Error: Timeout while waiting for transfer ready pin
I m not sure if this should be here, or under Duet Web Control Topic.
Still seeing this error on occasion.
"Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)"
M122 shows:
Last reset 00:00:38 ago, cause: software
Last software reset at 2020-05-25 18:39, reason: Assertion failed, spinning module GCodes, available RAM 71820 bytes (slot 0)
Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a80f BFAR 0x00000000 SP 0x2045fe9c Task MAIN
Stack: 00000194 00484cd0 00463dbf 00000001 0045831f 20428990 2044cd58 2044cc08 2043f1a8 00000001 2043f120
Error status: 0Usually only after uploading file to print. Once printer is reset and zeroed, I can print the file with no errors.
I have attached my config.g, the results from the M122 and console text prior to M122 along with the file I was printing.
Custom CoreXY
Duet3 +RPI 4B
DWC 3.1.1
DSF 3.1.1
Firmware: RepRapFirmware for Duet 3 MB6HC 3.1.1 (2020-05-19b2)config.g
Console with M122 Results 5_25_2020.txt
CuttingBoardHangerHalves.gcode -
I also got this error.
CoreXY Duet3 6HC +3HC
Doing some dryruns to test speed limits before steppers skip.=== Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode) Board ID: 08DJM-956L2-G43S4-6JKDD-3SJ6L-TB62G Used output buffers: 1 of 40 (14 max) === RTOS === Static ram: 154604 Dynamic ram: 164164 of which 32 recycled Exception stack ram used: 304 Never used ram: 74112 Tasks: NETWORK(ready,1980) HEAT(blocked,1188) CanReceiv(suspended,3420) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4640) IDLE(ready,76) Owned mutexes: === Platform === Last reset 00:12:42 ago, cause: software Last software reset at 2020-07-02 09:35, reason: Assertion failed, spinning module GCodes, available RAM 73220 bytes (slot 3) Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a80f BFAR 0x00000000 SP 0x2045fe9c Task MAIN Stack: 00000194 00484cd0 00463dbf 00000001 0045831f 20428990 2044cff8 2044cfa8 2043f1a8 00000001 2043f120 Error status: 0 MCU temperature: min 38.2, current 38.3, max 38.7 Supply voltage: min 31.9, current 31.9, max 32.0, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0 Driver 0: standstill, reads 46392, writes 0 timeouts 0, SG min/max not available Driver 1: standstill, reads 46392, writes 0 timeouts 0, SG min/max not available Driver 2: standstill, reads 46392, writes 0 timeouts 0, SG min/max not available Driver 3: standstill, reads 46392, writes 0 timeouts 0, SG min/max not available Driver 4: standstill, reads 46392, writes 0 timeouts 0, SG min/max not available Driver 5: standstill, reads 46392, writes 0 timeouts 0, SG min/max not available Date/time: 2020-07-02 09:48:45 Slowest loop: 4.94ms; fastest: 0.23ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is ready with "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 0.66ms; fastest: 0.01ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 0 of 8 - Ethernet - State: disabled Error counts: 0 0 0 0 0 Socket states: 0 0 0 0 0 0 0 0 === CAN === Messages sent 782, longest wait 0ms for type 0 === Linux interface === State: 0, failed transfers: 0 Last transfer: 17ms ago RX/TX seq numbers: 54295/25052 SPI underruns 0, overruns 0 Number of disconnects: 0 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.1.1 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 32.47
@TypQxQ said in Error: Timeout while waiting for transfer ready pin:
CoreXY Duet3 6HC +3HCMy best guess is that there was a power brownout or a transient of some sort (static discharge?).
