Error: attempting to extrude with no tool selected
ok, Nevermind... happened again. Here is the Diagnostic logs.
@dc42 I tested the resistance, and it is below 0.1. Also the wires are not near any stepper motors.m122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later Board ID: 08DJM-9178L-L2MS8-6JTDD-3S06N-98HLP Used output buffers: 3 of 24 (24 max) === RTOS === Static ram: 27980 Dynamic ram: 93556 of which 92 recycled Exception stack ram used: 528 Never used ram: 8916 Tasks: NETWORK(ready,308) HEAT(blocked,1224) MAIN(running,1788) IDLE(ready,80) Owned mutexes: === Platform === Last reset 00:43:59 ago, cause: software Last software reset at 2020-09-26 21:20, reason: User, spinning module GCodes, available RAM 9316 bytes (slot 2) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN Error status: 4 MCU temperature: min 33.0, current 35.7, max 36.1 Supply voltage: min 24.4, current 24.6, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: ok, SG min/max 0/205 Driver 1: ok, SG min/max 0/211 Driver 2: ok, SG min/max 0/201 Driver 3: standstill, SG min/max 0/193 Driver 4: standstill, SG min/max not available Date/time: 2020-09-26 22:04:29 Cache data hit count 4029131711 Slowest loop: 59.57ms; fastest: 0.14ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 8 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 5.1ms, write time 28.9ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 166, MinFreeDm: 101, MaxWait: 703770ms Bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves: 29343, completed moves: 29335, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.3 === GCodes === Segments left: 2 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 2 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 63.59ms; fastest: 0.00ms Responder states: HTTP(4) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.23 WiFi MAC address dc:4f:22:6e:60:44 WiFi Vcc 3.34, reset reason Unknown WiFi flash size 4194304, free heap 24568 WiFi IP address 192.168.1.253 WiFi signal strength -51dBm, reconnections 0, sleep mode modem Socket states: 2 2 0 0 0 0 0 0 === Filament sensors === Extruder 0 sensor: ok
I am still not sure what's happening here. Can someone please assist!?!?!?
Here is a download of all the Duet Config files.
https://www.dropbox.com/s/9okmtuly2bz2gmk/Duet Configs.zip?dl=0 -
2020-09-26 20:34:56 Event logging started 2020-09-26 20:35:36 Event logging stopped 2020-09-26 20:35:36 Event logging started 2020-09-26 20:37:30 Error: Bad command: :40 M409 F"d99f" 2020-09-26 20:40:06 Error: M409: expected string expression 2020-09-26 20:41:34 Error: Bad command: M<09 K"job" F"v" 2020-09-26 20:44:02 Warning: M9: Command is not supported 2020-09-26 20:46:18 Error: M409: control character in string 2020-09-26 20:49:23 Finished printing file 0:/gcodes/Test Prints - Calibration/support_test.gcode, print time was 0h 26m 2020-09-26 21:13:55 Event logging stopped 2020-09-26 22:00:42 Event logging started 2020-09-26 22:03:36 Error: Attempting to extrude with no tool selected. 2020-09-26 22:03:40 Error: Attempting to extrude with no tool selected. 2020-09-26 22:03:44 Error: Attempting to extrude with no tool selected. 2020-09-26 22:03:48 Error: Attempting to extrude with no tool selected. 2020-09-26 22:03:52 Error: Attempting to extrude with no tool selected. 2020-09-26 22:03:56 Error: Attempting to extrude with no tool selected. 2020-09-26 22:04:00 Error: Attempting to extrude with no tool selected. 2020-09-26 22:04:04 Error: Attempting to extrude with no tool selected. 2020-09-26 22:04:08 Error: Attempting to extrude with no tool selected. 2020-09-26 22:04:12 Error: Attempting to extrude with no tool selected. 2020-09-26 22:04:16 Error: Attempting to extrude with no tool selected. 2020-09-26 22:04:20 Error: Attempting to extrude with no tool selected. 2020-09-26 22:04:24 Error: Attempting to extrude with no tool selected. 2020-09-26 22:04:28 Error: Attempting to extrude with no tool selected. 2020-09-26 22:04:32 Warning: M489: Command is not supported 2020-09-26 22:04:32 Error: Attempting to extrude with no tool selected. 2020-09-26 22:04:36 Error: Attempting to extrude with no tool selected. 2020-09-26 22:07:36 Error: Bad command: O<09 F"d99f" 2020-09-26 22:15:16 Error: M409: control character in string 2020-09-26 22:17:01 Error: M409: expected string expression
Your error log shows some garbage commands. Either there is noise interfering or corruption on the SD card. Do you have another SD card to test with?
yes, let me try that.
I changed out the SD card with a new out of the box class 10 one. This was my output of the eventlog. The print did complete.
