Just a little lost re: upgrading to 3.0 firmware.
; Z-Probe M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X15:215 Y15:195 S20 ; define mesh grid
; deployprobe.g ; called to deploy a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 09 2020 12:35:40 GMT-0600 (Central Standard Time) M280 P0 S10 ; deploy BLTouch
; retractprobe.g ; called to retract a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 09 2020 12:36:12 GMT-0600 (Central Standard Time) M280 P0 S90 ; retract BLTouch
That's right out of the configurator.
@Phaedrux
I had it set up just like you just posted, and this is the error I get every time."Invalid servo index 0 in M280 Command."
I'm in the port labeled PWM5 on the duex board. This really is PWM5, correct? PWM5 isn't really PWM7 or something like that, right? I'm just trying to figure out why I cannot deploy the probe. Everything try yields some error or another when I try the M401...
@Phaedrux said in Just a little lost re: upgrading to 3.0 firmware.:
That looks correct to me. If you send that command from the console, what response do you get?
Please verify using M115 that you are running firmware 3.1.1.
6/9/2020, 3:40:31 PM M401
Error: M280: Invalid servo index 0 in M280 command
6/9/2020, 3:40:11 PM Upload of config.g successful after 0s
6/9/2020, 3:37:03 PM M401
6/9/2020, 3:36:49 PM M401
Error: M280: Invalid servo index 0 in M280 commandTwo tries, then cleared out, saved, re-opened blank deploy and retract g codes, and made them from scratch.. still same thing..
; deployprobe.g
; generated by RepRapFirmware Configuration Tool v3.1.1 on Tue Jun 09 2020 01:46:51 GMT-0400 (Eastern Daylight Time)M280 P0 S10 ; deploy BLTouch
That's my deploy.....
And you have this exactly in config.g?
@Steve-Lynch said in Just a little lost re: upgrading to 3.0 firmware.:
The command I wanted you to send from the console was the M950 command that I quoted.
This is my exact BL Touch Section:
; BLTouch
M950 S0 C"duex.pwm5" ; Define the bltouch servo on duex.pwm5
G31 P500 X0 Y28.8 Z4.9 ; set Z probe trigger value, offset and trigger height
M557 X4:300 Y27:300 S20 ; define mesh grid -
@dc42 Sorry sir... This is what it says:
6/9/2020, 3:48:23 PM M950 S0 C"duex.pwm5"
Warning: M950 command is not supported
6/9/2020, 3:48:06 PM M950 S0 C"duex.pwm5"
Warning: M950 command is not supported -
Looks like you are running RepRapFirmware 2.x then. Send M115 to check.
Here's what's in the "Machine specific" section...
Electronics
Diagnostics
Board: Duet WiFi 1.02 or later + DueX5
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3)
Duet WiFi Server Version: 1.23Note: You can install updates on the System page.
Is there any merit to just starting completely fresh? I've upgraded / downgraded several times, and god only knows what could be mismatched. Again, not your fault, I'm just stumbling through this...
actually, It was waiting for a restart.... I may have created that problem myself... I was in 3.0 when I originally posted. I switched back down for last night, so I could print, and re-loaded from the configurator a little bit ago... I must not have re-specified my firmware version in the configurator when I uploaded My JSON. Sorry... I've been trying so may things, that I lost track...
I just started fresh.... Probe deploys and retracts now! It was the extra C"duex.pwm5" that was in my "deploy probe" that was causing the problem. Just removed it, and I Heard it click!
So I was sooo close... Just had extra crap in the command.. Drats!
Now to figure out My heaters.... I think I probably have to specify ports and stuff for them. I'll go try that, and leave you alone unless I can't get it!
Also, the Configurator inserted extra lines in My BLTouch section. Stuff about Mod Probe, and servo angle and such.. It was not in the lines @Phaedrux sent me, so I deleted it.
I appreciate your patience...
Thanks for helping me get this far. I'm down to 2 little dilemmas now... Well, Possibly three, but We'll just stick with the two...
I've asked all around, and cannot seem to find an answer. What is the Gcode in 3.0 to release a BLTouch Alarm, and Pull Pin Up? I know thew old code was:
M280 P0 S160.
That's changed, and I tried replacing the P0 with C"duex.pwm5" but that doesn't seem to work.
What's happening is that my BLTouch deploys, homes, then goes into "Flashing Mode" saying the pin was already triggered. Any Ideas?
Lastly, I've always controlled lights Via PWM fan ports.
I'm in Fan/LED 3 and Fan/LED 4 on the duex.
If I make a macro with:
M950 F3 C"!duex.fan3" Q0
M950 F4 C"!duex.fan4" Q0Both Lights Turn Off
any Q number over "1" results in full brightness.
I used to be able to dim the lights using an integer between 1-255. any number I put in there now results in Full Brightness. These LEDS are extremely high output, so To avoid the extreme heat they put off, I simply dim them to 50%
Any suggestions on how to change the dimming value? I believe it was reducing the voltage the way it used to do it. Do you know what the new way is? Thanks!
Can you try a decimal number between 0 and 1? 0.1, 0.2, etc?
M280 P0 S160.
Assuming you are using servo index 0 to control the BLTouch, that should still work.
Remove the ! and the Q0 parameters in those two M950 commands.
BL Touch - Solved
Light control: The lights will only light up of I invert the pins with !
I tried removing them, and even tried swapping polarity. they will not trigger without the ! character.
They work fine without the "Q" value, but will not dim. Is a fan output the best way to do this? should I specify it as something else? say, a Heater? Either way, what would be the method to reduce the power to the lights, for, say, 50% brightness?
thanks so much!
The M950 command just assign fan number to the fan ports. To control the PWM, use M106 as usual. For example:
M950 F3 C"duex.fan3"
M106 P3 S0 ; LED off
M106 P3 S1 ; LED on
M106 P3 S0.5 ; LED half brightness -
OK, thanks.. I was trying to use M42, as specified in the documentation. I got everything else working now. Thanks a lot! This new system is a lot easier to wrap my head around
You can either use M950 Fn to create a fan port, then M106 Pn Sn to control it; or you can use M950 Pn to create a GpOut port, then use M42 Pn Sn to control it.
Using a fan port gives you a slider to control it in DWC, and options for direct thermostatic control. Using a GpOut port gives you neither of these, however you can still use the daemon.g file to have the LEDs change automatically in response to e.g. temperature or printer state.
