                          			elif iterations<9
                          				G1 X5 U5 A5 Y-5 V-5 B-5
                          			elif iterations<11
                          				G1 X10 U10 A10 Y-10 V-10 B-10
                          			else
                          				G1 X20 U20 A20 Y-20 V-20 B-20
                          			M400
                          			if iterations<3
                          				G1 X0.5 U0.5 A0.5 Y0.5 V0.5 B0.5
                          			elif iterations<5
                          			elif iterations<7
                          				G1 X2 U2 A2 Y2 V2 B2
                          			elif iterations<9
                          				G1 X5 U5 A5 Y5 V5 B5
                          			elif iterations<11
                          				G1 X10 U10 A10 Y10 V10 B10
                          			else
                          				G1 X20 U20 A20 Y20 V20 B20
                          			M400
                          			if iterations<3
                          				G1 X0.5 U0.5 A0.5
                          			elif iterations<5
                          				G1 X1 U1 A1
                          			elif iterations<7
                          				G1 X2 U2 A2
                          			elif iterations<9
                          				G1 X5 U5 A5
                          			elif iterations<11
                          				G1 X10 U10 A10
                          			else
                          				G1 X20 U20 A20
                          		M400
                          		if iterations<3
                          				G1 Y-0.5 V-0.5 B-0.5
                          			elif iterations<5
                          				G1 Y-1 V-1 B-1
                          			elif iterations<7
                          				G1 Y-2 V-2 B-2
                          			elif iterations<9
                          				G1 Y-5 V-5 B-5
                          			elif iterations<11
                          				G1 Y-10 V-10 B-10
                          			else
                          				G1 Y-20 V-20 B-20
                          		M400
                          		if iterations<3
                          				G1 Y0.5 V0.5 B0.5
                          			elif iterations<5
                          				G1 Y1 V1 B1
                          			elif iterations<7
                          				G1 Y2 V2 B2
                          			elif iterations<9
                          				G1 Y5 V5 B5
                          			elif iterations<11
                          				G1 Y10 V10 B10
                          			else
                          				G1 Y20 V20 B20
                          	else break
                            Another way is to use your original code but replace all the XYUVABC coordinates in the G1 commands by calculated values, something like this:
                            G1 X{0.5+0.1 * iterations} Y{-(0.5+0.1 * iterations)} ...
                              deckingman @dc42
                              Ahhh - that looks good! I tried something similar but it didn't work - because I used plain braces rather than curly ones. I'll give that a go..............
                                deckingman
                                For the sake of completeness, here is the final code that I ended up using. After playing around with it, I ended up using just G1 X{0.5+interations}........etc, rather than using fraction's of "iterations".
                                G91; Set relative
                                			M400
                                			G1 X{-(0.5+iterations)} U{-(0.5+iterations)} A{-(0.5+iterations)} Y{-(0.5+iterations)} V{-(0.5+iterations)} B{-(0.5+iterations)}
                                			M400
                                			G1 X{-(0.5+iterations)} U{-(0.5+iterations)} A{-(0.5+iterations)} Y{0.5+iterations} V{0.5+iterations} B{0.5+iterations}
                                			M400
                                			echo "Left"
                                			M400
                                			G1 X{0.5+iterations} U{0.5+iterations} A{0.5+iterations} Y{-(0.5+iterations)} V{-(0.5+iterations)} B{-(0.5+iterations)}
                                			M400
                                			G1 X{0.5+iterations} U{0.5+iterations} A{0.5+iterations} Y{0.5+iterations} V{0.5+iterations} B{0.5+iterations}
                                			M400
                                			echo "Right"
                                		M400
                                		G1 Y{-(0.5+iterations)} V{-(0.5+iterations)} B{-(0.5+iterations)}
                                		echo "Forward"
                                		M400
                                		G1 Y{0.5+iterations} V{0.5+iterations} B{0.5+iterations}
                                		echo "Backwards"
                                	else break
                                Thanks for all the help guys.
                                  deckingman
                                  For further completeness, I've added a "turbo button". So instead of increasing the distance using "iterations", I simply press the button in conjunction with moving the joystick. What that does is move the gantries 20mm if the button is pressed or 0.5mm if it isn't. I prefer this method but either one works.
