Common wiring to x carriage
Hi! Im using 2 cat 5e cables for all wiring to the x carriage. But now i realize this solution ends up with one wire to little.
So the question is, can i wire something with common ground/ vcc?
The functions needed is:
heater 4 wires (using 4 wires for more area)
termistor 2 wires
hotend cooler 2 wires (on when >60c)
part cooler 2 wires
stepper motor 4 wires
capacitive sensor 3 wires.
17 totalThe cat 5e has 8 cable giving me 16 total.
It must be possible to wire the fans to common ground/ vcc?
Any other suggestions?Thanks!
You can use a common positive (V_FAN) wire for both fans.
Ok, Thanks!
Can you post photos of the wiring solution? I am searching for wago terminals to wire the carriage, but any suggestion is welcome.
Thanks