2020-09-27 00:25:13 Event logging started 2020-09-27 00:25:35 Error: Bad command: J184 M409 F"d99f"*71 2020-09-27 00:26:15 Error: M409: control character in string 2020-09-27 00:26:56 Warning: the height map was loaded when the current Z=0 datum was not determined probing. This may result in a height offset. 2020-09-27 00:31:03 Error: M409: control character in string 2020-09-27 00:36:36 Error: Bad command: s73 M409 F"d99f" 2020-09-27 00:36:37 Error: Bad command: `M409 F"d99f" 2020-09-27 00:36:38 Error: Bad command: >0M409 F"d99f"+72 2020-09-27 00:36:56 Warning: M609: Command is not supported 2020-09-27 00:37:00 Error: Bad command: M<09 F"d99f" 2020-09-27 00:37:06 Error: Bad command: ^403 M409 F"d99f"*77 2020-09-27 00:37:11 Error: M409: control character in string 2020-09-27 00:37:55 Error: M409: expected string expression 2020-09-27 00:38:19 Warning: M40: Command is not supported 2020-09-27 00:38:26 Warning: M429: Command is not supported 2020-09-27 00:41:23 Error: M409: control character in string 2020-09-27 00:41:47 Error: M409: control character in string 2020-09-27 00:41:55 Warning: M429: Command is not supported 2020-09-27 00:45:03 Error: Bad command: $M409 F"d99f" 2020-09-27 00:48:07 Error: Bad command: O409 F"d99f" 2020-09-27 00:48:23 Error: Bad command: O628 M409 F"d99f"*70 2020-09-27 00:49:36 Error: Bad command: `m409 F"d99f#*78 2020-09-27 00:51:28 Error: Bad command: < M409 F"d99f" 2020-09-27 00:53:12 Error: M409: control character in string 2020-09-27 00:53:52 Warning: M40: Command is not supported 2020-09-27 00:54:20 Error: Bad command: ?17 M409 F"d99f" 2020-09-27 00:54:48 Error: M4: Command is not supported in machine mode FFF 2020-09-27 00:55:40 Error: Bad command: `M409 F"d99f" 2020-09-27 00:57:00 Error: Bad command: `M409 F"d99f" 2020-09-27 00:58:32 Warning: M40: Command is not supported 2020-09-27 01:00:28 Error: M4: Command is not supported in machine mode FFF 2020-09-27 01:02:05 Error: M409: expected string expression 2020-09-27 01:02:53 Warning: M40: Command is not supported 2020-09-27 01:05:57 Error: Bad command: :91 M409 F"d99f" 2020-09-27 01:11:05 Error: M409: expected string expression 2020-09-27 01:12:05 Error: Bad command: 3 M409 K"job" F"v" 2020-09-27 01:14:26 Error: Bad command: 018 M409 F"d99f" 2020-09-27 01:15:22 Error: M409: expected string expression 2020-09-27 01:15:34 Error: M409: expected string expression 2020-09-27 01:17:58 Error: M4: Command is not supported in machine mode FFF 2020-09-27 01:18:34 Error: Bad command: (M409 K"job" F"v" 2020-09-27 01:20:38 Error: M409: expected string expression 2020-09-27 01:24:42 Error: Bad command: J1172 M409 F"d99f"*127 2020-09-27 01:26:48 Warning: M509: Command is not supported 2020-09-27 01:28:26 Error: Bad command: y M409 F"d99f" 2020-09-27 01:30:55 Error: M4: Command is not supported in machine mode FFF 2020-09-27 01:31:11 Error: Bad command: :0 M409 K"job" F"v" 2020-09-27 01:34:27 Warning: M40: Command is not supported 2020-09-27 01:36:11 Error: Bad command: 55 M409 F"d99f" 2020-09-27 01:37:53 Finished printing file 0:/gcodes/Printer Parts/Flying_Bondtech.gcode, print time was 1h 14m
Was this with a freshly uploaded gcode file or one that was copied over?
It was a fresh g-code. I also tried a different print and it ended up giving the same Attempting to extrude error.
@theshabobo said in Error: attempting to extrude with no tool selected:
Hi all. I just did the Duet 2 Wifi Upgrade on my printer and I am getting this error when I print any file generated by Simplify3D.
Note: This issue only occurs with S3D, not any other Slicers.
History: The printer was not having this issue with S3D before the Duet 2 Wifi conversion.This issue will happen at random points during any print. It starts the print fine, then at a random point it will throw this error. Even with the same file, it's random! I have had it happen halfway thru the 1st layer, or on the 10th layer, or the 50th while using the same .gcode file.
There is only 1 extruder, labeled as T0. In the S3D Profile. T1 is the heated bed.
So from the OP and stepping back from everything else that has been said in this thread, the issue is clearly to do with the gcode files that has been generated by S3D because of this statement (quote) "Note: This issue only occurs with S3D, not any other Slicers".
