Solved G28 Delta towers crash
; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat May 16 2020 12:10:05 GMT+0100 (British Summer Time); General preferences
M550 P"kossel" ; set printer name
M665 R204 L288 B110 H200 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S1 ; enable Telnet; Drives
M569 P1 S0 ; physical drive 1 goes forwards
M569 P3 S0 ; physical drive 3 goes forwards
M92 X160.00 Y160.00 Z160.00 E663.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X2000 Y2000 Z2000 E1800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 Y2 Z2 S0 ; set active low and disabled endstops; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 R100 S20 ; define mesh grid; Heaters
M106 P0 S0 I0 F500 H0 T30 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
Set M574 to S1
Please post your homedelta.g file too.
What firmware version are you using?
Hi David, I am using the firmware:
Duet WiFi 1.02 or later (duetwifi102)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05.1 (2020-02-09b1)
Duet WiFi Server Version: 1.23 -
; homedelta.g
; called to home all towers on a delta printer
G91 ; relative positioning
G1 H1 X265 Y265 Z265 F1800 ; move all towers to the high end stopping at the endstops (first pass)
G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
G90 ; absolute positioning
G1 X0 Y0 F6000 ; move X+Y to the centre -
@rodek wouldn't that persume they are active when high?
I didn't see anything wrong with your configuration and homing files.
I suspect that you have swapped a couple of motor or endstop cables over. Use G91 followed by G1 H2 Xnnn moves to identify which tower has the X motor. Then check that when you trigger the endstop on that tower, M119 shows that it is the X endstop that is triggered. Repeat for Y and Z.
@dc42 Cheers David, the endstops seem to trigger and are confirmed under endstop status under machine specific tab.
does it matter which tower is the x , y and z on a delta as long as it goes in a clockwise direction?
I assume it does matter in the way the endstops correlate to the towers.
It may just be best practice to call the left tower "X", the right one "Y", and the back one "Z", but it really does help in preventing (or at least resolving) this type of issues.
@chris said in G28 Delta towers crash:
What I was trying to as was: Is the endstop that shows as X when triggered on the same tower as the motor that moves when you command X movement with a G1 H2 Xnnn move?
Instances of the behaviour you describe are typically caused by the motor and the corresponding endstop (e.g. X motor and X endstop) not being on the same tower.
@dc42 Cheers david X and Y limit switches got swapped
