Duet3D 2 WiFi - Requested temperature out of range
@davidvh86 if there’s a configuration in that file, that would be easy and cool -
Well I see the M143 for the bed but I don't see the M143 for the hotend.
Perhaps the config tool has a bug.
In any case lookup how to use M143 and add it to your config file for the hotend.
@fcwilt
I think it does too a few of my temp limits wernt showing up in my final config. -
@davidvh86 said in Duet3D 2 WiFi - Requested temperature out of range:
@fcwilt
I think it does too a few of my temp limits wernt showing up in my final config.Just one more edit and I think you will have it.
@fcwilt let’s see here,...
@fcwilt nice! stopped The error message, capping out, at around 305c weird
I removed the M143 for my extruder and reset the board.
Now the temp limit reported was 285 - so perhaps that is the default for extruders.
IIRC when not defined, the default max temperature is 280 degrees for a tool
What is your installed firmware version? M115 to find out.
@Phaedrux currently 3.1.1
Any defaults are going to be coded into the firmware.
The purpose of M143 and many other commands are to set the actual required values.
I have never worried about defaults since I am going to be setting the values I need.
