Duex4 v0.2a (with Duet 0.6)
Ok, small update.
- I localized the pins I should use: Pin: 23, Label: PC21, DuePin: D9, RepRapFirmwareUsage: heat[5] / E4_PWM.
- From: https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins#Section_Logical_pin_numbers
- Although it doesnt mention Duex4 explicitly, the info on Duex2 and Duex5 I guess E4_PWM is logical pin number 6:
- 3-7 seem to be available for heaters on expansion board
- this is the 4th one (so 3 + (4 -1) = 6)
Does this make sense ?
@sylvaindc said in Duex4 v0.2a (with Duet 0.6):
I'll be having some fun with these documents. I'll document my findings here in case some archeologist ever stumbles over the 3rd known Duex4
Quick question that remains is a hardware one, can I just hook up the 24v fan to the heater pins, or do I need to add a cap in parallel or something to ensure proper PWM?
Just hook it up.
@dc42 said in Duex4 v0.2a (with Duet 0.6):
I have @dc42's IR leveling meter hooked up to my Duet 0.6, using a pin on the expansion header https://miscsolutions.files.wordpress.com/2015/05/duet0-6-brd_0-781.png (Pin AD12 if I'm not mistaken). Does that just loop through to AD12 on the J7 EXPANSION1 header of the Duex4?, or should I find an other solution?
AFAIR, it just loops through.
Update: according to http://blog.think3dprint3d.com/2015/04/duex4-v02a-minor-updates.html AD12 does not loop through ( I guess it used to on the previous board). It is now exposed via the J16, which is the same jumper as we connect the ground wire to.I can confirm that the IR sensor works as it should via the Duex4 board.
Just hook it up.
Sadly the 24v fans are still in the mail, but I went ahead and set it up in config.g:M106 P0 T45 H1 S255 L1.0 ; Existing fan on main Duet0.6 board M307 H6 A-1 C-1 D-1 ; Disable Heater 6 M106 P1 H1 S255 L0 A6 ; Reuse Pin: 23, Label: PC21, DuePin: D9, RepRapFirmwareUsage: heat[5] / E4_PWM as Fan
Sadly I dont see any change to the web frontend. I can only see one fan, and only if I select Tool 0.
Is there a way to see all fans in the web front-end?
You won't see thermostatically controlled fans on the web interface.
@Phaedrux said in Duex4 v0.2a (with Duet 0.6):
Cool, that explains it! -
The plot thickens...
I hooked up the Duex4, IR probe work, but the Stepper on E1 doesnt.So I decided to do a M115:
m115 FIRMWARE_NAME: RepRapFirmware for Duet FIRMWARE_VERSION: 1.26.1 ELECTRONICS: Duet 0.6 FIRMWARE_DATE: 2020-02-09b1
My Google-fu showed a few people who had the same issue, but I cant find a solution... Does anyone have an idea, am I doing something wrong, or is the Duex4 just no longer supported in 1.26?
Can you pos the results of M122?
Sure thing!
M122 === Diagnostics === RepRapFirmware for Duet version 1.26.1 running on Duet 0.6 Used output buffers: 1 of 16 (16 max) === System === Static ram: 44212 Dynamic ram: 42732 of which 3168 recycled Stack ram used: 1080 current, 2564 maximum Never used ram: 5628 === Platform === Last reset 00:09:12 ago, cause: power up Last software reset at 2020-10-22 23:03, reason: User, spinning module GCodes, available RAM 5004 bytes (slot 0) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0xffffffff Error status: 4 Free file entries: 10 SD card 0 detected, interface speed: 21.0MBytes/sec SD card longest block write time: 12.3ms, max retries 0 MCU temperature: min 10.0, current 26.8, max 27.3 Date/time: 2020-10-22 23:23:27 Slowest loop: 69.21ms; fastest: 0.10ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0, FreeDm: 100, MinFreeDm: 100, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === DDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Stack records: 1 allocated, 0 in use Movement lock held by null http is ready with "M122 " in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Free connections: 15 of 16 Free transactions: 23 of 24 Locked: 0, state: 4, listening: 20071bf4, 0, 20071bd8
So the IR probe is connected to the duex4 and works? But the stepper doesn't?
Yea, but that is not so strange given that AD12 just physically loops to the J16 connector.
I'm starting to think I need to tell the board or the firmware that the Duex4 is connected
There have been no intentional changes to the DueX4 support, but it hasn't been tested for many versions. Have you tried the other motor outputs on the DueX4?
RRF does not detect the DueX4 the way that it detects a DueX5, so you will not see it reported in the M115 response.
@dc42 Thanks for your response, let me try the other ports
