Print Frozen - RRF3.01-RC12 and DSF 2.2.0
BTW, I don’t know why but when running the debug console I can still access the webpage and ssh but crontab stopped running.
@mwwhited, I believe this is fixed in the new firmware binary at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0. Please can you test it.
@jay_s_uk The fix will most likely resolve your problem, too. Please give it a try if you can.
Great stuff. I'll give it a go
@dc42 How long should this update take to apply?
it's been saying "Please wait while updates are being installed... " for over 15 minutes.
I'm now getting "Timeout while waiting for transfer ready pin" when I try to start DuetControlServer in debug mode.
I got that when I installed both the expansion and main board updates. It started working again once I fully powered off the machine
It should be very quick, like any other firmware update. I suggest you try updating the firmware using Bossa instead.
Okay, I'm back up and running after wedging a USB cable into my controller (guess I should have left some more room to work with.) I'll let it run and let you know how it goes.
I've updated the firmware on my boards but not had chance to run a print yet. Too busy tweaking my tpre and tpost files.
I haven't seen any more issues today... but I'll continue to keep and eye on it.
-Thanks,
Matt -
Didn't fix the issue. I was working on my toolhead scripts this morning and RPi froze.
@mwwhited Please try out the latest software bundle, there have been some more improvements since then. If you do see more freezes, please check the log of DCS (
sudo journalctl -u duetcontrolserver -e
