Thermocouple problems
The other lines are, the stepper, fans and the 230volt heater bands. BUT these are all turned off while I was testing. It would be surprising if this causes EMI. I also did a test while unplugging the fans and plugging them in, but that didn't give any changes, so I think EMI is out of the question.
The voltage drop is something I will check out tomorrow, that will clear up a lot I think.
Thanks!
BTW I also use the breakout board, could that also be an issue?
@stienfromarden I was wrong on the daughter boards comms - they use an SPI interface to the main board. A quick google suggests that this has a useable distance limit of 5-10m so my guess is that's your culprit (anyone who knows more feel free to correct me if this is wrong!).
Fair point on the EMI, though I've always found in an elusive beast. Could even be something else in the room? With the steppers, were they definitely off, or just in Idle mode? although the current is low in idle mode (default is usually 30% in RRF, but you may have set different), it can still be something (and particialry with long wires cause issues!). I was meaning actually unplugging the stepper wires from the Duet to be sure/because I'm a mech-y and don't trust electronics...
I don't see how having the expansion breakout board should impact things (as you're connecting the daughterboads to the main board), but it can't hurt to unplug it and try?
The SPI signal could be the problem, but I am reading 10 meter maximum and I run 6 meter...
I don't think EMI is the problem because when I tested the thermocouples on the daughterboard directly on the Duet, although the tc was running through a lot of wires in the electronicsbox there wasn't any EMI. Or maybe it is in the 10 wire cable in between the daughterboard and duet..
What could be an option is to extend the thermocouple wires... but that is an expensive guess....
https://nl.rs-online.com/web/p/thermocouple-extension-wire/3706228/
ok there are no voltage drops at the beginning and end of the cable, I meassure 2,98 at both sides.
I figured out that moving the connections a little changes the reading, sometimes to the ambient temperature, I will receive some plugs to fit the daughterboard and duet, maybe this will help some!
While SPI as a protocol may be ok up to 10m in some situations, the SPI bus voltage and frequency we use is not. I recommend extending the thermocouple wires. Its probably wise to shield the thermocouple wires as well over that length of run.
I decided to just go with some pt1000 sensors:
https://nl.rs-online.com/web/p/platinum-resistance-temperature-sensors/1005972/
It's just too much trouble for a bit faster response time and accuracy.... extending the cables of the tc will cost more then switching to pt1000 sensors
Is it an option te reuse the type j termocouple wires to extend the pt1000? just for about 20cm to reach the termination box? these wires are steel braided and can handle some high temperature..
@stienfromarden said in Thermocouple problems:
Doing so will introduce a small temperature error. The size of that error will depend on the temperature difference between the two ends of that thermocouple wire. It may be insignificant, I haven't done the sums.
@dc42 said in Thermocouple problems:
@dc42 thank you very much for the answer!
I did not now if these:
https://docs.rs-online.com/f7e6/0900766b8155404c.pdf
pt1000's were ok I don't know much about them but I hope it will work! Can't wait to power up the extruder an PRINT!
Any PT1000 should be OK as long as it is electrically isolated from the hot end metalwork.
