Temprature sensor error unknown temperature sensor channel
1.8mm trigger height sounds reasonable. 14mm high? Where is that coming from? How are you measuring that? After homing if you jog to z0 the nozzle should be touching the bed.
@Phaedrux i have a E3d super volcano on this machine so i measure from the bottom of the block with a ruler to the bed and it homes 14mm high every time. i can move the nozzle to the bed via the controls sure, but i thought it would home to the required printing height each time if set correctly?
@Phaedrux when i home Z it raises the bed hits the Zprobe then the bed drops 10mm or so?
@JTM what height does DWC report Z is at after homing Z? If 0, but nozzle is off bed, post your homeall.g and homez.g
@droftarts its says 0 on the console
homeall :
generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 16 2020 07:34:10 GMT+1000 (Australian Eastern Standard Time)
G91 ; relative positioning
G1 H1 X-505 Y-455 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-505 Y-455 F600 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X15 Y15 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioningHome z:
; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 16 2020 07:34:11 GMT+1000 (Australian Eastern Standard Time)
G1 X15 Y15 F6000 ; go to first probe point
;G90 ; absolute positioning -
@JTM said in Temprature sensor error unknown temperature sensor channel:
The print height gets set by the slicer.
The important thing is that after homing you can do a G90 G1 Z0 move and the nozzle touches the bed. If that works, then when you start the print it will go to the right height.
Maybe show a photo of what you mean with the 14mm if you still think something is wrong.
@Phaedrux said in Temprature sensor error unknown temperature sensor channel:
G90 G1 Z0
that did the trick ! so when the print starts it moves to z position 0? i didnt know that. I am trying a print lets see what happens but im finding i have to heat the extruder manually before starting a print. Ill figure it out tommorow
 I have started a print almost completed ! There are a couple of bugs to iron out but this board is amazing! So quite ! I have the wrong nozzle for the print as it was a rush to see it working but almost done! Just printing in reverse ! Lol but I’m sure there is an easy fix for it !
Thanks heaps guys I really appreciate all the help ! -
you have to wait a bit after the image upload reaches 100% otherwise the image will no be displayed
I’ll try again
@JTM
wait for it to display in the preview window -
 I don’t think I can load pictures from my mobile?
There were problems uploading images to the forum from some versions of Chrome. Is Chrome up to date on your smartphone? Or are you using a different browser?
@dc42 I think so mate, had an update not long ago.
Well no when the print starts it will move the first layer height set by the slicer. 0.2 or whatever you have it set to.
@Phaedrux yes it does move to the correct height for printing. I worked out why the machine was printing in reverse, embarrased to admit but i had the X and Y motors and end stops back to front ! lol
I have the machine printing but for some reason it doesn't start the heater automatically, i have to heat the extruder then start a print to get t printing. Not sure what this error is :Error: Temperature reading fault on heater 0: sensor open circuit
Resume state saved
Printing paused at X0.0 Y0.0 Z0.0I will try my friend google and see what i can come up with, thanks again for all the help guys !
@Phaedrux i am getting this error when trying to print:
Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater faultI'm guessing that the extruder temp is set below the temp (260c) i want to print at. how do i change that if that's the case?
Thanks in advance -
What slicer are you using? Does it have the temp set for what you want?
You should add
T0
to the end of your config.g so that the first tool is selected at startup. You should also add a T0 to your slicer start gcode just in case the tool gets deselected along the way.Can you post a sample sliced gcode file so we can see what it's trying to do at the start of a print?
@Phaedrux Hi mate, i'm using Simplyfy3d so yeah i set my temps for my other machine all through S3D. Im not sure about the sliced gcode, but in the scripts tab the starting script is G28 ; home all axes
Ive also noticed my end script to lift the nozzle 50mm after print finishes doesn't work either?
M104 S0 ; turn off extruder
M140 S0 ; turn off bed
M84 ; disable motors
G91;
G1 Z50;
G92; -
G91;
G1 Z50;
G92;Well it disables the motors and then tries to move them so move the M84 to the end.
