Software bundle 3.1.1 now available
@dc42 @chrishamm It was a lot of work and a long haul I know. Congratulations!
Upgraded. Pi+6HC+2x3HC+1HC. No issues.
Fantastic to have everything match. Conditional, etc.
Thank You.
Sorry if I'm being thick but I'm still on a very early beta (pre - RC) firmware and it has been many months since I last installed an update. I'm not sure what the RepRap firmware zip file contains - maybe I missed something somewhere.
I've made the following assumptions which I'd like to be confirmed please. Note, I'm still running stand alone - non RPi
The "Duet2and3Firmware-3.1.0.zip is just the firmware. I still need to separately download and instal "DuetwebControl 3.1.0." Yes or no?
The "Duet2and3Firmware-3.1.0.zip" is just for the main board. I still need to separately download and instal "Duet3Firmware_EXP3HC.bin" for the expansion boards. Yes or no?
Also, what is the procedure for updating expansion board firmware these days? Do I still need to send M997 Bn after uploading it or just run M98 P"config.g"?
Thanks
@deckingman said in Software bundle 3.1.0 now available:
Looks like the zip file contains everything needed for the board firmware, expansion tool board firmwares and the DWC files.
I don't know what version you're running specifically, but it may be best to update to 3.0 with it's zip file, and then 3.01 with it's zip file
@Phaedrux said in Software bundle 3.1.0 now available:
- ref Zip file - Cool.
- ref 3.0 - Good point. I'd have to check but methinks it'll be something like MB6HC291919 for the main board and EXPHC28b4 for the expansion boards. I guess it'll do no harm to update to 3.0 first in any case.
Do you happen to know if it's still necessary to send M997 Bn after uploading expansion board firmware?
It should install it automatically. Use M115 B# (# = CAN address of each expansion board) to check that it worked.
@dc42 said in Software bundle 3.1.0 now available:
Well... then... report:
In a Pi + 6HC + 2 x 3HC + 1HC system, the 6HC was firmware upgraded during the "sudo apt upgrade". The expansions and tool were not. I M997 each manually, and that went fine.
sudo journalctl -u duetcontrolserver (snipped to startup of 3.1 server) May 15 13:29:36 duet3 systemd[1]: Started Duet Control Server. May 15 13:29:36 duet3 DuetControlServer[3530]: Duet Control Server v3.1.0 May 15 13:29:36 duet3 DuetControlServer[3530]: Written by Christian Hammacher for Duet3D May 15 13:29:36 duet3 DuetControlServer[3530]: Licensed under the terms of the GNU Public License Version 3 May 15 13:29:36 duet3 DuetControlServer[3530]: [info] Settings loaded May 15 13:29:37 duet3 DuetControlServer[3530]: [info] Environment initialized May 15 13:29:37 duet3 DuetControlServer[3530]: [info] Connection to Duet established May 15 13:29:37 duet3 DuetControlServer[3530]: [info] IPC socket created at /var/run/dsf/dcs.sock May 15 13:29:37 duet3 systemd[1]: /lib/systemd/system/duetcontrolserver.service:9: CPU scheduling priority is out of range, ignoring: 20 May 15 13:29:39 duet3 systemd[1]: /lib/systemd/system/duetcontrolserver.service:9: CPU scheduling priority is out of range, ignoring: 20 May 15 13:29:40 duet3 systemd[1]: /lib/systemd/system/duetcontrolserver.service:9: CPU scheduling priority is out of range, ignoring: 20 May 15 13:29:44 duet3 DuetControlServer[3530]: [info] Flashing IAP binary May 15 13:29:44 duet3 DuetControlServer[3530]: [info] Flashing RepRapFirmware May 15 13:29:51 duet3 DuetControlServer[3530]: [info] Verifying checksum May 15 13:29:54 duet3 DuetControlServer[3530]: [info] Firmware update successful May 15 13:29:54 duet3 DuetControlServer[3530]: [info] Starting macro file config.g on channel Trigger May 15 13:29:54 duet3 DuetControlServer[3530]: [info] FTP is enabled on port 21 May 15 13:29:54 duet3 DuetControlServer[3530]: [info] TELNET is enabled on port 23 May 15 13:29:55 duet3 DuetControlServer[3530]: [info] Starting macro file yLimitPark.g on channel Trigger May 15 13:29:55 duet3 DuetControlServer[3530]: [info] Finished macro file yLimitPark.g May 15 13:29:55 duet3 DuetControlServer[3530]: [warn] M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C May 15 13:29:55 duet3 DuetControlServer[3530]: [info] Starting macro file /sys/Toffsets.g on channel Trigger May 15 13:29:56 duet3 DuetControlServer[3530]: [info] Finished macro file /sys/Toffsets.g May 15 13:29:56 duet3 DuetControlServer[3530]: [info] Finished macro file config.g pi@duet3:~ $
@Danal We decided to upgrade only the main firmware via the 3.1.0 package but that may change in 3.2.0. You do have to run
M997 B>=1
in SBC mode to update the expansion boards. -
Sorry - I'm still big thick. I've downloaded both RRF 3.0 and 3.1 zip files and extracted the contents into separate folders. I'm not seeing any DWC files that you indicated would be included, so I guess I still need to download the DWC zip separately yes? Or have I done something wrong?
Also, I see "DuetFirmware_TOOL1LC.bin" which I'm guessing is for tool boards. So as I only have expansion boards, I don't need that yes?
Finally, I see "Duet3_SDiap_MB6HC.bin. I think I already have that but I'm guessing this might be a later version so I ought to instal it yes?
Cheers
upload straight to dwc, no extraction first?
@bearer said in Software bundle 3.1.0 now available:
Oh really? Cool
Edit - things have moved on since December
@deckingman might be a feature of dwc2, however from my point of view its always been like that even in RRF2. Then again I'm (relatively) new to the game
Yes DWC has been updated by installing from a zip file for a very long time. But last time I updated the main board and expansion boards firmware back in December it was still done by uploading the individual firmware files. So updating everything, including all the boards firmwares as well as DWC from a single zip is new to me.
Didn't know it can be done like that?
I always upload the two bin's and the DWC ask if I want to flash the updated firmware file. The "big" zip file has too much stuff, never tried uploading that one
So far we are investigating two bug reports for the 3.1.0 release:
One user has reported that he is getting occasional resets. The M122 report shows the reason is stack overflow from the Network task (NETW in the M122 report). If you encounter this issue, please see this thread https://forum.duet3d.com/topic/16390/3-1-0-firmware-reboots-periodically for what to do.
Duet 3 with attached SBC fails to write the height map file after running G29. We are investigating this. Further information will be posted in this thread https://forum.duet3d.com/topic/16388/g29-not-writing-a-heightmap-csv.
@arhi Glad I'm not the only one who didn't know that (but I haven't tried it yet).
@dc42 Ahhh. Well in that case I'll hold off updating for now....
@chrishamm said in Software bundle 3.1.0 now available:
M997 B>=1
in SBC mode to update the expansion boards.Thanks. That's actually what I thought... I just read something into a post that wasn't there.
This post is deleted! -
the update to 3.10 worked well, unfortunately my PanelDue 7 "no longer wants to connect to my duet2maestro
there are already solutions for this Problem?
thank you
