Duet3D PCB delta printer effector sneak preview
So the big question is when to expect availability on this seemingly very cool and precise product development?
Once you make a defined scheduled, circumstances beyond your control will always delay it three to six months!
Haha good ol' Murphy hard at work…
I'm also very interested in this as I may need to replace the somewhat bulky aluminum effector on my TEVO delta in order to fit a DyzEnd-X hotend. In the meantime I'm going for a hacky solution.
Last week we agreed the new heatsink design with E3D. So production will start soon.
Pre order any time soon?
The PCB effector uses two connectors, one for signal wires and one for power wires. This is to reduce the risk of mis-wiring causing a short. A magnetic connector might work for the signal wires, but I doubt that it could be used for the power wires.
still requires wire but here is an example of magnetic quick change tools with what appears to be USB for quick disconnect.
Phoenix Contact also makes some hybrid quick connect plugs and cables that run power and signal through a single cable
Can you provide a link to the specific range of connectors?
the connectors are sold as just connector or connector with cable factory soldered in various lengths. I used some of their products on my CNC machine, top quality stuff allowing compact design.
They also work with different industries to make specialty terminal blocks and connectors. You might have some luck getting a hybrid connector made for 3d printers that uses the M8 profile if you do not need all the contacts that the M12 provides.
Thanks. Those are nice looking connectors, but at more than £25 per pair, too expensive for us to consider using.
Always more than one way to skin a cat, I have not dug into any of these but it appears there are other options as well as some china knock off versions:
Not sure on pricing but lumbergautomation (Belden) makes a similar plug as well
they are also very bulky for installing on a effector and I suspect have considerable more mass than a pair of Molex headers which are probably just as quick to disconnect!
Cant you just use a suitable IDC connector for both signal and power
IDC isn't suitable for hotends, as they can draw 3.3 amps, even 5 amps in the case of some 60 watt cartridges.
I was thinking along the lines of doubling up spreading the load across the connectors, 24v on a 60 watt heater cartridge comes out at 2.5 amps so if you use for example
16 way flat ribbon cable 28 AWG (7x36) Stranded 300V that should work.Just in the same way some are powering nema 17's with CAT5/6
But hey I'm a Mech Eng not Electrical….