                                  I've also wrapped the entire thing in a "if state.status != "processing"" statement (thanks for the suggestion @T3P3Tony). What that does is checks to make sure that a print is NOT in progress which will do what the M581 R2 parameter will do in the next firmware. Here is that version of the code
                                  if state.status != "processing" ; make sure that a print is NOT running
                                  	G91; Set relative
                                  				M400
                                  				if sensors.gpIn[4].value=0 ; check for long move button press
                                  				else
                                  				M400
                                  				else
                                  				M400
                                  				echo "Left"
                                  					G1 X-20 U-20 A-20
                                  				else
                                  					G1 X-0.5 U-0.5 A0.5
                                  				M400
                                  				else
                                  				M400
                                  				else
                                  				M400
                                  				echo "Right"
                                  					G1 X20 U20 A20
                                  				else
                                  					G1 X0.5 U0.5 A0.5
                                  			M400
                                  			echo "Forward"
                                  				G1 Y-20 V-20 B-20
                                  			else
                                  			M400
                                  			echo "Backwards"
                                  				G1 Y20 V20 B20
                                  			else
                                  				G1 Y0.5 V0.5 B0.5
                                  		else break
                                  else break
                                  appjawsundefined 1 Reply Last reply Reply Quote 2
                                  • appjawsundefined
                                    appjaws @deckingman
                                    @deckingman I have followed this with interest but then I thought what was the actual problem? When I use the XY buttons in DWC my main XY and UV carriages move together and in sync. Have I not understood the problem?
                                    appjaws - Core XYUV Duet Ethernet Duex5
                                    firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                                    Ormerod 1-converted to laser engraver, Duet wifi
                                    OpenSCAD version 2024.03.18
                                    Simplify3D 5.1.2
                                      deckingman @appjaws
                                      @appjaws said in Yet more conditional gcode help required:
                                      Hiya. I've changed things around a bit so that I no longer combine the axes after homing. So the DWC buttons only work for individual axes. i.e. XY moves will only move the hot end - not the hot end and extruder gantry (as they used to do when the axes were combined)
                                      The reason being that I've exploited the fact that, because the extruders are connected to the hot end via short Bowden tubes, that extruder gantry doesn't have to exactly follow the hot end gantry. It doesn't have to replicate every tiny move that the hot end does - it only has to follow it within an allowable tolerance. So if there are small features (say a hole or a cylinder) then I can "park" the extruder gantry in the centre of that feature and let it sit there while the hot end does all those short moves which make that feature. The same applies to other short zig-zag type moves where the extruder gantry sits still while the hot end does the short zig-zags.
                                      I made a couple of YouTube videos which explain it in a bit more detail
                                      https://www.youtube.com/watch?v=rOP9QYAlhZU
                                      and
                                      https://www.youtube.com/watch?v=mTPV3Ss1D-4
                                      So that's the reason why the axis button on DWC are no longer much use to me. A fuller explanation of what I wanted the joystick to do, and how that works in practice is here
                                      https://www.youtube.com/watch?v=wCR5Ao0iH-c
                                      • appjawsundefined
                                        appjaws
                                        Hi again,
                                        Very impressive videos @deckingman . Is it possible to have a copy of your python script that generates the movement please.
                                        My machine really vibrates during short movements so your solution should solve it for me.
                                        Simplify3D 5.1.2
                                          deckingman @appjaws
                                          @appjaws Sure. It's been a few years since we last communicated. Is your email address still the one ending ......ve.co.uk? If not, pm me with the address to use.
                                          Be aware, that it's quite a lot of work to run the machine in "true" CoreXYUV mode. You need to change all you homing files so that they do not re-combine the axes, and change the "P" parameter in M581 so that the 5 axes are visible. Also any macros or gcode start and end scripts that have XY moves will need to be changed to incorporate XYUV moves.
                                          Also be aware that, although the python code gets the job done, I'm not a writer of code, so it ain't pretty.
                                          • appjawsundefined
                                            appjaws
                                            @deckingman Yes same email address.
                                            I was wondering if I could just change the XYUV to be individual just during a print similar to the way homeall.g works.
                                            M584 X0 U3 Y1 V4 Z7:8:9 E2:5:6 P5 ; temporarily separate and map drives to U and V axes
                                            complete the modified gcode part file using separate XYUV axes
                                            M584 X0:3 Y1:4 Z7:8:9 U10 V11 E2:5:6 P3 ; put motor mapping back to normal so that X uses drives 0 and 3 Y uses 1 and 4
                                            then once the printed part is removed from the bed run homeall.g
                                            can you see any problems with this?
                                            Thanks for your help
                                            Simplify3D 5.1.2
                                            deckingmanundefined 2 Replies Last reply Reply Quote 0