Or more specifically, those S3D gcode files have commands which are inconsistent with RRF firmware because of this statement (quote) "The printer was not having this issue with S3D before the Duet 2 Wifi conversion".
Therefore, the solution must lie in the gcode file so it might be an idea if the OP made that gcode file available, then we can see what commands are embedded which could be triggering the problem.
This comment could be a clue (quote) "There is only 1 extruder, labeled as T0. In the S3D Profile. T1 is the heated bed."
If S3D is putting T1 commands in the gcode file to control the heated bed, these commands will be interpreted by the duet firmware as being commands to select or control tool 1. But there is only a single tool defined in config.g so any "T1" commands will refer to a tool which does not exist. So switching to T1 is likely to trigger the error "attempting to extrude with no tool selected" because T1 does not exist.
So my best guess at a fix (without seeing the gcode file) would be to correct whatever setting in S3D is causing T1 commands to be inserted in the gcode file.
Edit - Or maybe the unsupported M40 and M429 commands the S3D is inserting in the gcode file are triggering the error. These need to be fixed in the slicer settings in any case.
@deckingman this has all my config files and a copy of the G-code.
https://www.dropbox.com/sh/yvealx81yym4kqh/AACMONG_FHO9DB7TqGrw7dyia?dl=0Also, Note. I tried using different slicers, and got the error in all of them.
Feel free to take a look and let me know if you can see what's happening. -
@theshabobo Ahh so it's changed from being something specific the S3D as per your first post, to being slicer agnostic. I'll take a look at the files later is I get chance. Meanwhile are you setting the slicer output "flavour" to RepRap" ?
EDIT - I've had a quick gander at the gcode file and none of the bad commands that are being reported exist in the file itself. There is only one "T" command which is "T0" at the beginning of the file - exactly as it should be. So my take on that is that the file data is somehow being corrupted as it is being read from the card. I have no idea why that should be. So it's over to someone more knowledgable that I. You could try disconnecting the PanelDue - at least that would narrow it down a bit.
If it is data corruption to/from the SD card, one way to check if the SD card has an issue is to download the gcode file from the SD card using DWC and compare it to the original file that was uploaded.
@deckingman Yes, it is RepRap. I disconnected the Paneldue and was able to do a 2.5 hour print with no issues and no Bad commands appearing in the logs.
I will be changing the PanelDue cable to a shielded one later today (after work) and trying again.
@T3P3Tony I don't believe it is an SD card issue, or file corruption issue as I tried with a new card and new file. I also verified the files are proper when compared to eachother.
@theshabobo hello, sorry for asking directly
did you solved it? i also have this problem, i change to stp lan cable and this problem still happened.
any tips ? -
@dc42 said in Error: attempting to extrude with no tool selected:
must be no more than 0.1 ohms per conductor
hello, sorry for asking. i am not electronic guy so i alittle bit blank with 0.1ohms per conductor. what this means
i check i use stp lan cable to do it and i check in the internet it is have resistence about 150ohms i cannot use this cable?
@lifeform That would be measured with a multimeter.
@theshabobo @Phaedrux @deckingman I'm having the exact same issue as described here. Same garbage commands, and tool being de-selected.
Current firmware versions:
Board: Duet WiFi 1.02 or later + DueX5
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11)
Duet WiFi Server Version: 1.23Has there been any other instances of this? I am using prusaslic3r and was not having this issue before the upgrade to RRF V3, which I performed a few days ago.
I am using a 4 pin paneldue cable. There is only one small section where it is near a stepper motor (probably 5mm cross section) and the rest of the cable is in an aluminum extrusion, so it should be shielded.
There may be interference somewhere, but I think that would have shown up before the upgrade to RRF V3
Baud rate for PanelDue is 57600
@Surgikill said in Error: attempting to extrude with no tool selected:
V3 definitely seems more sensitive to interference. You can try lowering the baud rate to make it more tolerant.
What paneldue firmware version are you using?
Unrelated, but the wifi version for 3.2.2 is 1.25.
@Phaedrux Paneldue firmware is 3.2.11
I'll look into updating wifi server. I thought that all was updated with the combined firmware when I updated to 3.2.2.
@Phaedrux Looks like the baud rate change might have fixed it. Any recommendations on wire? I want to re-wire some of my stepper motors with shielded wire to cut down on interference, can't seem to find any good wire.
Any decent gauge wire should do. I like to do a braid or twist which seems to help with crosstalk without shielding. I hear people mention silicone wire as nice to work with. I've only ever used some cheap spools of 22 gauge wire on amazon for low current DC applications. Nothing special. And for AC wiring some larger gauge stuff from the local auto parts store.
@Phaedrux Well I lied, still getting communication issues. I replaced the SD card with a brand new one, and I moved the stepper motor wire that was near the paneldue wire so there is 4+ inches of separation. The only other wire near it is a mechanical endstop switch. Any other ideas? The paneldue does not have a SD card in it.
