Printed files don't appear in G-Code files list
I upl;oad and print a file but it doesn't get to the G-code files list. I think this problem appeared after updating to 1.18Firmware Name: RepRapFirmware for Duet WiFi
Firmware Electronics: Duet WiFi 1.0
Firmware Version: 1.18.1 (2017-04-09)
WiFi Server Version: 1.03 (ch fork)
Web Interface Version: 1.15a -
When I used Edge I had the same problem. When I changed to Firefox it worked fine.
Note that Edge has issues with Html5 when last checked. Recommendation is to use chrome or Firefox
I use Chrome
How long is your gcode files list? There is a limit on how many files will be displayed. I can't remember how long it is and it depends on the lengths of the file names, but it's normally more than 50. If you have a lot of files, you can organise them into subfolders.
Yes, there are many files, I can count them tomorrow.
BTW, a few times I wanted to clean the files, but could not find a way to choose and delete many files at once. Is there any trick to do that?
I counted some 95 files in web-interface.
Is there a way to remove them fast? -
Three possibilities:
1. Delete them individually.
2. Create some subfolders. You can drag files individually into the subfolders in DWC. This is probably quicker than deleting them individually, plus you get to keep them.
3. Remove the SD card, put it in a PC, and delete them from the PC.
Thanks!
I had 117 files in "gcodes".
It probably stopped showing new files after 95.Please make some interface to choose and move/delete multiple files.
Please request this in the Duet Web Control Wish List section of the forum
