Duet3/pi DCS is unavailable after wiring 24V
Wow @bearer you absolutely killed it
Thank you everyone!
@fractalengineer said in Duet3/pi flashing Diag LED after wiring 24V DCS is unavailable:
...again with the jokes, but technically you killed it, i fixed it, or put a band aid on it at least ...
volcano insurance ftw!
WHOO HOOO! As a mostly bystander, congrats to @bearer for all the "figurin" and to @fractalengineer who now has a running machine.
@fractalengineer, now the fun REALLY starts!
@bearer lol yess
I was thinking for a neater build would it make sense to swap the 22 and 18 wires like so?
@bearer lol yess
Its a neat idea, but i'd trim a bit off to avoid reterminating the idc where the insulation is already displaced
This way (as on the Duet 2 automated test equipment prototype on my desk) avoids having to disturb the IDC connectors:
Hey all,
I have the same "DCS is unavailable" issue with my Duet 3 v1.0 and RPI 4.
Do I understand correctly that swapping wires 22 and 18 on the ribbon cable will fix this issue ?
I have installed the lastest DuetPI version on my RPI and also reflashed my Duet3 with RRF 3 Release 3.01-RC12.Cheers Max
@MaxGyver said in Duet3/pi flashing Diag LED after wiring 24V DCS is unavailable:
In general probaly no, pretty spescial case with a damaged raspberry pi, you can test it using the same tools as described in the thread.
More likely RRF and DSF is out of sync, which version of DSF are you using - if you just downloaded the DuetPi image it will be using an old stable version not compatible with RRF 3.01-RC12. Switch to unstable package feed or downgrade RRF to 3.0 release.
@MaxGyver Best to start a new thread to fully diagnose your issue.
@bearer @Phaedrux
I have solved the issue by installing the unstable version (DSF Version: 2.1.3) of Duet Software Framework on Raspberry Pi. and also reverting back to RC11
The guide links to the stable version of the DSF and latest version of the reprap firmware which, at least in my case is not compatible and will lead to the "DCS is unavailable" Error.
cheers Max
