Duet3D PCB delta printer effector sneak preview
Just wanted to stop in and say this is looking fabulous. I've been looking for a solution to house multiple tool heads with quick disconnects and this looks perfect for that.
A couple of features I'd really like to see:
1. A single connector on the back that can be universal for all the different tool heads (hot end, laser, cnc, touch probe, etc)
2. That single connector is a magnet style both for safety and for a quick change.
3. I'd like for the rods to carry current either for the connections needed (there are 6 connectors) or for fault-tolerant break detection.
4. a purple color from osh?Again really good work and thanks for sharing. If there's a beta or early product tester program sign me up.
i vote for magnetic quick change too. as for connector - if i change tool, how than board will differentiate which tool is connected?
if it does then firmware may automatically adapt for the tool. -
The PCB effector uses two connectors, one for signal wires and one for power wires. This is to reduce the risk of mis-wiring causing a short. A magnetic connector might work for the signal wires, but I doubt that it could be used for the power wires.
Apple shoves 85w through Magsafe!
Have you seen the repair percentage on apple products power circuit ? a prime example of what NOT to do…......
So the big question is when to expect availability on this seemingly very cool and precise product development?
Once you make a defined scheduled, circumstances beyond your control will always delay it three to six months!
Haha good ol' Murphy hard at work…
I'm also very interested in this as I may need to replace the somewhat bulky aluminum effector on my TEVO delta in order to fit a DyzEnd-X hotend. In the meantime I'm going for a hacky solution.
Last week we agreed the new heatsink design with E3D. So production will start soon.
Pre order any time soon?
still requires wire but here is an example of magnetic quick change tools with what appears to be USB for quick disconnect.
Phoenix Contact also makes some hybrid quick connect plugs and cables that run power and signal through a single cable
Can you provide a link to the specific range of connectors?
the connectors are sold as just connector or connector with cable factory soldered in various lengths. I used some of their products on my CNC machine, top quality stuff allowing compact design.
They also work with different industries to make specialty terminal blocks and connectors. You might have some luck getting a hybrid connector made for 3d printers that uses the M8 profile if you do not need all the contacts that the M12 provides.
Thanks. Those are nice looking connectors, but at more than £25 per pair, too expensive for us to consider using.
Always more than one way to skin a cat, I have not dug into any of these but it appears there are other options as well as some china knock off versions:
