G32 Error:´´ Z probe was not triggered during probing move´´
@fcwilt
the word ´´deploy´´ and everything around it in the g.code is made by the configuration tool of!!!! how can it be wrong? -
@barbarossa-cologne said in G32 Error:´´ Z probe was not triggered during probing move´´:
@fcwilt
the word ´´deploy´´ and everything around it in the g.code is made by the configuration tool of!!!! how can it be wrong?I don't know. I've only used the config tool one and that was to generate a basic printer file for my kind of printer.
Then I looked at the generated code to learn how v3 firmware does things.
Then I edited my v2 files to meet the requirements of v3 firmware.
Not to worry - we determined the basic problem - your files were a bit messed up.
Do you know who to select all files in the SYSTEMS directory and use the "Download as ZIP" feature to get all of the files into a single ZIP file?
If you know how to do that do so and post the ZIP file here. I will download it and examine the files.
That will take a while so I won't be able to get right back to you.
@fcwilt
I can´t send the zip here, rigth?
There comes a message with ´´invalid file type´´ -
@fcwilt
Thanks a lot!!!!!! and take your time. -
@fcwilt
Thanks a lot!!!!!! and take your time.I will try to look at them tonight after dinner on in the morning.
However I have to assist my wife who is having surgery on Wednesday and I will be with her from noon Tuesday until Thursday or Friday.
@fcwilt
No stress. take your time.
Maybe you´ll first find out whats causing the ´´Error: Failed to enable endstops´´.
But take your time. Your family is more important!
Guten Appetit! -
I'll try to catch up on this thread later today/tomorrow.
@Phaedrux said in G32 Error:´´ Z probe was not triggered during probing move´´:
Thanks. I might not have time.
I suspect that it is just a question of errors in the files.
A quick check of config.g showed some garbage at the end.
@Phaedrux Thanks and no stress.
I´m not the only one who needs help. -
Ok, I've got caught up. Thanks very much to @fcwilt for all the troubleshooting. Well done. Turned out it was a case of the old config files in the wrong place.
So let's start from the top and see if we can get things up and running finally.
Duet 3 MB6HC version 3.01-RC9
You should update the firmware before we go any further.
Download this zip file and upload it AS IS to the /sys folder in DWC. Do not extract it.https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
It should detect the firmware upload and install it. After it will reboot. Then send M115 in the gcode console to verify that it was successfully applied.
As for the config files, I think you should go through the config tool and create a fresh set of config files. Try and choose everything as accurately as possible. Then download the config zip file and upload it to the /sys folder as is as well. That should place your new config set in the correct place.
https://configtool.reprapfirmware.org/Start
Also upload those files here so that we can double check them.
Please provide the following details here as well so that we can compare to what is in the config.
How big is the printer area?
What kind of endstops do you have?
Where are the endstops located on the printer and where are they connected?
What are your heaters and how are the connected?
What are your fans and how are they connected?
What are your motors and how are they connected?
How is the BLtouch connected?Once we have the basics up and running. Motors. Homing. Heaters. Fans. We can make the changes needed for automatic bed leveling.
that is an old issue.... now it´s not possible to start z probe. the message ´´Error: Failed to enable endstops´´ is shown.....
ok.... to all these questions. everything was working ONLY the true auto level not.
please give me time. I haven´t expected that much work again... -
Spam???????
@barbarossa-cologne
I´m sorry but I took a look in the configuration tool via the systems page in the DWC and decided that I just posting the g.codes that you need exactly. Because everything was working or IS working except the Bl-Touch / Z Probe.
After one month having the same problem ONLY with the BL I just want to try fixing it like this. I hope its ok.
Time is rare....; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Duet 3" ; set printer name ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P0.3 S1 ; physical drive 0.3 goes forwards M569 P0.4 S1 ; physical drive 0.4 goes forwards M569 P0.5 S1 ; physical drive 0.5 goes forwards M569 P1.0 S1 ; physical drive 1.0 goes forwards M569 P1.1 S1 ; physical drive 1.1 goes forwards M569 P1.2 S1 ; physical drive 1.2 goes forwards M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0:1.1:1.2 ; set drive mapping M350 X16 Y16 Z16 E16:16:16:16:16:16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z1600.00 E1600.00:1600.00:1600.00:92.70:92.70:92.70 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E3600.00:3600.00:3600.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z40.00 E250.00:250.00:250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2) M906 X1200 Y1200 Z3000 E3000:3000:3000:1200:1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X700 Y700 Z800 S0 ; set axis maxima ; Endstops M574 X2 S1 P"!io3.in" ; configure active-high endstop for high end on X via pin !io3.in M574 Y2 S1 P"!io0.in" ; configure active-high endstop for high end on Y via pin !io0.in ; Z-Probe M558 P9 C"io4.in" H10 F200 T1800 ; set Z probe type to bltouch and the dive height + speeds M950 S0 C"io4.out" ; create servo pin 0 for BLTouch G31 P25 X-20 Y-20 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X15:650 Y15:650 S200 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H1 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S90 ; set temperature limit for heater 0 to 90C M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency M106 P0 S0.8 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off M950 F2 C"out8" Q500 ; create fan 2 on pin out8 and set its frequency M106 P2 S1 H T45 ; set fan 2 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined M671 X-12:92:92:-12 Y185:185:615:615 S2.5 ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power deploy---------------------------- ; deployprobe.g ; called to deploy a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit) M280 P0 S10 ; deploy BLTouch retract.g-------------------------------- ; retractprobe.g ; called to retract a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit) M280 P0 S90 ; retract BLTouch homez.g------------------------- ; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Thu Jun 25 2020 00:21:12 GMT+0200 (Mitteleuropäische Sommerzeit) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G1 X15 Y15 F6000 ; go to first probe point G30 ; home Z by probing the bed
; bed.g ; Called using G32 ; Called to perform True Autolevel using 4-point probe ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit) M561 ; clear any bed transform G29 S2; Clear bed height map ; Probe 4-point G30 P0 X150 Y135 Z-9999 ; Front Right G30 P1 X550 Y135 Z-9999 ; Front Left G30 P2 X550 Y565 Z-9999 ; Back Left G30 P3 X150 Y565 Z-9999 S4 ; Back Right
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit) G91 ; relative positioning G1 H2 Z15 F2400 ; lift Z relative to current position G1 H1 Z-805 F1200 ; move Z down until the endstop is triggered G92 Z0 ; set Z position to axis minimum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z15 F40 ; lift Z relative to current position ;G90 ; absolute positioning
this are codes from the systems page.... NOT a macro. I´m sorry for beeing stupid in this thread and posting macros. I was tired after working much.
I hope somebody can help me in this way -
@barbarossa-cologne you have posted two homez.g files; one on the end of the config.g (also deploy and retract on there), and one separate. Which is the right one? One uses G30 to home Z, the other uses a maximum Z endstop, which isn’t defined in config.g.
@droftarts
the G30 configuration should be the rigth one. Should I copy that to the home z file?
Or how should I handle it? -
@barbarossa-cologne does your config.g contain deploy.g, retract.g and homez.g? These should not be in config.g, they should be separate files in the sys folder, which probably already exist. The homeall.g is run when you press the “Home all” button in DWC, and homez.g is run if you press the “home Z” button, so it is important that both these files are correct. Similarly, pressing “Home X” or “Home Y” runs homex.g or homey.g respectively. Post your homeall.g file, too.
So yes, copy the G30 version to the homez.g and homeall.g files, and also update the deploy.g and retract.g files, then delete from config.g everything after the “Miscellaneous” section.
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit) G91 ; relative positioning G1 H2 Z15 F2400 ; lift Z relative to current position G1 H1 X805 Y805 F1200 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X-5 Y-5 F2400 ; go back a few mm G1 H1 X805 Y805 F360 ; move slowly to X and Y axis endstops once more (second pass) G1 H1 Z-805 F360 ; move Z down stopping at the endstop G90 ; absolute positioning G92 Z0 ; set Z position to axis minimum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z15 F40 ; lift Z relative to current position ;G90 ; absolute positioning
@droftarts
G32 is working perfect. Also the normal Z probe with the BL Touch!!!
Thank you a lot!!!!
